Author Topic: SA Lunar New Year  (Read 14206 times)
Offline NoxNoxNox
SA Lunar New Year
« on: Sat, 22 January 2022, 03:08:32 »
SA Lunar New Year
Info:
Based on the Lunar New Year traditional red envelope, this sculpted SA Profile set uses stock colors and will feature brand-new SA Zhuyin sublegends.
Brought to you by Toki and Nox
Manufacturer: Signature Plastics
ABS Plastic
Profile: SA Scuplted 112343
Stock Colors:  YCF RAC
Color Reference:
GB Dates: TBD
Kits
Proof of Concept kit render (Please note the this is NOT the final kitting -see below-)
We have aligned to 4 kits (shown here on KLE)
Basekit
Novelties
Iso
Numpad
The two novelties not shown in the proof of concept render
Deskmat:
Renders
Sat75
TKL One
J-02
Vendors
NA: Thockeys
UK: Prototypist
Others: TBD
To do list:
Final kitting renders
One more deskpad
Finalize Pricing
More Vendors
Huge thanks to Pwade, OCM, and Aiwanei.
« Last Edit: Thu, 27 January 2022, 13:50:43 by NoxNoxNox »
Offline kylekwong1
Re: SA Lunar New Year
« Reply #1 on: Sat, 22 January 2022, 05:51:57 »
Zhuyin with Simplified Chinese on the novelties?
Offline Thailurr
« Reply #2 on: Sat, 22 January 2022, 09:48:08 »
Great set made by some great dudes big POGGERS
Offline floweryi
« Reply #3 on: Sat, 22 January 2022, 10:56:40 »
wait i don’t understand what’s the problem with having zhuyin and the actual characters? like genuinely asking. also it’s traditional
edit: hold on the render says 新年快樂 but the kitting says 春节快乐?? should probably sort that out. not only is it a difference of traditional vs simplified, it also means different things (same festival but different wording) happy new year vs happy spring festival
also since this is a cny themed keycap set, do consider adding 倒福 (character ‘fu’ upside down) as a novelty instead of just 囍. oranges, red packets, lion dance, firecracker, etc also come to mind
« Last Edit: Sat, 22 January 2022, 11:09:54 by floweryi »
Offline kylekwong1
« Reply #4 on: Sat, 22 January 2022, 11:26:02 »
春節 is another way of saying CNY/LNY so it wouldn't be the biggest problem if 春節 was used instead of 春节.
However I find Zhuyin sublegend with 春节快乐 offensive to some degree. Zhuyin is mainly used by Taiwanese, who use traditional Chinese character.
I also agree with your idea of 倒福. It is definitely something that should be in a lunar new year themed set
Also, adding Fai Chun to the deskmat seems better than just a plain red mat.
« Last Edit: Sat, 22 January 2022, 11:29:45 by kylekwong1 »
Offline ilikerustoo
« Reply #5 on: Sat, 22 January 2022, 14:12:14 »
I like red
Offline LaserCrafter
  • reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
« Reply #6 on: Sat, 22 January 2022, 15:50:37 »
sa thocc
Keyboard Collection: Unikorn, Orion v2.5, Orion v3, Realforce 87u, Viper v3, NMB RT8756CGR, Unicorn x Legend, Das II, TC-V3, Jetfire, Wang 325-3770, Lightpad v2
Keyset Collection: OG Doubleshots, CRP 2551 R4, Muted 2, Cyan R1, WoB, DCS Wyse, ISO OG POM, ePBT Blanks, BSP Blanks, BoW + Gigachild
Offline thienhaor
« Reply #7 on: Sat, 22 January 2022, 16:33:51 »
Well dang this looks so nice, looking forward to the GB!
Offline NoxNoxNox
« Reply #8 on: Thu, 27 January 2022, 13:51:44 »
Two updates:
1) Prototypist as UK vendor
2) Spacebar kit with 'b' for alice is being considered
As always, feedback is appreciated.
Offline thienhaor
« Reply #9 on: Thu, 27 January 2022, 13:53:48 »
Will there be an All-in-one bundle?
Offline Tyson
« Reply #10 on: Thu, 27 January 2022, 14:16:27 »
Wait, Toki's designing sets now? I don't want it. :PogO:
Offline TeacherGeek
« Reply #11 on: Thu, 27 January 2022, 23:15:19 »
Are you Chinese? Cause you used a symbol used for marriage 囍 rather than 福.
Offline ABABA
« Reply #12 on: Fri, 28 January 2022, 14:19:02 »
I like the idea of this set, but the design for the shuang xi looks a little wonky.  If you're committing to it I think you ought to consider bringing everything a little inwards and possibly connecting some of the horizontal lines, so that it looks more like a single character.
Or just go with a 福
Offline BAKAUSAGIDA
« Reply #13 on: Fri, 28 January 2022, 15:20:50 »
I like this design, but I must say that the word "囍" is actually used for marriage rather than Chinese New Year.
The overlapping of the two "喜" words in the represents a happy event for the two families, not New Years.
I think replacing the 囍 with the reversed "福" or "春" would be more appropriate.
Hope it gives you some inspiration.
« Last Edit: Fri, 28 January 2022, 15:22:53 by BAKAUSAGIDA »
Offline NoxNoxNox
« Reply #14 on: Thu, 03 February 2022, 16:17:19 »
Update;
Sort of announcement of announcement but wanted to share.
More vendors are secured.
More kitting changes are incoming including likely Latin alphas and spacebar kit, tweaks to novelties.
Please look forward to it.
Offline konstantin
  • Formerly constexpr
« Reply #15 on: Thu, 03 February 2022, 18:17:25 »
The base kit is missing R3 PgUp, R4 PgDn for 65% support, as well as F13.
The numpad kit is missing R1 PgDn, End for 1800/CP/96-key support.
Offline rowie
« Reply #16 on: Sat, 12 February 2022, 14:51:48 »
Love this. Would love a Hibi Brass PVD in Gold SA R3 “ 囍” please. I request the r3 profile so that it will be more universal especially for single or double macro columns and maybe some could buy some for an entire macro column.  ;D
Offline forsee
« Reply #17 on: Tue, 17 May 2022, 10:58:51 »
Really interested in this IC! Any progress on it or has it been abandoned?
Offline Meepergon
« Reply #18 on: Fri, 16 February 2024, 10:43:59 »
this goes insanely hard. i'll be copping if y'all run it soon.
Offline section311
« Reply #19 on: Fri, 16 February 2024, 13:49:52 »
Delete
« Last Edit: Fri, 16 February 2024, 13:51:25 by section311 »
Offline section311
« Reply #20 on: Fri, 16 February 2024, 13:50:56 »
Not sure if its happening but the only other one i am aware of is this https://www.zfrontier.com/app/flow/6VrzbyPnV61p
Offline singabore
« Reply #21 on: Thu, 29 February 2024, 22:07:09 »
this thing is still happening btw, just looking for a new NA vendor and fixing some kitting stuff. stay tuned bois
Offline tactilesbad
« Reply #22 on: Fri, 01 March 2024, 09:50:31 »
banger
