Author Topic: mstone Gold Springs 1 stage, 2 stage and 3 stage  (Read 8843 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Fri, 08 October 2021, 03:40:12 »
Out of every switch component, the spring is perhaps the most instrumental in creating a switch’s individual feel. No matter what your preference is, mStone’s custom gold-plated switch spring line has the fine-tuned, high-performing feel you’re after. Durable and consistent, each spring is made from stainless steel and gold-plated for extra corrosion resistance. Available here are five spring styles—15-millimetre springs, 18-millimeter long springs, 22-millimeter extra-long springs, 23-millimetre symmetric long springs, and 20-millimeter dual-symmetric springs. Springs with the symmetric design feature a tighter mid coil, while dual-symmetric springs have two tight mid coils. Individually packaged in 70-count, 90-count and 110-count packs, all spring styles are available in a variety of weights ranging from 35 grams to 80 grams.
SPECS
  • Manufacturer: mStone
  • Count:  individually packaged
  • Material: Gold-plated stainless steel
  • Lengths: 15 mm, 18 mm, 22 mm, 23 mm (symmetric design), 20 mm (dual-symmetric design)
Weights: 35 g, 40 g, 45 g, 50 g, 55 g, 62 g, 67 g, 75 g, 80 g[/li]
[/list]
Purchase
1 stage  springs
2-stage and 3-stage springs
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: mstone Gold Springs 1 stage, 2 stage and 3 stage
« Reply #1 on: Fri, 08 October 2021, 03:41:04 »
Offline hussar_name
« Reply #2 on: Sat, 08 January 2022, 02:39:40 »
2 stages springs, are usually a lie. This has been proven for the world renowned Sprit springs
