Author Topic: [IC]GMK Camping r3 (GB is live!)  (Read 41242 times)
Offline Krastoff
Re: [IC]GMK Camping r3 (GB starts from Dec. 1st, tons of updates)
« Reply #100 on: Wed, 01 December 2021, 12:45:47 »
There are R4 Pgdn and R3 Pgup in a lot of your renders, will you add these to the base kit since they're not there atm?
I didn't notice this, I'll talk to the vendors once the GB is concluded and see if it's possible to add 2 more keys to each base.
+1
Why talk to the vendors only after the GB is concluded though?
Offline heyimpanda
« Reply #101 on: Wed, 01 December 2021, 15:21:49 »
+1
My (relatively uneducated) guess is that adding those two keys would affect the price, so it's likely they're waiting to see if final numbers are high enough that a larger order would offset the price increase for those two keys. Just my guess based off other sets including extra keys based on final numbers after the GB had concluded (Cafe and Metaverse R2 come to mind)
Offline kingnestea
« Reply #102 on: Thu, 02 December 2021, 00:44:03 »
+1
correct
Offline kingnestea
Re: [IC]GMK Camping r3 (GB is live!)
« Reply #103 on: Thu, 02 December 2021, 00:45:32 »
I'm locking this thread as GB is live, pls move to the GB thread https://geekhack.org/index.php?topic=115502.0
