Author Topic: [IC] GMK Disco Rasputin - Complete Overhaul  (Read 203396 times)
Offline Ella
  • Why is it called an oven
« on: Fri, 31 December 2021, 17:35:00 »
IC Form
Hello. This is a keycap set.
Vendors
US: ?
CA: DeskHero
EU: MyKeyboard
SEA: Hex Keyboards
OCE: Switchkeys
CN: zFrontier
Kitting
Base Kit
Spacebar Kit
Meme Kit (Extension & 3key 40s)
Colors
Pink - Pantone 806C
Blue - GMK Stock TU2
Black - GMK Stock CR
Board Renders
by me
EllaXT by me
Vlad by Jing
Invader by me
If you want to support the set, add this code to your signature!
Code: [Select]
[url=https://geekhack.org/index.php?topic=115819][img height=120]https://i.imgur.com/4XsmiNt.png[/img][/url]Thanks to:
Ray for coming up with the name
Oggi for the Cyrillic modifiers, go check out GMK Taiga!
Skok for render help and general advice
Hali for kitting help
Laur for render advice
Jing for giving me Vlad render files
Tonsky for the Fira Code font, used for labeling kitting renders
« Last Edit: Fri, 30 June 2023, 15:25:20 by Ella »
Offline Ella
Re: [IC]GMK Moscow Nights
« Reply #1 on: Fri, 31 December 2021, 17:36:18 »
Updates:
- 3/19/2022 :: Remade the whole set as well as renders
- 3/19/2022 :: Added 3 key 40s compat into the extension kit based on feedback
- 3/19/2022 :: Fixed Render error in extension kit, I accidentally put R3 tab into R2
« Last Edit: Sat, 19 March 2022, 10:02:15 by Ella »
« Reply #2 on: Fri, 31 December 2021, 17:37:17 »
nice
Offline Entity.
  • Entity#1234
« Reply #3 on: Fri, 31 December 2021, 17:37:55 »
When can I buy?
Offline Sax_______
« Reply #4 on: Fri, 31 December 2021, 17:37:59 »
I see r0 and r5
I like
Although I'd prefer icon+text mods in base as opposed to text only
Offline TyPo.mk
« Reply #5 on: Fri, 31 December 2021, 17:39:13 »
I am interested
Offline Zetina
  • Big bird
    • Instagram
« Reply #6 on: Fri, 31 December 2021, 17:40:08 »
Looking Ňice
Instagram: @zetina.kb
Offline Aiwanei
    • ThocKeys.com
« Reply #7 on: Fri, 31 December 2021, 17:40:16 »
I'm in, this is so good.
ThocKeys.com
Offline lalostad98
« Reply #8 on: Fri, 31 December 2021, 17:40:43 »
text only mods bad
« Reply #9 on: Fri, 31 December 2021, 17:41:28 »
text only mods bad
true
text+icon pls
also GMK pad print not so good
but otherwise nice
Offline Pensa73
« Reply #10 on: Fri, 31 December 2021, 17:43:05 »
Icon > Icon + text >>>>>>>>>> text
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
« Reply #11 on: Fri, 31 December 2021, 17:43:15 »
very nice set, good work ellie.
« Last Edit: Sun, 17 April 2022, 15:18:31 by dudeship »
Offline denibhoxha
  • cock and balls technology
« Reply #12 on: Fri, 31 December 2021, 17:46:32 »
thank you Marek Hamsik this is so based
Offline linell
« Reply #13 on: Fri, 31 December 2021, 17:48:23 »
text only mods best mods
bro this a **** set, just be thankful you even getting 1 base running fr
Offline Baka Bot
« Reply #14 on: Fri, 31 December 2021, 17:48:36 »
You have Text only mods. That is good. glwic
Offline war40ck
  • Sadge
« Reply #15 on: Fri, 31 December 2021, 17:50:03 »
nice
Tell me why...
Offline Ella
« Reply #16 on: Fri, 31 December 2021, 17:50:23 »
I added an IC form, I messed up and forgot to add it when posting
Offline Sax_______
« Reply #17 on: Fri, 31 December 2021, 17:51:55 »
text only mods bad
Good take
text only mods bad
true
text+icon pls
but otherwise nice
Good take
Acceptable take
Bad take
Bad take
Offline Ella
« Reply #18 on: Fri, 31 December 2021, 17:56:05 »
text only mods bad
Good take
text only mods bad
true
text+icon pls
but otherwise nice
Good take
Acceptable take
Bad take
Bad take
Text Only mods are my dirty pleasure
Offline Neely_12
« Reply #19 on: Fri, 31 December 2021, 17:58:08 »
I do wish the shade of blue was a bit more blue rather than teal and text + icon mods would be nice, but this is a very nice set. Good luck!
Offline Yuinth
« Reply #20 on: Fri, 31 December 2021, 18:17:08 »
You got me at R0 and I like the colors, need it now.
GLWIC
« Reply #21 on: Fri, 31 December 2021, 18:26:01 »
text only mods bad
Good take
text only mods bad
true
text+icon pls
but otherwise nice
Good take
Acceptable take
Bad take
Bad take
points for multiquote
Offline Skok
« Reply #22 on: Fri, 31 December 2021, 18:52:47 »
I have a HUGE problem with this set. It's that you haven't made it for me sooner.
Offline DaaDaa
« Reply #23 on: Fri, 31 December 2021, 20:03:13 »
thank god for the text only shift. im just about sick of the text/icon shifts that all looks the same on 30 buck amazon sets and just about most gmk.
piggy60 red upgraded PVD w/ GMK umka zaku | tiramisuit w/ GMK noire JWK silk emerald | mr.suit black/chrome glossy chamfers w/ GMK minimal cow POM stem | jelly epoch w/ SA oblivion zaku | mode80 deco w/ gmk boneyard alpaca | mode 80 imperial with ePBT origami alpaca| MODE80 viridian /w CRP boba LT | RAMA thermal kuro w/ GMK muted 2 pewter | BBox60 C64 wih marshmellows and c64 keycaps | MODE Sonnet green /w MW voynich gateron ink box pink
Offline HungHingDaiLo
  • 無間道
« Reply #24 on: Fri, 31 December 2021, 21:17:38 »
Nice!
On the icon mods kit:
Is it possible to add R0 1u icon for Esc (The mirrored male symbol)?
IG: @rayhhdailo
Offline C_L | Soup
« Reply #25 on: Fri, 31 December 2021, 21:37:00 »
this is gorgeous! more R0 and R5 plz
Offline Tree_
« Reply #26 on: Fri, 31 December 2021, 21:54:25 »
Looks good. Text mods are nice.
Offline herbologist
  • beige enjoyer. send help.
« Reply #27 on: Fri, 31 December 2021, 22:02:57 »
good sir, I appreciate the fresh take on an old cw with subs and r5 but personally I prefer icon + text. pls consider.
Sent from my Pixel 6 Pro using Tapatalk
Offline darthcapn
« Reply #28 on: Fri, 31 December 2021, 22:59:48 »
Nice
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline vishydesigns
« Reply #29 on: Fri, 31 December 2021, 23:24:21 »
renders sold me, nice work
Offline Pyroo
« Reply #30 on: Sat, 01 January 2022, 05:22:58 »
Cute set
Bunny enthusiast
Offline Hedgey
« Reply #31 on: Sat, 01 January 2022, 09:57:49 »
Looks awesome!  Please consider 3 or 4 key 40's support in the base!!  :thumb:
"Resellers don't kill the community, auctioneers kill the community. Look at what happened to Diablo 3"
Offline LXVRGS
« Reply #32 on: Sat, 01 January 2022, 11:08:43 »
ne purselock avail for icon mod kit
Offline sirieous
  • help
« Reply #33 on: Sat, 01 January 2022, 11:33:48 »
I'd love to see this wtih icon+text mods but it's pretty neat so far. GLWIC
Offline sup3r170va
« Reply #34 on: Sat, 01 January 2022, 11:55:10 »
I prefer icon only mods, if not icon+text mods.
I'm not sure if this is a popular opinion here, but I am not a big fan of R0. I think the keycaps are too high. I prefer R1-R1-R2-R3-R4-R5 like some of the recent sets.
Offline krzank
« Reply #35 on: Sat, 01 January 2022, 12:52:02 »
Please keep R0/R5!
Please add: R4:Backslash/Pipe
Offline Vigrith
« Reply #36 on: Sat, 01 January 2022, 13:01:52 »
I love this set. Though I'll be honest, although I don't particularly dislike them in general, I think English text only mods look real weird in sets that have different alphabet alphas. I'd prefer text icon, or even just icon, but I'll be buying regardless.
Offline derpturtle
« Reply #37 on: Sat, 01 January 2022, 16:14:49 »
I love xeon
Offline soloplayer
« Reply #38 on: Sun, 02 January 2022, 08:04:33 »
you got me in for r0/r5
waiting for so long for a full scuplt gmk  :thumb:
Offline hottrout
  • I'd Hit Dat Key
« Reply #39 on: Sun, 02 January 2022, 18:18:50 »
Yes please.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline wired
« Reply #40 on: Sun, 02 January 2022, 23:50:46 »
can't wait  :thumb:
Offline Bub
    • big bub's beepers
« Reply #41 on: Mon, 03 January 2022, 05:54:35 »
couple of thing:
  • you're going to price people out with your current kiting + r0 and r5.... consider going slimmer unless you wanna run at $135-$140.
  • consider adding subs to numpad for a little ZEST
  • rub out
Offline Ella
« Reply #42 on: Mon, 03 January 2022, 06:01:06 »
couple of thing:
  • rub out
Thank you for the advice bub, stay thocky.
Offline chaoskills08
« Reply #43 on: Wed, 05 January 2022, 13:43:27 »
Just echoing a little here, I would LOVE to see some 40s support, even just basic 3 key. Also I feel some mats could go hard with this! Great work!
Offline _IanOfEarth
« Reply #44 on: Wed, 05 January 2022, 20:56:10 »
1.5u supers and 1u alts, amazing color scheme, great kitting. I am 110% in, this is so rad.
Offline konstantin
  • Formerly constexpr
« Reply #45 on: Thu, 06 January 2022, 03:31:24 »
Kitting suggestions (assuming R0, R5 are staying):
To elaborate further re: R1 Pause: if you aren't including numpad 00, then R1 Pause shouldn't be included either, as that particular 1800 layout option is even less common than numpad 00. Neither key is justified in a GMK base kit, imo.
Additionally, 1.25c space is currently missing from the spacebars kit and should be added.
« Last Edit: Thu, 06 January 2022, 03:40:03 by konstantin »
Offline Ella
« Reply #46 on: Thu, 06 January 2022, 04:03:15 »
Thanks for these suggestions! I'll try to update the renders asap.
Offline Mecxs
« Reply #47 on: Thu, 06 January 2022, 05:19:14 »
I love seeing 3key 40% support in GMK / DCS base kits.
But if I am going to pay extra for a full sculpt, then I am going to be using it on a TKL or 75% or full size, not something without R0/R1.
If 3key fits in and doesn't add hugely to the price, would definitely be great to see, but I do think it's reasonable to omit it in this specific set.
Offline konstantin
« Reply #48 on: Thu, 06 January 2022, 13:21:04 »
I agree with this reasoning.
Offline plag
  • Formerly pepperonichicken
  • i also go by plag
« Reply #49 on: Thu, 06 January 2022, 15:37:31 »
looks great! excited for this
