Author Topic: 【GB】Wind x -intesting layout keyboard  (Read 3221 times)
Offline windlabs
« on: Sun, 07 November 2021, 21:27:47 »
Wind.X
Hello Geekhack,
We are Wind Studio from China
Wind series:
Soldered
Hotswap
The major difference is it allows for a 2U 0 key, which is very important to dozens of people, especially if you're used to typing 0 with your thumb. And then there are those that meet the requirements like Austin.
First of all, let's talk about the theme, simple appearance and enough sincerity of the internal structure optimization, I believe that is "interesting soul pick one in ten thousand, nice-looking  is the same".
The appearance is very simple, and very durable. The front arrow keys on the top and back of the strip out of the strip are brass weight
So the looks very simple, but what is the feature of this kit?
First of all, the kit is a three layer structure.
To allow for a sleeker look than the conventional three-layer structure, we adopted the design of the bottom case and the middle has a gap in between top and bottom. The silver waist line in the picture is part of the bottom case .
The plate is sandwhiched bottom case and the top case, and then the middle frame is fixed to the top frame to achieve this effect.
note:The plate has cut outs that supports the ability to remove stabs without complete disassembly,it is friendly to somebody new to this hobby.
Because it is a big layout, so we use the split plate and PCB.
This is done to maximize the Gasket experience. Originally, we planned to learn the popular large flex cut plate and PCB, after proofing, we found that such a long cut PCB would lead to the consistency of typing is poor, the middle will be very soft, and the harder it will be towards both sides. It was soft but it sacrificed too much consistency. So we changed the design.
The newly designed slotting method can achieve a relatively balanced state in soft projectile and feel consistency. It's a way that works for most people.
we also changed the original plate thickness from 1.6mm into 1+0.5mm, that is, 1mm plate (POM,  carbon fiber) and 0.5mm ixpe pad . The advantage of this is that when the switch is pressed, the switch will put pressure on the pe pad in the first time. The reason why we adopted the hardness of 40 is that the hardness of 40 is relatively neutral, which can be of great help in the consistency of resilience.
we have one more layout question to address:
we will use two kinds of PCB (soldered and hot swap) (there will also be two kinds of plates). The soldered version can be compatible with large layout (recommended), but the hot swap version cannot be compatible with large layout, because the fixation of large keys and the easy disassembly of stablizer axis need to be considered, so hot swap can only be compatible with one kind of layout. (QMK&VIA)
All that's left is some basic information.
Material: 6063
Weight: brass (transparent electrophoresis)
Angle: 7 °
Fixed mode: Gasket
Board kit:
1x Keyboard case
1x PCB
1x JST daughterboard
1x POM plate or carbon fiber plate
1x PE plate pad
1x 3.5mm Poron plate foam
1x PE PCB pad
1x PCB foam
1x Bottom case foam
1x Rubber bumpons kit (4x)
1x screw kit
1x gasket foam
color:
Anode: ano black , ano silver, ano gray, ano orange  (1655C),ano red  (186C)
Electrophoresis: e white, e yellow(136c, e pink(495c), e green (566c)
Where: Windstudio
How:
Instock:200sets(e-white+e-yellow 80 sets,ano black+ano orange 60 sets,ano black+ano silver 60 sets)
GB: 300 units( no color limit, but only fixed combinations can be selected)
Price: standard:298 usd
When: November 10th 8am (Beijing time) or November 9th 8pm EST to december 10
Expected Delivery For instock immediately after GB, and 3-5 months for GB (2 month due to recent power shortages)
Videos:
more pics:
https://sterlingcophotography.pixieset.com/windlab/
discord
update history:2021.09,28  IC
                       2021.10.01 update more pics
                       2021.10.21 update more GB color details
« Last Edit: Sun, 07 November 2021, 21:44:58 by windlabs »
Re: 【GB】Wind x -intesting layout keyboard
« Reply #1 on: Thu, 11 November 2021, 09:50:07 »
Approved :thumb:
