Author Topic: [IC] Mammoth75/20 GB Update: Default Knob, GB Date, Vendor list  (Read 21411 times)
Offline Ckeeb
  • Meet ZOOM64 Keyboard!
    • MELETRIX
« on: Wed, 24 November 2021, 19:59:47 »
Hi Everyone,
Thank you for your interests for Mammoth75/20. Untill today, we already finished delivering 1st drop and is delivery 2nd drop. And now after listening to so many suggestions, we come to our GB in a few days.
GB Page with vendor list, limits, date here(Not live yet)
Aluminum Mirror PVD Bottom Case
What’s new from the 2 in-stock drops:
1.We update the default knobs below:
2.We include WS stabilizers for both Mammoth75 and Mammoth 20
Wireless version added
What to expect for the Knobs:
Check default knobs here
We will run a separate knob GB after this GB ends. The designs and votes for community knobs will start before this GB ends, and we are open to accept bespoke knobs. More details we be released later.
Mammoth75 info
Highlights
Full Mirror or Sandblasted Bottom Case
Sandblasted Diamond Cut Mammoth Weight
Special Gasket Structure with Daughter board
Details
Typing angle: 6.5 degrees.
Front Height: ~20mm
Weight (unbuilt): 2 kg
Case material: Aluminum
Mounting Method: Gasket Mount
PCB Specifications
Hot-swap PCB: 1.2mm thick, flex cuts.
Multi layout: supports split space bars, Left/Right shift split,backspace split, step caps lock
QMK / VIA support: Yes.
In-switch LEDs: No
Underglow: No
ESD Protection: Yes.
Mammoth75 Kit Contents:
Top Case (Aluminum)
Bottom Case (Aluminum/Brass Mirror PVD, Aluminum/Brass Sandblasted)
PC Plate
WS Stabs 6+1
PCB and daughter board
PORON gaskets
PORON dampener between plate and PCB
PORON foam between PCB and switches
PORON foam under PCB
Gaskets
1x Aluminum knob
1x Brass knob
Magnet base
Encoder holder
Screws and rubber feet
Colors: E-white, Black, Navy, Violet
GB Time: January 14th, 2022 - January 31th, 2022 Estimated Delivery: July 2022 to Vendors
We highly recommend joining the Wuque Studio discord to stay up-to-date with Mammoth75.
Updated December 14th, 2021
Hi Everyone,
Thank you for the wait so far, after near 2 weeks' preparation we are glad to let you know that we are ready for the in-stock sale very soon!
In-stock sale Mammoth75 Collections (not live yet)
Build Stream schedule:Alexotos(2PM EST, Tuesday December 14th)
In-stock sale schedule:08:30 AM GMT+8, Dec. 16th, 2021
Limited in-stock sale
Mammoth 75 Price: 399 USD (Except E-white 409USD)
Mammoth 20 Price: 109 USD
Colorways: E-white, Black, Navy, Violet
Qty: around 200 units in total for Mammoth 75 and Mammoth 20 each. Exact QTY for each colorway will be updated on the in-stock sale page before the sale drops.
GB after in-stock sale
After the in-stock sale we will run a GB with more options, please fill in our IC form if you are interested.
GB Price Estimation
Due to increasing raw material cost and manufacturing cost (higher defective rate than we expected for full mirror PVD bottom case), Mammoth 75’s GB price can be slightly higher than in-stock price even though we need to wait for GB delivery.
GB Limit Estimation
Since it’s really time-consuming for manufacturing full PVD mirror bottom case, we will set a limit for timely delivery and will announce after the in-stock sale.
GB Options
We will check our IC form for more options and update after in-stock sale.
Hi Everyone,
After IKKI68 OG is delivered in 2020, both our team and our users want to have a 75% board. So we started to design in late 2020. There are so many people who want to make 75% smaller, but we feel like our community deserves something new and special. We finally come to an idea for a heavy, sturdy, and elegant one - Mammoth 75. With this idea in mind, we discuss a lot with our focus team for every designs. From the top case to bottom, from the corner’s shape to the material we want, from the size of the knob to how much mirror PVD treatment we can do. And today, after almost 1 year’s effort, we can finally show you how it is now!
Gallery
Mammoth 75 info
-Typing angle: 6.5 degrees.
-Front Height: ~20mm
-Weight (unbuilt): 2.5 kg
-Case material: Aluminum
-Mounting Method: Gasket Mount
PCB Specifications:
-Hot-swap PCB: 1.2mm thick, flex cuts.
-Multi layout: supports split space bars, Left/Right shift split,backspace split, step caps lock
-QMK / VIA support: Yes.
-In-switch LEDs: No
-Underglow: No
-ESD Protection: Yes.
Mammoth 75 Highlights
  • Full Mirror Bottom Case
  • Sandblasted Diamond Cut Mammoth Weight
  • Special Gasket Structure with Daughter board
We make the plate poron foam the same size as the plate, and it will touch the entire bottom case to achieve a stable typing feel. We also use adhesive poron under PCB for a pleasant deeper sound.
  • Two Magnet Knobs
We use a magnet base to make knob even more friendly “hotswap”. The kit comes with 2 knobs for your choice: One Aluminium knurled knob, one brass CD pattern knob.
  • The Case Design
Thicker front bezel for a larger footprint, the gentle sloped case are reminiscent of a mammoth. But we further simplify its sides and back from IKKI68 OG (check how we change the prototypes here) and give it a silver decoration to make it look vigorous.
Price: $399 USD
Time: before Middle Dec. 2021
Qty: about 200 units (depends on final QC)
Colorways: E-white, Black, Navy, Blurple
Kit Contents:
-Top Case (Aluminum)
-Bottom Case (PVD Aluminum)
-PC Plate
-Hotswap PCB and daughter board
-PORON gaskets
-PORON dampener between plate and PCB
-PORON foam between PCB and switches
-PORON foam on the case
-Alu and brass knob
-Magnet base
-Encoder holder
-Hex screwdriver
-Screws and rubber feet
IC Form
After the in-stock sale we will run a GB, and we also looking forward to more feedback for the later GB. Please fill in our IC form if you are interested.
We will be posting more updates in a few days. Updates with more photos, sound tests and more! We highly recommend joining the Wuque Studio discord to stay up-to-date with Mammoth 75.
« Last Edit: Mon, 10 January 2022, 22:08:10 by Ckeeb »
Offline ptaatp
Re: [IC] Mammoth 75, a Full Mirror PVD Bottom Case Gasket Board
« Reply #1 on: Wed, 24 November 2021, 20:53:08 »
Definitely getting this. Any chance for a burgundy colourway?
« Last Edit: Wed, 24 November 2021, 20:56:02 by ptaatp »
Offline svenge
« Reply #2 on: Thu, 25 November 2021, 00:47:54 »
I'm normally a huge 75% fan but this just isn't for me.  There is a conflict between the space saving layout of a 75% and the huge knob, which might make more sense on a 105+ layout.  Also this is closer to a TKL rather than 75%, just based on the size.  Just my $.02.
Also .. that bottom reminds me an awful lot of the 7V.  Not sure if that's good or bad.
Offline Ckeeb
    • MELETRIX
« Reply #3 on: Thu, 25 November 2021, 03:41:23 »
Not sure, but you can fill in the IC form. We will decide which color will add in the later GB. Thank you.
Offline edwyn
  • I create stuff for CONCEPT & IDEA
    • CONCEPT & IDEA
« Reply #4 on: Thu, 25 November 2021, 13:20:58 »
Awesome to see something different also that navy is nice and dark!
Offline Ckeeb
    • MELETRIX
« Reply #5 on: Fri, 26 November 2021, 01:16:43 »
Thank you :cool:
Offline WarlordGorguts
« Reply #6 on: Fri, 26 November 2021, 12:03:03 »
Looks really great and fresh! Would be interested in more colors and a Mammoth 20x. Filled the IC.
Offline Galdom
« Reply #7 on: Sat, 27 November 2021, 08:09:07 »
No ISO enter?
Offline bastijn
« Reply #8 on: Sat, 04 December 2021, 02:10:26 »
Great to see an alternative layout for 75. Strong consider!
"The purpose of computing is insight, not numbers." -- Richard Hamming
Offline Ckeeb
    • MELETRIX
« Reply #9 on: Wed, 08 December 2021, 20:06:17 »
Thank you. In-stock sale will be around 15th Dec. 2021.
Offline MrBIGEURO
« Reply #10 on: Mon, 13 December 2021, 16:28:35 »
Offline Ckeeb
    • MELETRIX
Offline Ckeeb
    • MELETRIX
« Reply #12 on: Tue, 14 December 2021, 20:41:12 »
No ISO enter?
We will offer ISO version in later GB. Thank you.
Offline Ckeeb
    • MELETRIX
« Reply #13 on: Tue, 14 December 2021, 20:41:58 »
Thank you. Stay tuned!
Re: [IC] Mammoth75, Mammoth20 Build Stream and Limited In-stock Sale Coming Soon
« Reply #14 on: Tue, 14 December 2021, 21:17:48 »
Do you have a photo of both knobs?
Offline Havattack
« Reply #15 on: Wed, 15 December 2021, 22:25:33 »
Love the big nob, hate the 4key cluster below it. I think it would look a lot better if it was a diamond shape, as opposed to a square. (rotate it)
Offline DEN1ED
« Reply #16 on: Thu, 16 December 2021, 11:11:33 »
Love the design. Would definitely be in for the GB if there were color options for the knob. Not a huge fan of brass color.
Offline XBLRad
« Reply #17 on: Mon, 27 December 2021, 14:07:32 »
I'm highly interested in this board and I want to make sure I don't miss out on the next drop/sale. May I please get updated discord link. The one in the IC form is expired
Offline Magnificent Bureaucrat
  • Sooooo much red tape
« Reply #18 on: Mon, 27 December 2021, 14:23:56 »
I'm not a fan of the layout. The knob was clearly the main focus of the design and the four key cluster feels like an afterthought.
Offline itsazly
    • website place
« Reply #19 on: Tue, 28 December 2021, 12:33:38 »
The four key cluster matches their Ikki model.
« Reply #20 on: Tue, 28 December 2021, 12:45:26 »
when you think of this as an ikki68 with f row and knob it actually makes a lot more sense, at least to me
« Reply #21 on: Tue, 28 December 2021, 17:16:37 »
I can see they're trying to maintain the same design language but for me the smaller form factor of the ikki; along with the badge and led, meant things felt more cohesive. I think the dead space around the knob and next to the arrow cluster is throwing me off here.
All preference so I hope this goes well for people who are digging the design.
Offline IOVERCALLHISTIOCYTES
« Reply #22 on: Tue, 28 December 2021, 18:28:32 »
got my mammoth 20 in the mail today. this thing is FANTASTIC for the money. highly recommend.
Offline Ckeeb
    • MELETRIX
Thanks for your support! :thumb:
