Author Topic: Very small, one input, wireless device for Windows?  (Read 15737 times)
Offline Entropia
« on: Wed, 02 February 2022, 05:21:18 »
I have been browsing the web in search of this but I have not found anything. The idea is a wireless device that uses a button battery and that can communicate with a computer, being as small as possible, with the only need of being able to send a single input, such a key or key combination. It doesn't matter if it has a physical button or not, because the idea is to hack it to use my own wireless tiny button box.
Offline Leslieann
Re: Very small, one input, wireless device for Windows?
« Reply #1 on: Wed, 02 February 2022, 08:45:07 »
Look into the old Amazon Dash button, probably the smallest thing you will find.
People hacked them to do all sorts of things.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
