Author Topic: Building a dactyl-cc and I need help with wiring.  (Read 9856 times)
Offline ivche1337
« on: Mon, 22 November 2021, 08:25:20 »
Hey everyone!
So I decided to build myself a dactyl-cc, I got all the parts but I have trouble with figuring out how to wire the columns and the rows (diodes and switches).
I know that there are tons of wiring guides on the dactyl keyboards, but I am struggling with implementing them for this specific layout.
I would appreciate it if someone could outline a wiring scheme for me in the picture below.
Thank you in advance!
Offline nevin
Re: Building a dactyl-cc and I need help with wiring.
« Reply #1 on: Mon, 22 November 2021, 08:27:32 »
sure. what controllers are you planning on using?
Offline ivche1337
« Reply #2 on: Mon, 22 November 2021, 08:34:53 »
Arduino pro micros
Offline iaji
« Reply #3 on: Mon, 22 November 2021, 18:15:41 »
here you go.
Offline ivche1337
« Reply #4 on: Wed, 24 November 2021, 20:07:51 »
here you go.
Thank you, a lot!
Can you also mention which color on which pins of the switch?
Offline iaji
« Reply #5 on: Wed, 24 November 2021, 22:06:02 »
Blue for diodes. Red directly to switches.
Offline ivche1337
« Reply #6 on: Thu, 25 November 2021, 05:40:19 »
No but i meant, which color to solder to which pin on the switch?
Offline vvp
« Reply #7 on: Thu, 25 November 2021, 10:13:34 »
It does not matter. Select the one you like more.
