Author Topic: Black Friday Best Prebuilt 60 percent(clicky)?  (Read 2363 times)
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« on: Tue, 23 November 2021, 09:29:26 »
My keyboard is starting to wear out, i don't know it doesn't feel that nice anymore. I'm now not a fan of linear switches because they provide little to no tactile or audio feedback, plus they're so light that they kinda make my hands tired. I am currently working at my part time job at my local stadium. In addition, i also need a new mousepad because the one i have been using for 2 years is too small and i keep hitting the edges as i'm trying to do voltaic.
As the title says i'm looking for a keyboard thats clicky and 60 percent without going over my budget of 230 (canadian) dollars. Should i save up until the Grey Cup Paycheck, or should i spend now? I am getting a 200-300 dollar paycheck on December 1st. I also have amazon prime from my fathers account as well.
For context, i will work the most hours on the Grey Cup Shift, since it's like the Super Bowl but for canadians.
« Last Edit: Tue, 23 November 2021, 09:35:20 by Sintpinty »
Just my thoughts
Offline MIGHTY CHICKEN
Re: Black Friday Best Prebuilt 60 percent(clicky)?
« Reply #1 on: Tue, 23 November 2021, 09:35:19 »
Only prebuilt I would rec would be a Leopold, but they don’t have 60 maybe a womier k61 with a lil tuning and some extra caps?
Or a Miya from vermillio, maybe a key chron
Since this is THE hobby, you could always save up a lil more and get some cooler 60s with box jades or smth
Offline Sintpinty
    • My Roblox Profile
« Reply #2 on: Tue, 23 November 2021, 09:41:06 »
The GMMK is looking like a good option right now especially since i can swap out the switches for something like razer greens (my ideal clickies) or box whites. I might order that on Amazon or their website.
Just my thoughts
« Reply #3 on: Tue, 23 November 2021, 09:42:48 »
If you do feel like going a non-prebuilt route, you can always get the bakeneko which is hotswap and should fit nicely into your budget
Offline Maledicted
« Reply #4 on: Tue, 23 November 2021, 10:49:04 »
Razer greens are ideal? Which clicky switches have you tried so far? Razer's are made by Kailh or Greetech, neither of which make good MX clones. I can't imagine you would choose anything MX if you tried a few decent alternatives.
Offline HungerMechanic
« Reply #5 on: Tue, 23 November 2021, 13:59:13 »
Looks like he's gonna need hotswap. To try out the various clicky switches.
Zeal clickies are coming soon, too.
GMMK might actually be a decent choice. If it's their basic 60%, you should at least lube the stabilizers, maybe buy the Cherry-style gold-plated plate-mount stabilizers if BF prices are in-effect. I've used these to replace stabilizers on entry-level hotswap keyboards, and they're good.
