Author Topic: [GB] GMK Relegendables+  (Read 82485 times)
Offline Surostu
  • switchkeys.au x keyboardfinder.com
    • keyboardfinder
« on: Mon, 15 November 2021, 04:45:41 »
GB Date November 16th – December 17th
Expected delivery date is early Q1 2023.
SOCIALS TO STAY UP TO DATE
Join the my discord for all Relegendables+ updates.
Input Theory Discord Server - Includes updates for this project and all other projects I am working on
We may be doing a giveaway via the below instagram account. Be sure to keep up to date.
Instagram – Stew.Klack
KITS
Front printed kits – CR base and U9 base.
These include front printed kits in the two colourways, to suit WOB and to suit Beige Mods. The legends chosen will cover the top row of a TKL/full size as well as the nav cluster. While we agree the row height would be better if it matched the rows of the nav cluster, GMK unfortunately only makes these caps in R1.
Blanks kits – CR, WS1, U9, L9 and N9.
These kits will cover a range of common colourways used frequently on GMK sets. If you are unsure if these kits will match your set, please ask in the comments or with your local vendor. The short version, is it will cover you for most things WOB or BOW related, sets with white alphas (that aren’t WS2), all the classic beige variants and anything with Dolch coloured mods. Recent sets that some of these will work with (blanks kits) include the Desert base of Botanical R2, Monochrome mods, Minimal, Serika Accents (to be confirmed), Sixes, Modern Desko, Patisserie, Stealth, Thinkcaps, Beta, Dolch R5 etc. You get the idea. They’re useful for many, many kits.
The survey during IC was divided. So now you can buy them in lots of 10, or in lots of 20. Kits of 20 work out more economical, but for those wanting alternating beige especially, you can buy them in 10s. If you want to save money, buy the lots of 20 instead and split them with a friend.
HIBI - METAL ARTISAN
HIBI METAL ARTISAN
Yes, it's 2 pieces. A brass PVD silver top, with a black ano base. Was very happy to work with HIBI on this one, the first 2 piece cap they've done. Not to be missed.
Board Renders
PRICING
Pricing will be updated as each vendor adds prices.
VENDORS
OCE - Switchkeys
US - Space
EU - CandyKeys
CA - Ashkeebs
KR - SWAG Keys
CN - KBDFans
SEA - iLumkb
PH – Zion Studios
UK - Prototypist
A big thankyou to everyone who provided feedback during the IC.
Big thanks to Nathanalphaman, Avocadough, Stef, Caz, Ragan at Space, Oggi, Nathandesigns and all the other vendors and people who helped bring this together.
« Last Edit: Thu, 10 February 2022, 16:01:57 by Surostu »
Offline Nuap
Re: [GB] GMK Relegendables+
« Reply #1 on: Tue, 16 November 2021, 07:14:30 »
Let's go! Finally reasonably priced relegendables
Offline yoshifan151
« Reply #2 on: Tue, 16 November 2021, 11:41:52 »
About time someone ran a relegendables gb, loaded up on these. Thanks again for running this and GLWGB!
Mech27 V2 (Black/WKL) | Cloudline (Red/WKL)
Offline clik_clak
« Reply #3 on: Tue, 16 November 2021, 11:45:33 »
Bought 20 piece black, white and dolch so far. Just deciding what beige I want to go with and will most likely order towards the end of the GB.
Thanks for doing these!
Offline Pach
« Reply #4 on: Tue, 16 November 2021, 12:59:41 »
very nice :cool:
Offline Pylon
« Reply #5 on: Tue, 16 November 2021, 23:29:03 »
Just picked up a couple sets to fill out the extra keys on my Boston protos.
I have CR black ones off an old Cherry G80-8200HUAUS-2 - really looking forward to getting some in WS1 and N9.
« Last Edit: Tue, 16 November 2021, 23:30:53 by Pylon »
Offline Surostu
    • keyboardfinder
« Reply #6 on: Tue, 23 November 2021, 04:01:33 »
Bit of an update even though I wont have a chart.
CR kits in blanks and front print have hit MOQ.
Every other kit is now halfway past MOQ.
Thanks everyone for the support so far  ;)
Offline scapegoat4
  • Mega lurker
« Reply #7 on: Wed, 24 November 2021, 03:49:23 »
This is a great set! I'm tempted to order but I already have enough for my current boards lol
Offline Jo_hannes
  • You can never learn less. You can only learn more.
« Reply #8 on: Wed, 24 November 2021, 03:54:14 »
Almost everything ordered! There was talk of a template for printing legends for these in the IC. Any developments on this? /Johannes
Offline Surostu
    • keyboardfinder
« Reply #9 on: Wed, 24 November 2021, 03:58:24 »
We were trying to get exact dimensions for them from GMK in terms of thickness tolerance so that we could advise what was possible in terms of paper/card material for them, but haven't been able to get that info from them unfortunately. Either way, im confident we will make a template that works for printing on standard size pieces of paper so they can be made to scale. So yes, we are working on it.
Offline Jo_hannes
« Reply #10 on: Wed, 24 November 2021, 06:27:41 »
Great to hear, thanks! /Johannes
« Reply #11 on: Wed, 24 November 2021, 10:50:38 »
I believe the traditional size for printing for relegendables is 15mm, but I don't have a caliper to check mine.
Offline Jo_hannes
« Reply #12 on: Fri, 26 November 2021, 06:39:44 »
All right, increased my order to every 20pc kit (excluding WS) and took in both side-labelled kits and of course the HIBI! 222 Euros, but I just love the look so much! Thanks again for making this! /Johannes
Offline Pylon
« Reply #13 on: Fri, 26 November 2021, 12:12:03 »
My G80-8200HUAUS-2 had stickers under the relegendables when I bought them. Just measured one with calipers and it came out to 0.13mm thick, and the top clips in just fine.
From measuring the keycap and the top, there's around a 0.15mm gap between the bottom of the top and the top of the keycap, so you can probably fit at least that.
Offline King4477
« Reply #14 on: Sat, 27 November 2021, 09:23:14 »
In. Thanks!
Offline Surostu
    • keyboardfinder
« Reply #15 on: Sat, 04 December 2021, 16:50:17 »
All kits have now hit MOQ, everything will be made.
I am VERY excited to see pics of all the boards where people have clearly bought a full for of HIBI caps.
Thanks to everyones support so far. Just under 2 weeks to get your orders in!!!
Offline Surostu
    • keyboardfinder
« Reply #16 on: Thu, 16 December 2021, 18:21:41 »
Final day/hours. Don't miss out.
The number of people buying a full row of hibi's is astounding!!!
Thanks everyone who made this GB possible  ;D
Offline Surostu
    • keyboardfinder
« Reply #17 on: Thu, 10 February 2022, 16:01:28 »
Invoices received from GMK.
To follow along with the project or to see what else im working on, join the discord below:
Offline joke
« Reply #18 on: Mon, 12 September 2022, 04:19:24 »
The invite link is invalid, can you post an updated one?
Offline Surostu
    • keyboardfinder
« Reply #19 on: Mon, 12 September 2022, 05:09:55 »
https://discord.gg/WSMuUbq3RK
Try this one :)
« Reply #20 on: Wed, 14 September 2022, 18:46:43 »
Would they not be the same as OG relegendables, I just assumed GMK has the same tooling?
Offline NightFox99
« Reply #21 on: Sun, 02 April 2023, 09:18:49 »
News ?
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #22 on: Thu, 01 June 2023, 18:50:16 »
If there is an update, could you please share it here as well as in discord?
https://geekhack.org/index.php?topic=115197.0
Offline Dewstem
« Reply #23 on: Sun, 04 June 2023, 00:28:00 »
Hello any updates?
Keebs owned:
Geon's F1, F2, Hiney's Poly TKL One, Singa's Kohaku, Sho's PC Snipe Silenced, Snow Edition HHKB Hybrid, Pro 3, Pro 2, Realforce 87u
Offline iamtragic
« Reply #24 on: Sun, 04 June 2023, 00:41:40 »
299554-0
Closest thing to an update I could find on their discord.
Offline IOVERCALLHISTIOCYTES
« Reply #25 on: Sun, 04 June 2023, 23:39:25 »
Sorta assuming the date was intended to be Euro format (june 9) but american format seems a bit more likely
Offline Nuap
« Reply #26 on: Tue, 04 July 2023, 19:56:33 »
I believe the designer has been busy.
SwitchKeys has Relegendables listed as July in their updates page (updated 28th June): https://www.switchkeys.com.au/pages/updates
Offline iamtragic
« Reply #27 on: Thu, 27 July 2023, 05:26:05 »
How exciting
Offline SwitchKeys
    • SwitchKeys
« Reply #28 on: Sun, 30 July 2023, 18:49:36 »
Oceania begins fulfilment today. Extras will follow likely next week.
Cheers
Offline SwitchKeys
    • SwitchKeys
« Reply #29 on: Thu, 03 August 2023, 20:36:04 »
Offline godofdeath
« Reply #30 on: Sat, 19 August 2023, 19:37:02 »
Are these double shots for the front print?
Offline Fraaaan
« Reply #31 on: Sun, 20 August 2023, 04:28:01 »
UV printed
