Author Topic: [IC] DCS ''Yellowed''  (Read 27963 times)
Offline Preston Walz
  • Operating since 2020.
    • Discord Server
« on: Thu, 27 January 2022, 12:37:55 »
DCS ''Yellowed''
Consider filling out IC Form, I'm considering WYSE legends. Extra thoughts are welcome as well.
IC Form:https://forms.gle/xhwuGhoLbJrJPCEu7
IG:https://www.instagram.com/prestonwalzdesignstudio
Discord: https://discord.gg/nWTAbK5sY9
Inpiration
DCS ''Yellowed'', is inspired by vintage keyboards that are often found with aged yellowed keycaps. Typically, enthusiast restore their yellowed keycaps to their former glory, but... Why not embrace the yellow?
I made this set with the goal of retaining that vintage style we all know and love, whilst modernizing it to a point where it would sit comfortably in contemporary desk setups.
Why DCS
DCS profile is slowly making its return to the keyboard scene. I think there are already so many cherry profile keysets (I'm slightly bored of it), DCS offers an entirely different feel and typing experience. The DCS profile has a thinner profile than GMK caps, this means a slightly ''chirpier'' sound, you'll also be able to fully appreciate the finer characteristics of the keyboard and key-feel when typing. This leads to a distinct typing experience some can describe as ''raw'', or ''pure''.
I'm a fan
Vendors
US TBA
CA TBA
EU TBA
UK TBA
CN TBA
KR TBA
OCE TBA
When
(Estimate)
Q2 2022
Proposed Kits
Accessories
TBA
RENDERS:
TECHNICAL SPECS
  • Made in Washington by Signature Plastics LLC
  • DCS profile (1-1-2-3-4-4) w Cherry legends
  • Compatible with MX Style switches
  • ABS plastic
Code: [Select]
[url=https://geekhack.org/index.php?topic=116107.0][img]https://i.imgur.com/VtYkARz.png[/img][/url]
« Last Edit: Wed, 17 August 2022, 22:36:52 by Preston Walz »
    • Discord Server
Re: [IC] DCS ''Yellowed''
« Reply #1 on: Thu, 27 January 2022, 12:38:38 »
Changelog:
1/27 - IC Posted
1/27 - Fixed IC question
1/28 - Fixed Discord link
« Last Edit: Sat, 07 May 2022, 21:30:39 by Preston Walz »
Offline of_sam
« Reply #2 on: Thu, 27 January 2022, 12:39:09 »
Why
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline kameron
« Reply #3 on: Thu, 27 January 2022, 12:40:24 »
please consider adding 3/4key and terminal iso support as while as using Wyse legends
Offline Sandy
  • Formerly cogitoergofemme
  • Sandy - Peach Tray Maker
    • the peach · studio
« Reply #4 on: Thu, 27 January 2022, 12:41:09 »
Are the mods triple shot? The text and icon are different colors or is that just an illusion from font weight
🍑C11🍑KWA.6🍑GPK60 47-GR1RE🍑Vast60🍑Rose60🍑EHKB🍑Viktus Sinne🍑Boop65🍑Jelly60 Pro🍑Fuji65🍑Ginkgo 65🍑S7.7🍑Treasure Type-9 II🍑Thermal R2🍑Jelly 60🍑
Offline DubbTom
« Reply #5 on: Thu, 27 January 2022, 12:43:39 »
How about a pre-shined kit as well  ;D
poker II
Offline Fraaaan
« Reply #6 on: Thu, 27 January 2022, 12:47:33 »
RGB mods are great! +1 for WYSE legends.
Offline LaserCrafter
  • reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
« Reply #7 on: Thu, 27 January 2022, 12:53:48 »
do wyse legends pls and ty
Keyboard Collection: Unikorn, Orion v1, Orion v3, Realforce 87u, Das II, 356mini, Wang 325-3770, Lightpad v2, Deko Fast Action
Keyset Collection: OG Doubleshots x2, CRP 2551 R4, Muted 2, Cyan R1, WoB, DCS Wyse, ISO OG POM, ePBT Blanks, BSP Blanks, BoW + Gigachild, Minimal R1, SAD Dyesubs,
Offline notquant
« Reply #8 on: Thu, 27 January 2022, 12:54:19 »
Looking good, love the RGB mods. Wyse support would be appreciated as well!
Offline nu_types
  • Formerly Iredeus
« Reply #9 on: Thu, 27 January 2022, 12:55:49 »
Once it eventually yellows you'll have DCS Brown
Offline Aiwanei
    • ThocKeys.com
« Reply #10 on: Thu, 27 January 2022, 12:56:18 »
another +1 for Wyse Legends, fits the vintage DCS concept a lot better imo.
ThocKeys.com
Offline Moods
« Reply #11 on: Thu, 27 January 2022, 12:57:36 »
Nice F13  :))
Would like to see WYSE also
Offline stewfayew
« Reply #12 on: Thu, 27 January 2022, 12:58:28 »
Like a fine aged cheese...
Edit: Consider using WYSE legends :) and adding mod tilde
« Last Edit: Sun, 30 January 2022, 14:57:44 by stewfayew »
Offline NoPunIn10Did
    • NoPunIn10Key
« Reply #13 on: Thu, 27 January 2022, 13:05:07 »
You have some goofiness going on with your ISO compatibility alpha-wise.  Right now you're halfway between two common setups.
Currently you have:
R3 '@
R3 #~
R4 <>
I recommend one of these setups:
UK ISO, which requires 6 alphas
R1 `¬ or `¬¦
R1 2"
R1 3£
R3 '@
R3 #~
R4 \|
Terminal Minimal US ISO, which requires 2 alphas
R3 \|
R4 <>
Windows Minimal US ISO, also just 2 alphas, though less recommended outside certain contexts
R3 \|
R4 \|
Apple US International ISO, 3 alphas, very rarely seen in the hobby
R1 §±
R3 \|
R4 `~
« Last Edit: Thu, 27 January 2022, 13:07:54 by NoPunIn10Did »
Offline fruitykeeb
    • Storefront
« Reply #14 on: Thu, 27 January 2022, 13:07:09 »
looks good! please consider 3-key in base for 40s compatibility  :thumb:
Offline Neely_12
« Reply #15 on: Thu, 27 January 2022, 13:14:16 »
Unless you plan on offering the numpad kit at a high moq, it would probably be best to include it in base. Kitting needs a good bit of work, and I would like to see the quality of the renders improved a little to better represent what you’re trying to show. Personally think you should go with wyse or gorton legends for this. Finally target pricing would be nice, since it’s relatively easy to get quotes. I’ve listed all the kitting changes are immediately apparent to me below:
Base:
Add the four uk iso keys you are missing (not, mod not, 1, and 2) or just change to terminal
Move R1 end and pg dn to numpad kit or move numpad kit to base
Change the stepped caps to say double line “caps lock” instead of “caps”
Add mod tilde
Change 1.5u backspace and iso enter to text+icon, and would encourage 1.25u to be text only.
Numpad:
If you keep it separate of base: add equals
Remove second enter
Would encourage adding arrows and Nav subs
Change “num” to double line “num lock”
Add 1u + and -
Other:
Please add a spacebars kit
Please list what stock colors you are using
Offline MIGHTY CHICKEN
« Reply #16 on: Thu, 27 January 2022, 13:21:38 »
Another +1 for wise legends
Offline ZavaZ86
« Reply #17 on: Thu, 27 January 2022, 13:37:13 »
Fix the 1.25u shifts, it's supposed to be icon+text and not icon only. It is also sitting higher than the other icons. Also don't just include UK-ISO because of a very loud minority.
Offline herbologist
  • beige enjoyer. send help.
« Reply #18 on: Thu, 27 January 2022, 14:12:53 »
I'm a fan of the theme, but there definitely needs to be some changes.
numpad should really be in the base, you're missing a spacebar kit currently. Please use wyse on dcs, especially because it's a vintage themed set. not everything needs to use cherry legends.
Sent from my Pixel 6 Pro using Tapatalk
Offline PixelPlays__
  • God, this hobby is so expensive.
« Reply #19 on: Thu, 27 January 2022, 14:23:37 »
Why is there no render for F13?
Offline carlfink
  • metal rectangle enjoyer, @carl.#1208 on discord
« Reply #20 on: Thu, 27 January 2022, 14:42:39 »
+1 for wyse  ;D
Offline paulgali
    • SKME
« Reply #21 on: Thu, 27 January 2022, 15:05:06 »
Here's a funny thing
Jokes aside, you have 10u, but no other spacebar kits, and very strange compat on ISO - consider NoPunIn10Did's comment. Also f13 box? huh
I understand its targeting that old school layout but add compat for modern layouts. People might like it and there's no need to alienate people because of that.
If that base kit is over 80USD I would be shocked
« Last Edit: Thu, 27 January 2022, 15:06:42 by paulgali »
    • Discord Server
« Reply #22 on: Thu, 27 January 2022, 15:24:15 »
Currently you have:
R3 '@
R3 #~
R4 <>
R1 `¬ or `¬¦
R1 2"
R1 3£
R3 '@
R3 #~
R4 \|
R3 \|
R4 <>
R3 \|
R4 \|
R1 §±
R3 \|
R4 `~
Thank you for the suggestions, I will be taking a closer look and make changes accordingly.
    • Discord Server
« Reply #23 on: Thu, 27 January 2022, 15:30:05 »
Thank you for the joke, you just made my day. Jokes aside (heh), similar description of DCS.. yes. Do I genuinely feel this way about DCS... also yes. The F13 box, sorry haha. Likely, I'm going to render again with the kitting changes suggested and F13 as an actual key, with mod and alpha colors.
I will also consider spacebar kitting for the set. Thank you for the valuable input.
    • Discord Server
« Reply #24 on: Thu, 27 January 2022, 15:31:30 »
I will be fixing soon, alongside adding mod colored F13 and other kitting additions. Thank you for the input.
    • Discord Server
« Reply #25 on: Thu, 27 January 2022, 15:33:43 »
I will take a look. For WYSE legends, I am still in consideration. Though, yours and others feedback is heard. Thank you for the input.
Offline Tyson
« Reply #26 on: Thu, 27 January 2022, 19:40:30 »
As much as I would love to also see the base kit price be $80, I could be wrong but even if this uses stock SP colors there's potential for it to be $90+ due to the price of resin being extremely high right now. After getting multiple quotes for DCS Rectifier no matter how small I tried making the base kit I was unable to consider any price point under $100 due to the prices SP quoted me. But then again I could be wrong, SP prices could be very different set to set. I'm down for this if you are able to price it at $80!
Offline paulgali
    • SKME
« Reply #27 on: Thu, 27 January 2022, 22:50:34 »
Send me the colors and ill run you a WYSE render in under a minute in private. At least you could have an idea of how it looks.
    • Discord Server
« Reply #28 on: Fri, 28 January 2022, 00:09:56 »
No, nothing is triple shot. It's likely the weight of the fonts causing a slight illusion as you mentioned. I apologize
Offline Juan.
« Reply #29 on: Fri, 28 January 2022, 04:15:16 »
Response:
[TBA]
rubber cup
Offline treeleaf64
    • treeleaf64
« Reply #30 on: Fri, 28 January 2022, 11:39:25 »
It look like 9009   Are   you making a   copy cat
Everyone must pay the cat tax
    • Discord Server
« Reply #31 on: Fri, 28 January 2022, 12:16:58 »
No treeleaf. It's ''yellowed''.  :D
Offline Mikhail
« Reply #32 on: Fri, 28 January 2022, 12:21:25 »
RGB mods is good idea. Maybe add yellow sys/code caps like in GMK RGBYK?
And, if SP have cherry style font for DCS, can they made cherry style Russian subletters?))
    • Discord Server
« Reply #33 on: Fri, 28 January 2022, 12:29:52 »
I will consider adding yellow, but I want to keep the cost low. Personally, I don't like how the yellow ends up looking when applied, I much prefer the RGB modifier WKL builds.
Offline kameron
« Reply #34 on: Fri, 28 January 2022, 13:01:18 »
Big Fan Mr Treeleaf69-5 this is clearly yellow and draws no inspiration from pauls set smh my head
Offline TheNeonKnight
« Reply #35 on: Fri, 28 January 2022, 16:04:24 »
Will the 10u bar be 7u stabbed?
    • Discord Server
« Reply #36 on: Fri, 28 January 2022, 16:53:42 »
Yes. The 10u spacebar will require 7u stabilizers.
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #37 on: Fri, 28 January 2022, 16:55:49 »
This looks great!
Offline Poesjuh
« Reply #38 on: Fri, 28 January 2022, 17:09:43 »
+1 for WYSE legends, also to make it stand out more compared to 9009.
On that same note, I wonder if this is “yellowed enough” or still too close to the classic beige combo. Perhaps have a side by side render?
And your discord link is broken ;)
    • Discord Server
« Reply #39 on: Fri, 28 January 2022, 17:12:34 »
I'm currently developing a render with different beige sets next to DCS ''Yellowed'' to compare. Thank you for the suggestion.
Offline Poesjuh
« Reply #40 on: Fri, 28 January 2022, 17:16:10 »
Nice :)
It’s probably very visible irl. I have some og doubleshots that in a vacuum don’t look that Yellow. But hold it next to a new set and it looks like the og’s have mustard all over it :P
    • Discord Server
« Reply #41 on: Fri, 28 January 2022, 17:29:51 »
Good catch. Fixed discord link.
Offline treeleaf64
    • treeleaf64
« Reply #42 on: Sat, 29 January 2022, 00:47:37 »
v helpful "yellow"   what are the colors
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #43 on: Sat, 29 January 2022, 00:51:47 »
yellow
Offline HappyB0T
  • I'm a Piggie
« Reply #44 on: Sat, 29 January 2022, 02:31:04 »
Treeleaf
yellow + blue = green
you will be fine.
___________________________
Missed opportunity not to render this on a vintage board.
Most of render color choices don't seem to pair with the board / keyset well.
Consider A beige board > A soft green > A deep green > a yellow board.
This set reminds me of yellow teeth. Get the theme but not really into it.
If the spirit of the ic was "make your old boards look old again with something new" I probably would not feel so confused right now. +1 Wyse Legends
Offline treeleaf64
    • treeleaf64
« Reply #45 on: Sun, 30 January 2022, 16:31:23 »
what is SP color you are using so i can be at peace  that it is not copy  cat
    • Discord Server
« Reply #46 on: Sun, 30 January 2022, 18:19:03 »
Modifier color: SP stock color GAW
Alpha color: PANTONE 11-0617 TCX
I'll be adding these colors to the IC thread soon.
Offline mcmcmc
« Reply #47 on: Sun, 30 January 2022, 22:55:18 »
+2 for wyse
i like your inspiration.
P.S. i know that you are using krk, if you are thinking of changing to wyse there’s Fooblitzky’s model you can use. it’s much better than krk.
« Last Edit: Wed, 30 March 2022, 03:55:32 by mcmcmc »
Offline zyyg
« Reply #48 on: Tue, 22 February 2022, 04:58:26 »
HI ,When will start groupbuy
    • Discord Server
« Reply #49 on: Tue, 22 February 2022, 11:02:01 »
Feel free to join my Discord Server, or follow my Instagram page. I'll be posting updates/news regarding this project on both platforms.
edit* links:
Discord Server: https://discord.gg/nWTAbK5sY9
Instagram: https://www.instagram.com/prestonwalzdesignstudio/
