Author Topic: [GB] KAM Command (GB is over)  (Read 36859 times)
Offline mvkb
  • Designer
    • MVKB
« on: Mon, 04 October 2021, 07:47:11 »
276877-0
276879-1
Our alien robot overlords are here, and you too can join their squadron of nuclear-powered spacecraft by purchasing this set of controls keycaps. This is a limited time offer available from October 4 2021 until November 4 2021 at an electronics store on-line e-commerce website*. Don't miss out on this amazing deal!
*Internet connection required.
This set is an homage to the sci-fi books, TV shows and movies we all grew up with. It takes inspiration from a bunch of them, and adds its own little twists. Every single legends is custom designed, including the made-up alien-overlord language. The name "Command" comes from "By your command!", the Cylon battle cry from Battlestar Galactica.
We've really gone all out with the collaborations, which include 2 aluminum artisans, an aluminum knob, and even an absolutely stunning premium acrylic TKL board based on Protozoa's succesful GLITCH/FROST line.
This set is expected to ship Q2-Q3 2022.
276881-2
Command is currently in group buy, available from these vendors:
Pricing
276895-3
276883-4
Renders
276897-5
276899-6276901-7
Whimsy by PRKNS
276903-8
276905-9276907-10
Conone 80 by KindaKeyboards
276909-11
276911-12276913-13
Boop 65 by Biip
Kitting
Command comes in 15 different kits (2 alpha kits, 3 modifier kits, numpad, spacebars and 8 international kits). It features a unique design with a simple color palette (RAL 3020 and RAL 9005). The Modifiers kit includes some extra keys so it can be used to deck out 2 boards (if you get 2 alpha kits). Caps are matte (not shiny).
276915-14276917-15
276919-16
276921-17
276923-18
276925-19276927-20
276929-21276931-22
276933-23276935-24
276937-25276939-26
276941-27276943-28
Samples
276945-29
Keyreative was kind enough to provide me with a full set of samples. The colors are absolutely stunning and the legends crisp, but let's dive into some of the obvious issues, and how I'm planning on making this one of the highest quality keysets out there.
ALIGNMENT OF LEGENDS
These are just samples, and a first round of them too. No alignment efforts were made during the production of this first set. Good news: These legends are super easy to align because they're all pretty much a rectangle.
BLUE-ISH TINT
Depending on how the light reflects off the caps, you can kinda see a blue-ish tint. Keyreative is working on this (it's caused because of the pigments they use), and if that doesn't work, I'll slightly tweak the color so it's closer to black. Worst case scenario, there might be a reddish tint in the black.
FADING AROUND THE HOMING BARS
You might've seen this issue on some other KAM sets, but sadly there isn't a good solution for this. So instead of having homing bars for Command, I asked Keyreative to create a scooped 1u KAM mold instead (something they don't have today). This won't have the discoloring issue, and provides the tactile feedback you need to know your hands are in the right position.
276885-30
The Protozoa Command TKL is a premium acrylic board produced by Protozoa. It's based on their successful line of GLITCH/FROST boards. The colors match Command, and it comes with a custom-engraved top plate and solder PCB with custom screen printed artwork which supports a knob in the top right corner.
SPECS
  • CNC stacked plastic case
  • CNC milled polycarbonate bottom
  • Silicone sandwich mount
  • Custom silicone pad foot
  • Silkscreened PROTOZOA x MVKB solder PCB (included, supports a knob)
  • Fits cftkb's Mysterium PCBs, or other Protozoa Mysterium based PCBs.
  • Colors: Fire or Dark
  • Weight: ~2.6 kg (~5.73 pounds)
  • CNC Polycarbonate (frosted) plate with universal layout (ANSI + ISO)
Note: Renders show an ANSI plate and hotswap PCB; actual TKL will include an ANSI+ISO plate and solder PCB (supporting split backspace, split right shift, Tsangan or ANSI bottom row, ISO, switch or knob top right). Board will also include an encoder for the knob. Knob not included.
276947-31
276949-32
276951-33276953-34
276955-35276957-36
276889-37
Milled from aluminum and bead blasted for a matte finish. The vents are filled with resin as dark as outer space. Produced by Protozoa, these come in a 1u (escape key) and 2.25u (return key) version. The shape is custom but matches the profile of KAM caps.
276959-38
276961-39276963-40
276887-41
Aluminum milled knob for your knob needs. Engraved and resin filled top with Command symbols. Two piece design with hotswap screwless exterior. Includes both red and black outer grip o-rings.
Produced by Protozoa. Render by Alex Sailer.
276967-42
276965-43
2 premium quality deskmats, 900x400mm, 4mm thick.
276969-44
276971-45
276893-46
« Last Edit: Wed, 10 November 2021, 07:05:14 by mvkb »
Offline mvkb
  • Designer
    • MVKB
Re: [GB] KAM Command
« Reply #1 on: Mon, 04 October 2021, 08:16:27 »
[Reserved for updates]
« Reply #2 on: Mon, 04 October 2021, 09:54:31 »
Approved :thumb:
Offline _IanOfEarth
« Reply #3 on: Mon, 04 October 2021, 11:45:25 »
What's the best mailing address for my wallet?
Offline ravermeister
« Reply #4 on: Mon, 04 October 2021, 11:48:36 »
I would add how the finish is. Atleast in the IC thread you mentioned it's the same as KAM Wraith (matte).
Offline mvkb
  • Designer
    • MVKB
« Reply #5 on: Mon, 04 October 2021, 13:19:00 »
Will add!
Offline cthalupa
« Reply #6 on: Mon, 04 October 2021, 18:06:29 »
Uniform profiles aren't my thing, but this is an excellent set and the amount of work you've put into it, down to the details in the IC and GB is astounding. Best of luck!
Offline adi
  • adi.kbds; Consider ePBT Fruit Chew
    • Adi Nikumbh
« Reply #7 on: Wed, 06 October 2021, 23:29:41 »
The pure effort that was put into this set... well done man.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #8 on: Fri, 08 October 2021, 14:41:51 »
Edit: revised scale
« Last Edit: Thu, 05 January 2023, 20:37:31 by dvorcol »
Offline dvorcol
« Reply #9 on: Tue, 12 October 2021, 12:43:02 »
More vendors just updated.
« Last Edit: Tue, 12 October 2021, 14:42:51 by dvorcol »
Offline dvorcol
« Reply #10 on: Tue, 12 October 2021, 14:42:17 »
Edit: revised scale
« Last Edit: Thu, 05 January 2023, 20:37:39 by dvorcol »
Offline dvorcol
« Reply #11 on: Sat, 23 October 2021, 19:22:10 »
Edit: revised scale
« Last Edit: Thu, 05 January 2023, 20:37:46 by dvorcol »
Offline mvkb
  • Designer
    • MVKB
« Reply #12 on: Mon, 01 November 2021, 18:44:46 »
3 days left, numbers looking good (expect a Dvorcol graph soon), full hearts, can’t lose.
277974-0
Offline dvorcol
« Reply #13 on: Mon, 01 November 2021, 19:23:53 »
Edit: revised scale
« Last Edit: Thu, 05 January 2023, 20:38:13 by dvorcol »
Offline mvkb
  • Designer
    • MVKB
« Reply #14 on: Wed, 03 November 2021, 22:52:01 »
Final day, last chance to get your order in!
278027-0278029-1278031-2
Offline dvorcol
« Reply #15 on: Tue, 09 November 2021, 22:16:50 »
<-- without extras
Offline mvkb
  • Designer
    • MVKB
« Reply #16 on: Wed, 10 November 2021, 06:54:55 »
Just a quick note to thank everyone who supported this project. Well over 500 base kits, over 100 TKL's, tons of artisans and knobs... I personally had a ton of fun with the renders and general theme of this set. Already pinged Keyreative to kick off another round of samples, and a lot of the collaborations have already been ordered. On to the next one!
Offline dvorcol
Re: [GB] KAM Command (GB is over)
« Reply #17 on: Thu, 06 January 2022, 14:21:56 »
Keyreative shared their estimated KAT/KAM production schedule - https://en.zfrontier.com/blogs/project-updates/keyreative-keyset-progress-report
Offline mvkb
  • Designer
    • MVKB
« Reply #18 on: Thu, 06 January 2022, 14:30:23 »
Thanks for putting this together! Keyreative's estimates look safe and not overly optimistic, so I have a good feeling they will hit these dates (or at least close to it).
Offline mvkb
  • Designer
    • MVKB
« Reply #19 on: Mon, 21 November 2022, 01:32:38 »
Current queue from Keyreative: Lil Dragon (in production), Soaring Skies (in production), command (planning done, injection ongoing, dye-subbing in mid Dec, should finish in Jan)
Offline mvkb
  • Designer
    • MVKB
« Reply #20 on: Thu, 05 January 2023, 16:00:17 »
Latest update from the factory. There were some additional delays because of the massive Covid outbreak they're currently suffering from.
Production for command is expected to finish by the end of the month. Official CNY holidays are 21-27 Jan. So the very end of Jan or early Feb.
Offline William_S_Jones
  • Best Prime Ever!!!
« Reply #21 on: Sat, 07 January 2023, 22:08:18 »
Thanks for the update, I'm looking forward to receiving my kits!
Sent from my SM-G998U using Tapatalk
Offline mvkb
  • Designer
    • MVKB
« Reply #22 on: Fri, 03 February 2023, 14:41:14 »
Keyreative is in the process of QC'ing and packing Command right now. They've really come through these past couple of months, and I've been enjoying their transparency and progress. Give them a follow on Instagram if you haven't yet.
« Reply #23 on: Sat, 11 February 2023, 21:47:52 »
Thanks, I appreciate you.
Offline mvkb
  • Designer
    • MVKB
« Reply #24 on: Thu, 16 March 2023, 15:42:40 »
Keycaps are ready to be shipped out to vendors. People who ordered should be receiving them soon, they also have extras up already.
Offline Ranker2
« Reply #25 on: Fri, 17 March 2023, 03:55:18 »
Which sites have extras up?
Offline mvkb
  • Designer
    • MVKB
« Reply #26 on: Fri, 17 March 2023, 05:32:32 »
So far only zFrontier.
Offline Ranker2
« Reply #27 on: Sun, 19 March 2023, 22:07:29 »
Got a link?  I looked on zFrontier's site but didn't see any preorders or extras listed
Offline mvkb
  • Designer
    • MVKB
« Reply #28 on: Mon, 20 March 2023, 14:23:06 »
Hmm strange. Someone on my server showed off a set. Maybe it was what they ordered during GB?
Offline mvkb
  • Designer
    • MVKB
« Reply #29 on: Wed, 19 April 2023, 16:29:14 »
Some photos of the artisans:
298459-0298461-1
Offline AuthenticDanger
« Reply #30 on: Wed, 10 May 2023, 16:56:41 »
Are the keycaps lost at sea? Haven't seen any news about shipping since mid-March.
F Keys belong on the left.
Offline mvkb
  • Designer
    • MVKB
« Reply #31 on: Thu, 11 May 2023, 02:56:56 »
Depends on your vendor, but most are still waiting for the keycaps to arrive. Sea shipping is quite slow sadly.
Offline CosminOance
  • 'tis the season to be yourself
    • PixelDrama.club by Cosmin Oance
« Reply #32 on: Thu, 31 August 2023, 05:40:42 »
Just received mine. I had forgotten about them twice :) So it was a nice surprise.
