Author Topic: [IC] 32-Bit Build Deskmats  (Read 17416 times)
Offline retoid
« on: Fri, 15 October 2021, 21:33:54 »
GB Thread Here
Hello, I am retoid of BKM Caps. Thank you for checking in on the deskmat that I have put together!
Pixel art has been a hobby of mine for some time now and I really wanted to design something that would fit into the keyboard community.
I really hope you enjoy the design.
In the artwork you will see several of the components and tools often used when building a custom mechanical keyboard.
Navy
Render by MrBingo
Clay
Render by MrBingo
Aged Olive
Render by MrBingo
Red
Render by MrBingo
Interest Check Form
Specifications:
Size: 900mm x 400mm
Thickness: 4mm
Stitched edge
Standard Non-Slip Bottom
Rough Textured Fabric Top
Vendors & Pricing:
Pricing: ~$25 USD (Price may vary for vendors outside of USA)
USA - Digital Carpentry
Canada - Ashkeebs
Europe - Candy Keys
Asia - Base Keys
UK - Prototypist
Oceania - Daily Clack
Target Dates & Updates:
Target Date for GB: July 18th, 2022
Target Date for Product Shipment: Roughly 8 weeks after GB.
October 24th, 2021: 1st sample is in production.
April 7th, 2022: 4th sample has arrived. Adjusting final color tweaks. GB soon.
May 12th, 2022: Final samples approved. Going to photos.
Social Media:
Instagram | Discord | Web
The quality of the mat and print are very important factors for me.
They will not be produced before having samples printed and having gone through a quality control check.
The design is pretty much set the way it is but I am always open to entertaining any suggestions or ideas.
Thank you very much for your interest and for stopping in :)
If you'd like to support this project and add an image to your signature, here is an image you may use. Thank you!
Code: [Select]
[url=https://geekhack.org/index.php?topic=114998][img width=330 height=120]https://i.imgur.com/aqKJ4aK.jpg[/img][/url]
« Last Edit: Mon, 18 July 2022, 17:08:48 by retoid »
Offline arq1999
Re: [IC] 32-Bit Build Deskmats
« Reply #1 on: Fri, 15 October 2021, 21:37:54 »
Reserved
Offline itsazly
    • website place
« Reply #2 on: Mon, 18 October 2021, 21:44:57 »
Yes, thank you. This is so neat!
Offline retoid
« Reply #3 on: Tue, 19 October 2021, 21:29:16 »
Thank you very much! I am very glad you like the design :)
I hope to have some updated information soon.
Offline Loquerish
« Reply #4 on: Thu, 21 October 2021, 08:40:43 »
I love how theres traces on the pcb! Did you make the pcb yourself?
Offline retoid
« Reply #5 on: Thu, 21 October 2021, 10:30:10 »
Thank you :)
It's all drawn in pixel art, including the PCB. The PCB is drawn to look like it would work but the traces to the IC are sort of random :D
Offline NovaRMK
« Reply #6 on: Tue, 16 November 2021, 20:48:40 »
How have I not seen this yet. Need.
Offline retoid
« Reply #7 on: Thu, 02 December 2021, 10:38:18 »
:D Glad you like it!
Still working on getting the colors to print good on a sample. Hopefully I will have an update soon.
Offline Arithmetics
« Reply #8 on: Thu, 02 December 2021, 13:48:01 »
imagine losing parts on this mat
Offline dankthropod
  • Formerly wariomale
« Reply #9 on: Sun, 05 December 2021, 05:19:32 »
Looks really good! I've been looking for a deskmat for my blue keyboard for a while. I think the navy version makes the cut!
KEEBS: Niz atom TKL, KBD67 Lite V2 R3 with gateron black inks
AUDIO: beyers dt 880 pros with a k3 DAC. Really want to get my hands on some sennies hurr durr six hungos
Offline retoid
« Reply #10 on: Fri, 10 December 2021, 13:59:43 »
Awesome! Thank you very much, glad you like it. Sorry for the long delay, I had a sample made up but it was not up to par, so I am having another sample made up, currently waiting for that one.
Offline maybejari
    • Honkertown Studio
« Reply #11 on: Sun, 12 December 2021, 15:11:46 »
Love the Red design!
Offline retoid
« Reply #12 on: Fri, 08 July 2022, 12:47:35 »
Group Buy date, target pricing and vendors have been added to the original post!
Going to be running Navy, Clay and Aged Olive.
Will create a new GB post when it's live.
Thank you!
Offline retoid
« Reply #13 on: Mon, 18 July 2022, 14:10:23 »
The Group Buy is live!
New GB post still waiting for moderation.
