Author Topic: EEs wanted: will this USB drive work with *this* USB hub?  (Read 4830 times)
Offline Stupidface
  • Lifelong edge use case
« on: Mon, 03 January 2022, 08:35:29 »
(NB: If any of the below is unclear, please let me know and I will clarify.)
I recently acquired an 8TB USB 3.0 drive.  In terms of power requirements, the drive is rated (as near as I can make out) at 12V 4A.
The drive has two FW800 ports on the back; I will be using one of those ports to transfer data.  The drive also comes with a power cable containing a barrel-type connector on one end to plug into the drive and a USB-A plug on the other end to plug into a USB port of some kind for power...which is where the USB hub comes in.
The particular USB hub I am looking at to do this is described as "a universal AC 100 – 240 V to DC 5V 6A with 6 USB Ports Power Supply."  The 6 USB ports are connected in parallel so the amps will be divided according the number of charging devices I plug in.  I plan on plugging in two devices (a smartphone and the aforementioned USB drive), so presumably each USB port will be able to provide 3 amps.
ETA - For the sake of anyone faced with a similar problem in the future, this matter hangs on the following formula:
W = V * A (or: watts equals volts multiplied by amps)
In this case, we have a hard drive with a power supply drawing 12 volts at 4 amps, so: 12V * 4A = 48 Watts
Meanwhile, as suicidal_orange points out, the USB hub supplies 5 volts at 6 amps so: 5V * 6A = 30 Watts.
Bottom line: Plugging a 48 Watt device into a 30 Watt hub and expecting it to operate is not likely to meet with much success.
(Well, now I know.)
« Last Edit: Tue, 04 January 2022, 05:08:03 by Stupidface »
Re: EEs wanted: will this USB drive work with *this* USB hub?
« Reply #1 on: Mon, 03 January 2022, 09:38:03 »
USB 3 has a spec for power delivery which allows for up to 240W, your drive (if you guessed right) requires 12V@4A which is only 48W so that's how the supplied cable should be used.
That hub provides 5V@6A which is only 30W and that's before the phone steals any and some is lost in the voltage conversion so if everything you said is accurate it wont work.
Offline Darthbaggins
  • PC Cannibal
« Reply #2 on: Mon, 03 January 2022, 14:48:30 »
Straight nope, it wont be a stable power source.  (As S.Orange already stated as well)
Offline Stupidface
« Reply #3 on: Tue, 04 January 2022, 05:18:59 »
Yes, and therein lies the problem: the laptop I would like to use this drive with only has USB 2.0 ports, hence my messing around with USB 3.0 hubs.  Unfortunately, as I have quickly learned, many of the USB 3.0 hubs for sale are not meant to power anything substantial (like, say, a HD drawing 48 Watts).
Indeed, I was barking up the wrong tree with this one.  Thank you for taking the time to sort me out. [tips hat]
« Last Edit: Tue, 04 January 2022, 05:37:49 by Stupidface »
Offline Stupidface
« Reply #4 on: Tue, 04 January 2022, 05:35:32 »
Thank you for confirming suicidal_orange's answer.  This one was a no-hoper, all right.
