Author Topic: Life or death question I need to ask you right now.  (Read 2907 times)
Offline ranker
    • keyboard porn
« on: Sat, 11 December 2021, 01:55:12 »
Do you prefer a 145g or 155g spring?  I personally prefer 145...155 is way too stiff for me.
Re: Life or death question I need to ask you right now.
« Reply #1 on: Sat, 11 December 2021, 04:33:42 »
In what kind of life-support machine are you using it?
Does your oxygen level dip too low if you use the 155 g spring?
Offline ranker
    • keyboard porn
« Reply #2 on: Sat, 11 December 2021, 05:22:58 »
almost!
Offline Faceman76
« Reply #3 on: Sat, 11 December 2021, 08:54:05 »
I use a 100 that bottoms out at 140g for the main board and 150 that bottoms out at 200g for the macro pad.
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
Offline Leslieann
« Reply #4 on: Sat, 11 December 2021, 09:37:27 »
Stop punching your keyboard and you won't need such insane springs.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Faceman76
« Reply #5 on: Sat, 11 December 2021, 09:53:54 »
I bottom out with less.
Although, I may give 80's or 90's a try soon.
As for the macro pad, the heavy springs are to prevent accidentally pasting and entering important data in fields where it doesn't belong.
Offline ranker
    • keyboard porn
« Reply #6 on: Sat, 11 December 2021, 11:54:30 »
holy cow
Offline ranker
    • keyboard porn
« Reply #7 on: Sat, 11 December 2021, 11:55:27 »
makes sense to me
Offline Leslieann
« Reply #8 on: Sat, 11 December 2021, 15:17:27 »
How you type can impact how you bottom out, not as much as springs, but how you bottom out is also important.
Typing on rocks isn't any better for your joints due repetitive stress and when you do bottom out because of the force behind your fingers to get there it's only going to be more harsh. I run 39g springs* but because I use so little effort that when I do bottom out I have almost no pressure behind my fingers. Put another way, my bottoming out pressure is less than your activation pressure.
*This soft of a spring is not compatible with all switches.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
