Author Topic: 【IC】NuPhy TES68 Switch Tester Kit  (Read 7678 times)
Offline harryke
« on: Fri, 08 October 2021, 05:19:29 »
A switch tester kit of great value. TES68 is hot-swappable and supports both Bluetooth and 2.4G wireless connections. It is powered by two AAA batteries and does not allow a wired connection.
Based on the prototype provided by CIY, we injected NuPhy’s design capability into TES68 with the mission of creating the most cost-effective product for our customers.
Works page: https://nuphy.com/blogs/works/tes68
Product page: https://nuphy.com/products/tes68
All kits include:
1 x 65% ABS case
1 x Aluminium plate
1 x Silicon dampening pad
1 x Hotswap PCB, Bluetooth 5.0 & 2.4G (125hz) support
3 x 2u + 1 x 6.25u Plated mounted stabilizers
4 x Silicon feet
1 x 2.4G receiver
We hope that TES68 will encourage people to make use of their extra switches and keycaps. Once connected to the switches and keycaps of your choice, TES68 can be used as a keyboard.
Note: This kit does not include mechanical switches and keycaps. Please purchase the switches or keycaps you want to test, separately. The switches and keycaps in the photos are for display only.
Feel free to leave suggestions and questions.
IG: https://www.instagram.com/nuphy.studio/
Discord: https://discord.com/channels/864389832829567067/
Offline NotYeMK
  • I will yeet your keyboard
Re: 【IC】NuPhy TES68 Switch Tester Kit
« Reply #1 on: Fri, 08 October 2021, 06:58:58 »
It seems more like a wireless keyboard that could be used as a switch tester tbh. I really can't see how it is more of a switch tester than it is a wireless keyboard. It makes me wonder what really is the line between a switch tester and a functioning keyboard. But whatever. Looks nice, though.
Offline growler
« Reply #2 on: Fri, 08 October 2021, 07:43:03 »
How affordable is affordable?
Sent from my SM-G980F using Tapatalk
Don't just stare at it ...
Offline Neely_12
« Reply #3 on: Fri, 08 October 2021, 07:59:47 »
If the 19.95 price tag on the website is correct, this is an absolute steal. Would like to see a darker blue color or a purple. Good luck!
Offline o3okevin
« Reply #4 on: Fri, 08 October 2021, 09:15:16 »
is this programmable?
Offline Volny
« Reply #5 on: Fri, 08 October 2021, 10:00:00 »
This reminds me of the time I was tired and wanted to sit down, so I went to the Toyota shop and bought a four-pack of seats.
Offline growler
« Reply #6 on: Fri, 08 October 2021, 10:03:46 »
Yeah, I'm an idiot.  20 bucks, it's a deal, it's a steal!
Offline piit79
« Reply #7 on: Fri, 08 October 2021, 12:57:19 »
Say what? Plastic case with a hotswap BT PCB for $20?
Yeah, that's nonsense.
Offline mikestah
« Reply #8 on: Thu, 14 October 2021, 15:09:24 »
Any clarification on price? $20 for an alu plate, wireless pcb, case and more seems way too good to be true. A wallet on the same site is 10 bucks more lol
Offline akingcool
« Reply #9 on: Thu, 14 October 2021, 20:40:31 »
This was SO close to being a massive hit for me, the lack of a wired connection and need for AAA batteries is a no-go. Unnecessarily adding to the world's battery waste...
