Author Topic: [GB] GMK Dracula V2.0 — GB Closed (Shipping)  (Read 28358 times)
Offline pikku-allu
  • IG: @kinnalek
« on: Wed, 10 November 2021, 20:31:51 »
$ gmk install -g @dracula/main-core
$ gmk install -g @dracula/nightmode-core
$ gmk install -g @dracula/git-core
$ gmk install -g @dracula/extension-module
$ gmk install -g @dracula/ligature-module
$ gmk install -g @dracula/highlight-module
$ gmk install -g @dracula/whitespace-module
$ gmk install -g @dracula/err-module
$ gmk install -g @dracula/minify-module
$ gmk install -g @dracula/command-module
$ gmk install -g @dracula/macro-module
$ gmk install -g @dracula/localization-module
$ gmk run deploy
Starting 'deploy' ...
> Uploading: geekhack/group_buys/gmk-dracula-v2/master.tar.gz
> [=============================] 100% 0.0s
> Initializing GB ...
> Starting 'intro' ...
> README.md
Introducing GMK Dracula V2.0! Now back for a second run with new kits and accessories!
The keycap set adapts the popular color-scheme of the same name, Dracula, designed by Zeno Rocha. Contrary to what you might think based on the name, this is not a Halloween themed set per se. Instead, GMK Dracula (V2.0) focuses on the software and coding aspect of the Dracula Theme. The colors of the set are dark greyish blue tones with blue-purple-gray alphas. The iconic multicolored syntax highlighting of the Dracula Theme is included in the form of vibrant pastel and neon legends and accents.
There has never been a set with so many different options to choose from, whether you already have V1.0 or not. Check out what's new!
Render of TGR Jane V2 CE (black) w/ GMK Dracula V2.0 Main Core + Highlight Module
[Render of TGR Jane V2 CE (black) w/ GMK Dracula V2.0 Main Core + Highlight Module]
> Configuring distribution ...
▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ DRACV2.0_Dist.txt ▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓
├── GB_vendors/
│ └── proxy_list/
│     ├── US --
Omnitype ---------- [LINK]
│     ├── CA --
Deskhero ---------- [KEYCAPS][MATS]
│     ├── EU --
Oblotzky Industries [LINK]
│     ├── UK --
Proto[Typist] ----- [LINK]
│     ├── AU --
Daily Clack ------- [KEYCAPS][MATS]
│     ├── SEA -
iLumkb ------------ [KEYCAPS][MATS]
│     ├── CH --
zFrontier CN ------ [LINK]
│     └── INT -
zFrontier EN ------ [LINK]
└── GB_info/
    ├── Group Buy - November 8th – December 6th 2021
    ├── Status – In Production
    └── Shipping Estimate - June 2023 https://omnitype.com/blogs/timelines/gmk-dracula-v2-0
GMK Dracula V2.0 Specifications
Version          Total Kits          Modifier Styles
2.0123
Manufacturer    Profile                    Stem
GMKCherry (1-1-2-3-4-4)MX Style
Plastic Type          Process          Thickness
ABSDouble-shot1.5mm
> Run script 'renders' [Y/N]
Renders
[w/ GMK Dracula V2.0 Main Core + Highlight Module]
[w/ GMK Dracula V2.0 Nightmode Core + ERR! Module]
ION Zenith (black)
[w/ GMK Dracula V2.0 Git Core + Macro Module]
Keycult No.1 Rev.1 (burgundy)
[w/ GMK Dracula V2.0 Main Core + Ligature Module + Whitespace Module]
> Run script 'kits' [Y/N]
Kits
[Album with all of the kits: https://imgur.com/a/BZkNaBx]
> Load package 'price-table' [Y/N]
Omnitype (USD)     Deskhero (CAD)     Oblotzky Industries (EUR)     Proto[Typist] (GBP)
Main [CORE]$114.99$150€119£88.33
Nightmode [CORE] *NEW!$114.99$150€119£88.33
Git [CORE] *NEW!$114.99$150€119£88.33
Extension [MODULE]$42.99$56€37£33.33
Ligature [MODULE] *NEW!$39.99$52€37£30.83
Highlight [MODULE]$36.99$48€35£28.33
Whitespace [MODULE]$26.99$35€27£20.83
ERR! [MODULE]$43.99$58€45£34.17
Minify [MODULE]$43.99$58€47£34.17
Command [MODULE]$27.99$37€29£21.67
Macro [MODULE] *NEW!$29.99$39€29£23.33
Localization [MODULE]$64.99$85€69£50.00
Daily Clack (AUD)     iLumkb (SGD)     zFrontier CN (CNY)     zFrontier EN (USD)
Main [CORE]$158$159₯799$140
Nightmode [CORE] *NEW!$158$159₯799$140
Git [CORE] *NEW!$158$159₯799$140
Extension [MODULE]$58$59₯299$47
Ligature [MODULE] *NEW!$54$55₯279$44
Highlight [MODULE]$50$52₯259$41
Whitespace [MODULE]$37$38₯189$30
ERR! [MODULE]$60$62₯309$49
Minify [MODULE]$60$62₯309$49
Command [MODULE]$38$39₯199$32
Macro [MODULE] *NEW!$41$42₯209$33
Localization [MODULE]$88$94₯459$73
Main [CORE]
Classic multicolored syntax highlighting of the Dracula Theme.
All dark modifiers with white legends for an incognito Dracula look! Best combined with the ERR! Module
Git [CORE] *NEW!
Git commands as text-only modifiers in classic multicolored syntax highlighting of the Dracula Theme.
Extension [MODULE]
Added layout compatibility with many additional options.
Now with ligature support! Icon modifiers to transform the style of the Cores.
Highlight [MODULE]
Bright accents in neon/pastel colors to bring extra highlight to your build.
Whitespace [MODULE]
Bright accent spacebars in neon/pastel colors + added compatibility.
> 'kits' encountered an error after 120 ms
> gmk ERR! Error: Fatal: access denied
> gmk ERR! @dracula/err-module not found
░░░░░░░░░░░░░░░░░ ERR-loader ░░░░░░░░░░░░░░░░░
├── GB/
├── .README.md
├── .DRACV2.config
├── .give-me-split-spacebars.md
├── .so-many-kits.md
└─┬ .my-wallet-hurts.md
  └─ .stop.md
ERR! [MODULE]
ERR░R█░▓▓▒░▒▓▒██RR█R!
> Starting subtask 'rebuild' ...
Minify [MODULE]
Layout compatibility and accents for various small form factor keyboards.
Command [MODULE]
What did you think it was going to be called? Layout compatibility for macOS specific keys.
Dedicated keys for different types of macro columns. Bundled with Vim arrows.
Language support for Nordic (Danish, Finnish, Swedish, Norwegian) + German & UK layouts.
> Run script 'accessories' [Y/N]
Dracula V2.0 & HIBI Keycaps
Material          Stem
AluminumMX Style
GMK Dracula V2.0 & HIBI — Box Eye
Finish                  Infill            Profile          Size
Blue Gray AnodizingBlue EnamelR1 (Escape)1u
GMK Dracula V2.0 & HIBI — Eye
E-WhiteBlue Gray EnamelR1 (Escape)1u
GMK Dracula V2.0 & HIBI — Critical ERROR!
Blue Gray AnodizingRed EnamelR3 (Enter)2.25u
Deskpads
Dracula V2.0 Eye, ERR! & Void *NEW! deskpads
Size                  Material (Top)          Material (Bottom)          Edge Finish
900x400x4mmClothRubberStitched
> Deploy complete.
« Last Edit: Thu, 20 July 2023, 12:37:51 by pikku-allu »
Offline pikku-allu
  • IG: @kinnalek
Re: [GB] GMK Dracula V2.0 — LIVE!
« Reply #1 on: Wed, 10 November 2021, 20:48:06 »
reserved
Offline HappyB0T
  • I'm a Piggie
« Reply #2 on: Wed, 10 November 2021, 22:26:34 »
Here take more of my money ;) Please design more sets <3
Offline alwaysbless
« Reply #3 on: Wed, 10 November 2021, 23:53:54 »
Baked Alice bars and night mode into base kits so now anyone from r1 has to spend hundreds to get those kits. Very naise
Offline DaaDaa
« Reply #4 on: Thu, 11 November 2021, 02:52:40 »
please consider designing and releasing more GMK sets that, like dracla v2 git base, have text only mods. the ugliest thing aqbout gmk sets is the text + icon mods or icon only (specially shift), dye sub sets have a variety in the graphics but gmk sets, mostly have the same exact text + icon and for me it has gotten really really stale. my only problem with symbiote was that. why cant u guys make new and innovative grpahics/icons for gmk sets? and if not then please consider more sets with just text.
piggy60 red upgraded PVD w/ GMK umka zaku | tiramisuit w/ GMK noire JWK silk emerald | mr.suit black/chrome glossy chamfers w/ GMK minimal cow POM stem | jelly epoch w/ SA oblivion zaku | mode80 deco w/ gmk boneyard alpaca | mode 80 imperial with ePBT origami alpaca| MODE80 viridian /w CRP boba LT | RAMA thermal kuro w/ GMK muted 2 pewter | BBox60 C64 wih marshmellows and c64 keycaps | MODE Sonnet green /w MW voynich gateron ink box pink
Offline oilpapers
« Reply #5 on: Wed, 17 November 2021, 12:30:13 »
Changing the Nightmode to a core set rather than a add-on seems like a very odd choice, going to be spending less on this than I otherwise would have.
Offline dgneo
  • Supervillain
« Reply #6 on: Wed, 17 November 2021, 12:37:30 »
> Shipping Estimate - Q4 2022
Off by a couple years methinks
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #7 on: Wed, 17 November 2021, 12:40:53 »
Incorrect
Offline Pach
« Reply #8 on: Wed, 17 November 2021, 12:48:50 »
I mean they dont have to do colormatching anymore so prob only off by like 2 years
Offline Remsky
  • Lubed switch count > Puddsy post count
« Reply #9 on: Wed, 17 November 2021, 14:39:30 »
Thats why you change the renders to match how R1 came out for R2
TGR Jane v2 - GSKT00(coming) - TGR Jane CE V2 - TGR Poly alice - LZ Physix - Matrix 8XV 2.0 - RS - LZ FE - Dalco 959 Mini GT edition (coming) - Mc65 - Hiney TKL one - HHKB Pro 1 - 25th anniversary edition HHKB pro Hybrid - 30th anniversary Filco 2S keyboard
Offline pikku-allu
  • IG: @kinnalek
Re: [GB] GMK Dracula V2.0 — LIVE! (November 8th – December 6th)
« Reply #10 on: Thu, 02 December 2021, 17:46:37 »
Added a couple of renders using the new Ligature Module and the new spacebar accent color:
Offline ChrisJoy
Re: [GB] GMK Dracula V2.0 — GB Closed (In Production Queue)
« Reply #11 on: Mon, 03 October 2022, 05:02:16 »
I was wondering how many sets did you guys sell.
Offline Mecxs
« Reply #12 on: Mon, 03 October 2022, 06:10:56 »
I bought one. I know two other guys who bought sets as well.
So at least three overall.
Offline DaaDaa
« Reply #13 on: Mon, 03 October 2022, 10:54:04 »
I bought one of git set and one of nightmode set and also some child kits. Other than the default base kit with that disturbing text/icon shift, the rest is fire.
Offline Darthbaggins
  • PC Cannibal
« Reply #14 on: Tue, 04 October 2022, 09:00:01 »
Really wish I had jumped in on this set - one of my favorite color schemes and I use the Dracula theme on all my workspaces where I can apply it.
Offline synthtastic
« Reply #15 on: Tue, 04 October 2022, 09:53:46 »
Extras are up for pre-order on Oblotzky. Am sure there will be plenty of extras for sale after this ships.
Expensive plastic makes me sigh.
Offline m2u-84
  • Be excellent to each other and – party on, dudes!
« Reply #16 on: Sun, 09 October 2022, 09:31:20 »
Oblotzky Industries just shared this info with their customers via e-mail:
“[…] While GMK has been making great progress in catching up with their queue, it wasn't quite enough to hit the original or revised timeline target for some of the sets. The schedule currently looks as follows: […] GMK Dracula V2.0 - March […] Please note that these dates are referring to the time when GMK expects these to ship out from their factory. Transit time to me is usually no more than 2-3 business days, plus a few days (more for large projects like Botanical and Oblivion) for me to fulfill all orders. […]”
On their website they updated the shipping date to March 31st, 2023. So it is rather going to be beginning / middle of April than Q1 until the set will appear at our doorstep.
« Last Edit: Sun, 09 October 2022, 09:46:44 by m2u-84 »
Offline thornkin
« Reply #17 on: Thu, 13 October 2022, 22:15:27 »
No extras available in the US at present? Shipping from Oblotsky is pretty high to the US.
Sent from my SM-G991U using Tapatalk
Offline max.clacks
« Reply #18 on: Fri, 14 October 2022, 11:23:27 »
Seeing as Drac V2 hasn't shipped yet, the only options will be preorder and Omnitype doesn't do preorders. Your best bet for getting them with the cheaper US shipping is to wait for extras from Omnitype after fulfillment.
Offline drunken_sailor
  • I'm from KeebCats!
    • KeebCats
Re: [GB] GMK Dracula V2.0 — GB Closed (In Production)
« Reply #19 on: Fri, 16 June 2023, 07:16:45 »
I would sacrifice numerous goats to get my hands on this set... I'm shocked and disappointed that I missed it. Cannot wait for extras  :llama:
Offline IOVERCALLHISTIOCYTES
« Reply #20 on: Fri, 16 June 2023, 11:30:02 »
I mean...aftermarket is often under 150$, especially if you don't mind if it's been used
