Author Topic: [IC] GMK Lilac on Black | Group buy live September 1st!  (Read 114714 times)
Offline Yuinth
Re: [IC] GMK Lilac on Black | Kitting Updated
« Reply #50 on: Sun, 31 October 2021, 16:47:52 »
Could you add a couple of renders with the accent spacebars and a 40s board?
Offline Sax_______
« Reply #51 on: Sun, 31 October 2021, 17:46:42 »
I will over the next few days! I also need to re-do the ones with mono katakana
Offline kylekwong1
« Reply #52 on: Sun, 31 October 2021, 18:23:09 »
I would like to see
Two base kits instead of alt alpha
Stepped cap control
Icon mod
Accent spacebar?
Move numpad to its own kit
Moving numpad to its own kit makes it ~ $50 more expensive for people that want numpad. When I joined GH the only people using numpad were legacy users on old keyboards but now there are a lot of customs that are using it.
Pretty much this, having numpad adds basically no cost, moving it to its own kit adds cost for anyone that does want it.
The sales numbers of standalone numpad is usually just 10-15% of the base kit sales numbers. This can also be because of the high price tag, but also, the amount of boards that have a numpad is small and not in high demand. Moving numpad to its own kit will make the overall price lower for most people
Offline LilithAugustus
  • She/Her
« Reply #53 on: Sun, 31 October 2021, 18:46:19 »
LOB>WOB
Offline SmitH1y
« Reply #54 on: Tue, 02 November 2021, 10:12:31 »
LOVING THIS!
Offline Sax_______
« Reply #55 on: Wed, 03 November 2021, 00:32:43 »
Update:
11/02
-Removed mono katakana renders (whoops, had forgotten about that!)
-Replaced a render with a new one showing accent space bars
I have also updated the IC form with a new question, if you already answered I would appreciate if you could go back in to answer the new question!
Offline denibhoxha
  • cock and balls technology
Re: [IC] GMK Lilac on Black | IC Form update
« Reply #56 on: Wed, 03 November 2021, 17:23:28 »
How bout this, but hangul??? It would go hard
Offline vishydesigns
« Reply #57 on: Wed, 03 November 2021, 17:35:13 »
I mean theres nothing really special about this set and the earliest we would get it is late 2023 so
Offline TyPo.mk
« Reply #58 on: Wed, 03 November 2021, 19:24:30 »
https://revolutionarypaideia.com/2011/02/03/look-inward-before-you-look-outward/
Offline XiXora
« Reply #59 on: Wed, 03 November 2021, 20:33:17 »
Just checking the NorDeUK kit from UK perspective:
swap R4 [><] for R4 [|\]
missing R4 1u AltGr key
Offline Sax_______
« Reply #60 on: Wed, 03 November 2021, 21:31:45 »
You're right actually! hadn't noticed the >< key was repeated in base kit, thanks for pointing it out.
Offline PancakeReaper
« Reply #61 on: Thu, 04 November 2021, 00:51:35 »
The renders with the accent space bars look so sick.
Any chance we'll get accent space bars for the sizes 2.25u and 2.75u? Any plans for novelties?
Offline davidhellmann
    • davidhellmann.com
« Reply #62 on: Sat, 06 November 2021, 12:07:40 »
Very interesting for my girlfriend but just with NorDe Kit cause she needs a German Iso Layout.
Is it possible to get a Render with a Lilac Mode SixtyFive with a Brass Backplate. That would be 🚀
Offline Space_Case88
  • keebs, anime, video games and coffee
« Reply #63 on: Sat, 06 November 2021, 21:01:24 »
Been waiting for something exactly like this. What a pretty set!
Offline Sax_______
Re: [IC] GMK Lilac on Black | Small fixes
« Reply #64 on: Wed, 24 November 2021, 19:34:00 »
Hey y'all, I was quiet for a bit because honestly I kinda slacked on this since my pc takes ages to render stuff.
But here we are now with some small updates, nothing major since I'm pretty happy with the current kitting.
-Revamped katakana sublegends, I noticed several of the legends were wrong so I decided to use an existing asset for them
-Made small fixes on some errors in numpad (It was missing a barred 5 and the scoop had no scoop)
-Updated renders with katakana subs to show the new sublegends
Offline XiXora
« Reply #65 on: Thu, 25 November 2021, 11:55:29 »
No chance of 1.5U Supers and extra 1u Alt to supplement then? Oh well :(
Btw, don't forget to fix NorDeUK kit.
Offline Gvalch_ca
« Reply #66 on: Thu, 25 November 2021, 13:26:52 »
Not bad at all.
But what's the supposed base kit cost? It is huge, including some short spacebars, accent keys for everything including ISO, 40s support, and numpad. Looks like 140$ base to me. Maybe removing numpad from the base kit is a good idea, but you should consult with GMK about the actual price first.
Lead Keyboard Cringeneer.
Alps and Space Invaders enthusiast.
Offline lunatictaco
« Reply #67 on: Sun, 28 November 2021, 15:00:22 »
40s and specialties kit would be great!
Offline Sax_______
« Reply #68 on: Tue, 30 November 2021, 00:37:21 »
Thanks for reminding me about the NordeUK kit, almost forgot to fix it entirely, should be corrected now.
As for the 1.5u super and extra 1u alt, I tried to find a way to fit them into the kitting, but the base kit is already a bit too big and my only other option would have been an extension kit, however there just isn't enough interest currently for an extension kit.
Offline meberko
« Reply #69 on: Wed, 05 January 2022, 00:07:37 »
Wow, I've been saying for a long time I would only brave the crazy GMK lead times for a set I absolutely love.
This is that set.
Offline konstantin
  • Formerly constexpr
« Reply #70 on: Wed, 05 January 2022, 15:39:47 »
The base kit is missing R3 PgUp, R4 PgDn for 65% support.
Accent-colored R2 Esc is not a necessary key and can be removed from the base kit.
On a similar note, I suggest moving accent arrow keys to the spacebars kit to help keep the cost of the base kit down and make room for more important keys.
The R1 -_ホー key in the alt alphas kit is missing the ー sublegend in the top right.
« Last Edit: Fri, 05 January 2024, 08:42:02 by konstantin »
Offline novelflyer
« Reply #71 on: Tue, 22 March 2022, 16:59:42 »
Any updates on this?
Offline MSA_Vision
« Reply #72 on: Fri, 25 March 2022, 19:29:49 »
I think they’re waiting on quotes from the vendors.
Sic Parvis Magna
« Reply #73 on: Fri, 20 May 2022, 16:02:43 »
This is the last group buy for GMK I'm likely ever going to get again. So tired of waiting for all the sets. I have like 6 sets I haven't received for over a year. I will wait for this one though. It's beautiful.
Offline Daesya
  • 💜 purple supremacy 💜
    • social mediass
« Reply #74 on: Tue, 05 July 2022, 14:31:43 »
I'll have 10 of these 💜💜💜
Actually it would be nice if the short spacebars were lilac as well for more contrast !
« Last Edit: Fri, 08 July 2022, 05:53:49 by Daesya »
Offline Sax_______
Re: [IC] GMK Lilac on Black | Hibi added
« Reply #75 on: Thu, 04 August 2022, 15:08:29 »
Hey ya'll, small update, a Hibi has been added for the set and the group buy will be sometime in September
Offline meberko
« Reply #76 on: Tue, 16 August 2022, 09:58:50 »
Holy crap so excited!!! Will try to be the first to enter the GB  :D
Offline Sax_______
Re: [IC] GMK Lilac on Black | Group buy live September 1st!
« Reply #77 on: Fri, 26 August 2022, 17:21:18 »
Yo, set is alive, group buy next week :)
Offline lonewolf4
« Reply #78 on: Sun, 28 August 2022, 06:35:31 »
Hey is it too late to add one key? All it's missing to support ISO-PT is the "Ç"
Offline Sax_______
« Reply #79 on: Sun, 28 August 2022, 12:23:39 »
Way too late unfortunately, that would require getting new quotes for the entire set.
