Author Topic: Plate choice: Aluminum vs. FR4  (Read 14882 times)
Offline ShePearl
« on: Sun, 24 October 2021, 22:18:10 »
This is with Durock Lavender (F+L) switch.
I've ordered both aluminum and FR4 plates for Frog TLK and obviously I'll be using only one of them.
Which plate do you think complements Lavender on the Frog TKL better ?
Offline Sup
Re: Plate choice: Aluminum vs. FR4
« Reply #1 on: Mon, 25 October 2021, 08:36:37 »
Alu.
current
Coming soon
Offline ShePearl
« Reply #2 on: Tue, 26 October 2021, 20:13:33 »
Mounted on aluminium.  (I'm not sure if I'll be bothered to desolder for FR4 plate)
Feels and sounds nice.
Offline Chalkboard
« Reply #3 on: Tue, 26 October 2021, 20:25:39 »
Nice countertops. Specs?
Offline ShePearl
« Reply #4 on: Tue, 26 October 2021, 21:25:38 »
Frog TKL in Harbor Grey with GMK Apollo Command Module keycaps
- Durock Lavender switch
- SPRiT MX Slow Extreme I (65g) spring
- Gateron PCB mounted screw-in Ink Black stabilizers (HOLEE mod)
- KBDfans stabilizer foam sticker
- Aluminum plate
- 80A tadpole
- Deskeys switch film (white)
- Krytox GPL105 for spring
- Krytox GPL105+205G0 Mix (7:3) for stems and bottom housing
- Krytox GPL205G0 for stabilizers
- Poron switch pad (0.5mm)
- PCB foam (3mm Poron)
- Case foam (2mm Poron)
Offline Toffee Studio
    • Toffee Studio
« Reply #5 on: Wed, 15 December 2021, 00:56:59 »
I like alu, although FR4 introduces a little bit more of that "clacky" sound signature while providing a slightly softer bottom out. Personal preference, you can always try both or try one switch  :D
Offline phinix
« Reply #6 on: Tue, 25 January 2022, 03:09:35 »
I bought POM plate for my Frog - of course it will come with standard alu plate, but was wondering which to use. I picked POM plate and soft tad poles to get nice and soft like kbd67lite feeling.
Offline vutid
« Reply #7 on: Wed, 02 February 2022, 17:05:57 »
jwks on fr4 is clack heaven
GMK Rave
Offline granola bar enthusiast
« Reply #8 on: Wed, 30 March 2022, 23:09:46 »
isnt kbd67 lite super stiff? typing on mine rn and the only flex you get is from the rubber feet compressing, are you talking about the bottom out feel?
