Author Topic: [IC] EPPic board | 58 key split keyboard | Ergonomics, Productivity, Portability  (Read 3644 times)
Offline willem-jan
    EPPic board
    Design philosophy:
    • Highest possible Ergonomics
    • Ultimate Productivity
    • Easy Portability
    277981-0
    277984-1
    Specs:
    • Ergonomic column stagger, optimized in many design iterations
    • 58 keys with 3+2 keys on thumb cluster
    • Smaller vertical spacing then MX for less finger travel
    • Kaihl Choc tactile switches
    • Low profile for improved portability without compromising ergonomics and tactility
    • 3 layer QMK with Qwerty or Colemak DH as default
    • USB-C left and right
    • No RGB LEDs, displays or other useless gimmicks
    • With or without (default) aluminium casing
    • Quick availability
    Let me know what you think! All feedback, tips and comments welcome. In case of significant interest we will initiate a group buy.
    Google form: https://forms.gle/qBCyBUsiQMzfoZCk6[/list]
    « Last Edit: Tue, 02 November 2021, 06:37:25 by willem-jan »
    Offline Mecxs
    What is the price?
    Offline willem-jan
    The price is not determined yet as that is highly depends on the interest (and hence the batch size), but we aim to make this as affordable as reasonably possible. Once we have a feeling for the interest we can determine the batch size and target cost. What do you think about the design if I may ask?
    « Last Edit: Tue, 02 November 2021, 06:00:59 by willem-jan »
    Offline P103
    Having a google form would help gauge the interest better.
    I think it needs a case of some sort. I would not be comfortable with an exposed PCB. At the very least provide the customers with a copy of the layout and board dimensions in SVG or DXF format so that they could get something made themselves.
    Some existing "cases" out there have just a cover over the controller and a bottom plate. The PCB may need mounting holes for standoffs. The best would be if the case had a built-in tenting mechanism.
    Offline willem-jan
    Thanks for your feedback!
    I also added a Google form.
    Offline ReesMogg
    Feel free to come and share with the Low Profile Keyboards Discord: https://discord.gg/dMNgkqF4
    Offline willem-jan
    Thanks, will do!
    +also thanks for all the usefull feedback we got via the Google form. Preliminary conclusion is that there is some serious interest and than an optional alu case might be a good idea.
