Author Topic: [GB] GMK Hooty (Nov 1st Launch)  (Read 141787 times)
Offline sourmk
« on: Thu, 21 October 2021, 14:09:41 »
GMK Hooty
Polo by Marco
November 2021
Projected delivery date - Q4 2022 - Q1 2023
Vendors
To be linked as vendors go live.
US - Space
UK - ProtoTypist
EU - MyKeyboard
CA - DeskHero
SEA - iLumKB
OCE - DailyClack
CN - zFrontier CN - zFrontier Intl
KR - SwagKeys
Hooty is quite the grumpy little owlet, usually disgruntled, tired, generally unimpressed, and always waking up on the wrong side of the bed.
Hooty will feature low contrast and saturation doubleshot greys throughout the set and novelties, with soft, bright pink UV throughout the base and novelties. Same pink will be used as the doubleshot accent legend, and the keycaps in the accent kit. Grey keycaps and legend in the accent kit is GMK 2B. Pink and light grey are custom.
Kits
Base ($134.99 USD) and Novelties ($49.99 USD)
(Two blank relegendables, and two with printed + side-print novelties - The wonderful man that he is, Jae @Prototypist will be providing laser cut papers for the relegendables)
Accents ($39.99 USD) and Expansion ($39.99 USD)
Renders
Gunmetal daji Ocho Cuatro by juaninamilli
E-White Petrichor by Alchemist Keyboards
Pink Poly TMO V2 by funderburker
Deskmats
Standard cloth tops, 900 x 400 x 4mm with black stitching
Sleepytime Hoot & Hootweave ($19.99 USD)
Collaborations
HIBI
Grey Hooty Hibi ($38.00 USD) Dual level milling (like GMK Pono cap), with pink enamel infill. Geo Hoot Hibi ($56.00 USD) Brass + rose gold PVD, third in the geometric brass animal series (to match GMK Pono and ePBT Ivory)
Space Cables
Cerakote color matched coiled aviator ($70.00 USD) - Straight grey cable ($30.00 USD)
Gateron Hooties Going on pause for the moment
Nylon housing, POM stem, No factory lube, 5-pin PCB mount, 63.5g stainless steel spring (15mm length)
Thanks to Marco for the lovely renders, and patience
Discord linked in signature if you'd like to stay up to date with this and other projects.
Cheers!
« Last Edit: Tue, 09 November 2021, 12:27:43 by sourmk »
Some Work: GMK Wasabi | GMK Pono | GMK Dandy | ePBT DuO | GMK Hooty | Petals Sixty
Some Collabs: ePBT Ivory | GMK Deep Navy | GMK Fundamentals | GMK Polybius | GMK Blurple | GMK Deepwell | GMK Fuji | GMK Pacific
Some Boards: Daji Seis Cinco, Ocho Quattro, Seis Cero | MatrixLab 2.0 ADD + CP, 2.0 Xmas + CP, 1.2OG | Keycult 1/60 | Hiney Ladybird | QXP | Noxary 268.2
Discord - https://discord.gg/j3PxfJ4rBC | Instagram - https://instagram.com/sourmk | Web - https://www.sourmk.com/
Offline sourmk
Re: [GB] GMK Hooty (Nov 1st Launch)
« Reply #1 on: Sun, 31 October 2021, 14:28:41 »
Reserved for updates.
Not long before going live! :thumb:
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #2 on: Sun, 31 October 2021, 17:00:32 »
Another banger! :thumb:
Offline HappyB0T
  • I'm a Piggie
« Reply #3 on: Mon, 01 November 2021, 02:45:30 »
How do I not all in this set?
Offline Qarmaa
« Reply #4 on: Mon, 01 November 2021, 05:40:30 »
Hooty hype!
Offline kk73715
  • Why are you even reading
« Reply #5 on: Mon, 01 November 2021, 09:03:39 »
WOOOOOOOOOOOOOOO
Offline sourmk
« Reply #6 on: Tue, 02 November 2021, 06:21:52 »
All vendors are live! :cool:
Offline sourmk
« Reply #7 on: Mon, 08 November 2021, 16:55:50 »
Hello all. Checking in for a quick update. The switch collab will be going on pause for now. The thought for the moment is that these might run again closer to ship date. Sorry to those that wanted to support the idea, I feel I have let all you down for the moment but, I do hope to bring these back a little later on. Normal procedure for refunds from vendors will proceed. Cheers and sorry.
Offline CookieFlow
« Reply #8 on: Sun, 28 November 2021, 08:06:46 »
Do you have an update on this?
They show as available in the EU, UK and Australian vendor so I am confused.
Offline sourmk
« Reply #9 on: Sun, 28 November 2021, 13:03:46 »
Refunds for the switches will begin going through after the buy has concluded, same as any other refund procedure :thumb:
Offline CookieFlow
« Reply #10 on: Sun, 28 November 2021, 14:19:32 »
Understood, but maybe I worded myself poorly.
IllumKB, MYK, Prototypist and Dailyclack still allow you to purchase the Switches. It seemed easier (to me at least) to remove them, instead of letting people still purchase them, only to refund them after the GB is over.
Especially since not everybody reads the GB Thread so they might be disappointed.
I hope they will return in the future, would love them to finish my Hooty builds  :thumb:
I hope the set is doing well, it really deserves it  :thumb:
Offline sourmk
« Reply #11 on: Mon, 29 November 2021, 09:36:33 »
Hmm, well I don't run a vendorship or sales site myself, to be quite honest, so I'm not entirely sure what the easier process for them is. This is the information I was passed (that refunds go out after conclusion - it's usually how this happens.) and passed that along myself.
As far as communication, it was also announced in my server, suppose could have done a little more to communicate, but it's not something I'm very happy about tbh.
They will be back soon though, there were some internal details that we couldn't work out in time unfortunately. Will be sharing more info when everything is ready!
Appreciate your nice words and support very much though!
Offline sourmk
« Reply #12 on: Tue, 30 November 2021, 12:41:33 »
Last day all! Thank you for your support and love!
Space and myself are hosting a giveaway on Instagram - One base kit + supporting kit of your choice - from each of us.
Hope to see you there!
Cheers!
« Last Edit: Tue, 30 November 2021, 12:43:11 by sourmk »
Offline hussar_name
« Reply #13 on: Tue, 30 November 2021, 12:43:47 »
I don't know... for what I know, korean doubleshots looked quite good.
Offline mmayhem17
    • Steam profile
« Reply #14 on: Mon, 13 December 2021, 03:35:25 »
Do you have an update on final numbers?
Offline MSA_Vision
« Reply #15 on: Fri, 24 February 2023, 19:00:41 »
Any update?
Sic Parvis Magna
Offline udller
« Reply #16 on: Sun, 21 May 2023, 09:41:17 »
which site should i check to see an eta of this?
Offline sourmk
« Reply #17 on: Mon, 22 May 2023, 11:54:30 »
My site (linked in signature) has not been updated yet though :p
Space's site is also a good reference :thumb:
Offline sourmk
« Reply #18 on: Mon, 31 July 2023, 01:28:04 »
Hi!! The Hootster has started arriving on some lucky peoples' desks.
Figured I would get in here quick and let you know that there is small visual difference with the single pink used in the set.
Pink was as a legend accent on some caps, so these are doubleshot, pink was also used as the subs legend color, these legends are UV.
So basically, there is a small difference in the saturation / vividness of the pink when compared from the doubleshot accent caps, to the UV printed sub legend.
While I haven't seen this in person yet, it doesn't make the set unusable or anything dramatic like that, but I understand this might disappoint some people.
Waiting for replies and information. Please continue to be patient, while we see what's what. I thank you :thumb:
Offline ABlazinBlueToe
« Reply #19 on: Wed, 06 September 2023, 14:17:07 »
I would love to see some photos, can't find any online yet.
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #20 on: Wed, 06 September 2023, 14:36:13 »
Try looking around at pictures of the melbourne meetup and see if you can find an image of the swtichkeys stand ok it might not have been that stand but one member of the aussie mech community showed me it and I believe he said hooty. I'm pretty sure it was hooty but maybe I'm misremembering.
The colours seemed to match but because of the uv printing of the sublegends, the sublegends are far less saturated than the doubleshot pink which may a bit disappointing but is expected if you know about uv printing on gmk.
« Last Edit: Wed, 06 September 2023, 14:37:52 by Rhienfo »
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline bigmaxnonions
« Reply #21 on: Thu, 07 September 2023, 09:11:19 »
https://www.instagram.com/reel/CvzQQFdsl4O/?igshid=MzRlODBiNWFlZA==
Hibi posted some typing tests on Instagram, you can kinda make out the sublegends and they do look a little off.
This video was also posted on Sour’s discord.
Hope these help! I can’t wait to see the shipping notification from Space Cables.
Offline Rhienfo
« Reply #22 on: Thu, 07 September 2023, 11:25:05 »
ok it was at the meetup at the hibi stand, which may be on their instagram. I was correct about what I said before as well, I found a clearer image on hibis instagram.
https://www.instagram.com/p/CvzQQFdsl4O/
this shows much better what I was talking about with the disparity of the sublegends and doubleshot.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline sourmk
« Reply #23 on: Thu, 16 November 2023, 13:25:22 »
As usual, lighting will always play a big role in how things are displayed.
Here are a few lovely photos courtesy of Captain Sterling
Should have the set in hand by next week, so not really going to judge just yet, but seems like it's pretty close to my original comment. There is a bit of a difference between in the saturation and vibrance of the pink, but it shouldn't be a really big deal or make the set unusable. Hope you might still enjoy the set, but I do understand that this deviates slightly from the original idea. I have been hearing positive comments from people who have their sets, which has put me at ease.
(previews not loading so here's a link to the instagram post in case)
Will check back in in the next week or two, cheers!
« Last Edit: Fri, 17 November 2023, 11:52:07 by sourmk »
Offline patricklau
« Reply #24 on: Fri, 17 November 2023, 03:30:00 »
so cute
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #25 on: Tue, 21 November 2023, 04:14:22 »
I am pretty happy with the set! the novelties came out nice.
Offline sncbraxsc2
  • ⭐Domesticated Dweeb⭐
« Reply #26 on: Tue, 05 December 2023, 14:15:36 »
Looking good  :cool:
Is there any intention to run this set in PBT?
Offline sourmk
« Reply #27 on: Thu, 07 December 2023, 13:28:59 »
Heyo, so set came in a couple days ago, and yeah it's fine heh.
Pink sub is a little less saturated a little less vibrant than the doubleshot.
It's not something that super stands out as a big difference.
It would have been nice if manu mentioned something about this during production, but nothing I can personally do about their insistence about not communicating with their community and customers, (maybe another go over the alphas with the pink UV might have helped). Again though, it's not something that makes the set unusable or distracting or anything like that.
Please keep in mind to see something in person before judging colors, look at it under different lighting situations, etc...
Don't let a low quality image with poor lighting conditions be your judge and jury.
Thank you all for your support <3
Cheers
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #28 on: Wed, 13 November 2024, 21:26:15 »
Oblotzky's phase 5 of MyKeyboard.eu customer support has started.  Paraphrasing his post from phase 4:
Orders of this set that were abandoned by MyKeyboard are currently being collected for previous customers first until November 19th, then the set will also be available to the public until November 27.  More info here - https://oblotzky.industries/pages/myleftovers
https://oblotzky.industries/products/gmk-cyl-hooty
« Last Edit: Wed, 20 November 2024, 16:50:24 by dvorcol »
