[IC] Foundation – γ (Gamma): Seamless, Screwless, F13 TKL![[IC] Foundation – γ (Gamma): Seamless, Screwless, F13 TKL, GB DATE: April 10 281372-0](https://geekhack.org/index.php?PHPSESSID=g4k42t916ejcmf2hscv65hotmkikuulc&action=dlattach;topic=116033.0;attach=281372;image)
![[IC] Foundation – γ (Gamma): Seamless, Screwless, F13 TKL, GB DATE: April 10 281374-1](https://geekhack.org/index.php?PHPSESSID=g4k42t916ejcmf2hscv65hotmkikuulc&action=dlattach;topic=116033.0;attach=281374;image)
My take on a seamless, screwless F13 TKL. Designed around the use of heavy linear or tactile switches.
IC FormProto galleryCase specs:- Case: 6063 Aluminum
- Weight: polished stainless steel
- Typing angle: 7 degrees
- Width: 372.79 mm
- Height: 19.18 mm (front), 34.77 mm (back)
- Effective typing height: 24.65 mm
- Weight: 2.9 kg excluding plate
- Mounting method: Gasket mount
- WKL or WK options
- Plate options: FR4, Aluminum, Polycarbonate, Carbon Fiber
PCB specs:- QMK/VIA compatibility
- ESD Protection
- Daughterboard: Unified C3 (USB C – Centered)
- Soldered only
- PCB will be opened sourced under non-commercial clause after GB ends.
![[IC] Foundation – γ (Gamma): Seamless, Screwless, F13 TKL, GB DATE: April 10 281378-3](https://geekhack.org/index.php?PHPSESSID=g4k42t916ejcmf2hscv65hotmkikuulc&action=dlattach;topic=116033.0;attach=281378;image)
![[IC] Foundation – γ (Gamma): Seamless, Screwless, F13 TKL, GB DATE: April 10 281520-4](https://geekhack.org/index.php?PHPSESSID=g4k42t916ejcmf2hscv65hotmkikuulc&action=dlattach;topic=116033.0;attach=281520;image)
Plate not final, will be adding stepped caps compatibility.
Plate will be open sourced under MIT license after GB ends. This includes a version without any flex cuts. Please feel free to experiment.
Pricing:- $630 USD with FR4 plate, $645 USD with other plate (CF, PC, Alu) @ 350 MOQ
- Group buy date: April 10
Contents:- Keyboard Top
- Keyboard Bottom
- Weight (polished stainless)
- PCB
- Daughterboard + JST cable
- Gaskets
- Screws
- Bumpons
- MechandCo Carrying case
Vendors:- NA: MechsandCo
- CAN: Deskhero
- AUS: Dailyclack
- UK: Prototypist
- EU: MkbEU
- SEA: Hex
- CN: Frontier
Lead time: 3-4 Quarters.
Typing testPrototype units are being sent out. Expect proper sound tests soon.
AlexotosRemarksWhy no renders?Renders are an artist's interpretation of an item. Prototypes are the item.
Discord
