Author Topic: [IC] Abacus (ID42) | IDOBAO | Announcement and Layout Update | 1-5-22 UPDATED  (Read 6343 times)
Offline rainson
    • IDOBAO_Studio
Abacus [ID42]
Discord Server for More Updates Here
Google Form for IC(Leave your important opinion here)
Updates
Product Design
IC & Improve
Structure Design & Test
Sample Test
Produce & Gourp buy Sale
First batch to send & Off Sale
Group purchase order sending
Restock and On Sale
Latest News
1.the keyboard price have been confirmed at 119$
2.Group buy may will be on Jan.8th. to Feb.2th.,will gifted a customized keycaps kit
3.it has 3 color[White,Black and Very Peri]now,will more in future
4.The space bar is 2.25u on the left and 2.75u on the right
Status
Date:5th of January 2022
Lateset:Keyboard layout diagram updated
Next:Sample Test and Collect Feedback
What i am doing now:Making IC post & collect feedback
Renders(White,Black and Very Peri)
More Pictures Here
Black
White
Very Peri
Specifics
Name: Idobao Abacus [ID42] Keyboard
Structure: Top(Frame) Mount
Color: White、Black、Very Peri
Typing Angle: 6 Degrees
Material: Aluminum、Foam
PCB: ID42 PCB from IDOBAO (Support VIA & QMK)
Light:Per key RGB
Includes
Top Case: Aluminium
Bottom case: Aluminium
Kailh Hot sawp PCB
Others:Stabilizers、Screws、Cable、Foot pad、Foam
Please Join our Discord to make sure can get earlier and more updates
Please leave your thoughts here
Thanks & Regards
Rainson
« Last Edit: Tue, 04 January 2022, 20:11:32 by rainson »
Offline nu_types
  • Formerly Iredeus
Deja Vu
Offline rainson
    • IDOBAO_Studio
Deja Vu
i re-post it,the geekhack team delect as it suspected advertising...i dont know why and update the pics website and re-post.
Offline rainson
    • IDOBAO_Studio
hope you can review it and give us the comment and feedback again.
post was deleted by geekhack in mistake in hours ago that we cant see them.
or fill the IC form,thanks!!!
Offline fortaye
  • 40's 40's 40's
Thanks for incorporating some of the feedback. I hope the right shift can be moved all the way to the right. Typing with that 1.25u in that location on 12u is quite difficult.
Offline rainson
    • IDOBAO_Studio
nothing,thats what i do.yes this id42 is a bit difference with the normal 40% layout,and a bit same as the 60% layout,like combining the two into one
Offline Necrolegion
Oh Idobao, when will you guys break the mold?! Why do you guys keep starting with an integrated plate version first, then follow it up with another integrated plate with brass weight, then PC/acrylic gasket version, and finally an aluminum gasket version????
You guys repeat this with almost every single keyboard! Just make it a gasket or top mount and have something new.
Offline rainson
    • IDOBAO_Studio
thanks for your confusion,it can take into account the needs of two structures users."Value should values by quality rather than by quantity"is famous in Chinese idioms.
but we also try hard in this way,will bring more new products this year
