Author Topic: Soldering Iron/Station.  (Read 148990 times)
fartq
  •  Guest
Re: Soldering Iron/Station.
« Reply #250 on: Sun, 05 August 2012, 21:43:57 »
damnit!
so i actually had a wlc100 that i gave away (to family) because i was so unhappy with it. it takes a very long time to heat up sometimes
Offline alaricljs
  • I be WOT'ing all day...
« Reply #251 on: Sun, 05 August 2012, 21:48:16 »
Yeah sucker is slow to heat, no doubt there.  With experience you can speed it up by cranking it to 5 and setting a timer.  My handle is also dying a slow stupid death... something inside broke and is slowly crumbling.
Filco w/ Imsto thick PBT
fartq
  •  Guest
« Reply #252 on: Sun, 05 August 2012, 21:53:38 »
the problem is i may need something so foolproof that not even demik can screw it up :D
« Reply #253 on: Sun, 05 August 2012, 21:54:43 »
im going to burn i hate kawa into you when you aren't looking
fartq
  •  Guest
« Reply #254 on: Sun, 05 August 2012, 21:55:40 »
maybe i'll stick with the wlc100 then...
Offline Input Nirvana
« Reply #255 on: Wed, 08 August 2012, 00:51:41 »
Don't bother, I already have that tattooed on my pecker, right where everyone can see it.
I see guys with absolute soldering JUNK and they solder the crap outta everything. Technique accounts for a LOT!
I don't like junk.
