Author Topic: Are these Tai-Hao keycaps defective?  (Read 4201 times)
Offline dman777
« on: Fri, 29 October 2021, 09:30:30 »
I bought the ABS-Cubic Profile Translucent Backlit from tao hao https://shop.tai-hao.com/products/abs-104-t31bk101.  This is for my Ducky Shine 7.
For the bk101, the keys sit higher than my other keys. They are the same size as my other keys, but I think the stem is incorrect and makes the key sit higher. Are they defective? I have other styles of these types of key caps like https://shop.tai-hao.com/products/abs-104-t31bu301 and I do not have this issue.
https://imgur.com/a/l9LoS3f
https://imgur.com/XG4BdPV
Offline Neptune Keys
Re: Are these Tai-Hao keycaps defective?
« Reply #1 on: Sun, 31 October 2021, 07:29:37 »
Not sure about that. Maybe you should contact taihao to ask.
