Author Topic: [GB] Clickiez™, Crystal™, Pearlio™ Switches  (Read 47049 times)
Offline IneffableCrab
Re: [GB] Clickiez™, Crystal™, Pearlio™ Switches
« Reply #100 on: Sat, 21 May 2022, 21:01:06 »
Just got mine in the mail earlier this week and put them in the test board. I've been swapping between the two weights, and I'm very surprised how much I like the 40g ones. That said, for some reason I just don't vibe with the 75g ones. (Which is weird because I generally like a heavier key press; I was really expecting that to go the other way around!)
I need to type on them for a little bit longer before deciding, but the 40g Clickiez are a serious contender for my 1800 board. I only ordered 20 of each to try them out, so getting the rest to outfit a full sized board won't be cheap--but what is in this hobby? I'm pretty sure I'll get in on the next round of pre-orders anyway.
The only way I'll give up my numpad is if you pry it from my cold, dead hands.
Offline Telstar
« Reply #101 on: Mon, 17 October 2022, 15:03:48 »
Anyone has some spares? I need to test the clickiez 40g and crystals, just 1-2 pieces each.
