Author Topic: [IC] Liberi | GB Start 22 July 2022  (Read 97929 times)
Offline $W4GK!NG
  • Cars/Racing/Keyboards/Watches Enthusiast
    • Linktree
« on: Sat, 05 February 2022, 13:37:03 »
henlo fellow kibort fren
Liberi
IC Form
Discord Server
About
    Hi, I'm $W4GK!NG, it has been over 2 years since I started this hobby, this is my first keyboard project.
    I saw a Kmac Mini, I instantly fell in love, so I made this board, the naming sake and color choices are some weeb **** no one probably cares about.
Latest Update
     GB Date has been confirmed, Liberi GB will be running starting from July 22nd 2022 to August 5th 2022
     There will be 4 vendors avail
        - Ashkeeb (covers the NA area)
        - KEYGEM (covers EU and UK)
        - HexKeyboard (covers SEA and Asia in general)
        - Acid & Co (covers Indonesia)
    Price per keyboard will be $545.00CA / €500.00 (incl. 19% VAT) / $589SG / 6,299,00Rp respectively with 100MOQ
Specification
    - Material: 6063 Aluminium and Brass Weight
    - Color: Anodized Blue or Grey with Coated Sand Blasted Weight
    - Plate: Sandblasted Polycarbonate with MX Cutout (Alps plate will be available later)
    - PCB: Solder only with Alps support using an ai03's daughterboard
    - Typing angle: 6°
    - Width: 358mm
    - Front Height: 22mm adjusted
    - Weight: 1664g unbuilt
    - Mounting: Top mount
    - Layout: Refer to the picture below
Colors
    The 2 colors are RAL 5000 and RAL 7011.
    As mentioned before, the color choices were based on some weeb stuff, I'm not gonna bore yall with that
Prototype & Iteration
    Prototype Album
    I don't have the means to get another prototype in a different color at the time so you will have to forgive me on that, but anyway, this blue prototype was built in the most basic of all layouts.
    I typed on that for a month and I don't like how muted the spacebar was so I decided to add some acoustic cut on the spacebar area both on my prototype and the model.
    And I ended up in-filling the front engraving with acrylic paint.
    For the actual run, there is some amount of change compared to the prototype unit, the case wall size has been reduced and the wall that separated the xt column has been thickened a little, I also added a chamfer all around the bottom case and the seam, and also the plate height from plate to top case is increased from 7.5mm to 7.8mm so that keycaps other than GMK will not float.
    Anyway here's a sound test of the first build of the prototype unit, without the spacebar cut yet.
Pricing, Availability & Vendors
    Ideally, I would love this to be around $450US + Shipping at around 100 MOQ + a few FNF units, Time frame is probably Q2 Q3 2022, still have to finalize the stuff about vendors. Reminder that with more vendors and higher interest, I might be able to run this with a higher MOQ and that will definitely lower the price.
    Confirmed Vendors
        -Hex.Keyboard (SEA)
        -Ashkeeb (NA)
        -Acid & Co. (ID)
        -KEYGEM (EU)
Special Thanks
    Bachoo - Literally everything, from teaching me the design basic to CAD and ****, thank you :peepolove:
    CrazyAssMonkey - Thank you for answering all my dumb Fusion question
    Bababaul - Thank you for the feedback and all the info that I probably would never have if it weren't for you
    Founder role on my discord - Thank you for supporting me all this time, thank you
Update Log
    5 Feb 22 - Posted the IC
    6 Feb 22 - Added Change Log and more entry under prototype section
    6 Feb 22 - Added Exploded View image
    9 Feb 22 - Ashkeeb and Acid & Co. came on board!!
    10 Feb 22 - KEYGEM Joined in :salute:
    3 Feb 22 - Second prototype has been ordered
    17 Jul 22 - GB Date has been annouced
    You can also add this project to your signature to help spread the word :salute:
Code: [Select]
[url=https://geekhack.org/index.php?topic=116187.0][img width=288 height=120]https://imgur.com/uqxW4c9.png[/img][/url]
« Last Edit: Mon, 18 July 2022, 00:26:37 by $W4GK!NG »
Offline Fraaaan
Re: [IC] Liberi
« Reply #1 on: Sat, 05 February 2022, 13:37:24 »
Reserved
Offline Juan.
Re: [IC] Liberi
« Reply #2 on: Sat, 05 February 2022, 13:37:35 »
I like this keyboard, I like this person, I like this vendor, I do not have money.
edit: you are a weeb
« Last Edit: Sat, 05 February 2022, 13:44:14 by Juan. »
rubber cup
Offline Kptburger
Re: [IC] Liberi
« Reply #3 on: Sat, 05 February 2022, 13:41:49 »
weeb kebort by a big weeb, nice :thumb:
best of luck with the IC
i crave lasang
Offline Ella
  • Why is it called an oven
Re: [IC] Liberi
« Reply #4 on: Sat, 05 February 2022, 13:43:20 »
this is almost certainly a keyboard
Offline Dyno
Re: [IC] Liberi
« Reply #5 on: Sat, 05 February 2022, 13:45:09 »
Weebs gonna weeb, but this is too good to pass
GLWIC!
Offline ankit
  • Formerly ankit-sachdeva
Re: [IC] Liberi
« Reply #6 on: Sat, 05 February 2022, 13:45:15 »
Very nice. GLWIC
Offline nullinasou
Re: [IC] Liberi
« Reply #7 on: Sat, 05 February 2022, 13:49:28 »
I love top mount and I love this board.
However you need to improve your spanning it was the saddest sound that my ears have ever experienced
Offline $W4GK!NG
    • Linktree
Re: [IC] Liberi
« Reply #8 on: Sat, 05 February 2022, 13:50:53 »
I legit cant snap :giggle:
Offline Moods
Re: [IC] Liberi
« Reply #9 on: Sat, 05 February 2022, 13:51:33 »
Nice one Swag. GLWIC
Offline denibhoxha
  • cock and balls technology
Re: [IC] Liberi
« Reply #10 on: Sat, 05 February 2022, 13:51:50 »
Liberi so fresh
Offline rookb
Re: [IC] Liberi
« Reply #11 on: Sat, 05 February 2022, 13:51:57 »
Looking forward to it swag  :cool:
Offline Sandy
  • Formerly cogitoergofemme
  • Sandy - Peach Tray Maker
    • the peach · studio
Re: [IC] Liberi
« Reply #12 on: Sat, 05 February 2022, 13:53:26 »
I personally think 450 is a lot of money to not make a new proto with the changes you made but it shouldn’t be the end of the world. You could even do a private proto run. Glwic. 100 units shouldn’t be so bad
🍑C11🍑KWA.6🍑GPK60 47-GR1RE🍑Vast60🍑Rose60🍑EHKB🍑Viktus Sinne🍑Boop65🍑Jelly60 Pro🍑Fuji65🍑Ginkgo 65🍑S7.7🍑Treasure Type-9 II🍑Thermal R2🍑Jelly 60🍑
Offline Sicowa
Re: [IC] Liberi
« Reply #13 on: Sat, 05 February 2022, 13:54:18 »
Looking good cutie
Collection: Khajit 60, Leopold FC980C, Pepper, Ex. Visa, Daedalus
pfp:https://twitter.com/kuroseP/status/1305179874429079553?s=19
Offline chat and team
Re: [IC] Liberi
« Reply #14 on: Sat, 05 February 2022, 13:57:42 »
pricing almost as bad as crin and fr to that guy that was talking about a tofu65.
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline Juan.
Re: [IC] Liberi
« Reply #15 on: Sat, 05 February 2022, 13:59:54 »
who are you talking about
rubber cup
Offline $W4GK!NG
    • Linktree
Re: [IC] Liberi
« Reply #16 on: Sat, 05 February 2022, 13:59:59 »
I was originally planning a private buy before doing a public run, sadly a payment problem was discovered and I can't run a private buy on my own, and all the change was a cosmetic too
Offline kameron
Re: [IC] Liberi
« Reply #17 on: Sat, 05 February 2022, 14:07:30 »
gg this is sexy  :thumb:
Offline stewfayew
Re: [IC] Liberi
« Reply #18 on: Sat, 05 February 2022, 14:08:33 »
exactly. the crin had a brass through-weight too
Offline qats
Re: [IC] Liberi
« Reply #19 on: Sat, 05 February 2022, 14:27:30 »
boggies
Re: [IC] Liberi
« Reply #20 on: Sat, 05 February 2022, 14:30:44 »
Yea there's an age requirement for bank accounts
Offline treeleaf64
    • treeleaf64
Re: [IC] Liberi
« Reply #21 on: Sat, 05 February 2022, 14:54:20 »
Everyone must pay the cat tax
Offline LaserCrafter
  • reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Re: [IC] Liberi
« Reply #22 on: Sat, 05 February 2022, 15:15:39 »
nice
Keyboard Collection: Unikorn, Orion v1, Orion v3, Realforce 87u, Das II, 356mini, Wang 325-3770, Lightpad v2, Deko Fast Action
Keyset Collection: OG Doubleshots x2, CRP 2551 R4, Muted 2, Cyan R1, WoB, DCS Wyse, ISO OG POM, ePBT Blanks, BSP Blanks, BoW + Gigachild, Minimal R1, SAD Dyesubs,
Re: [IC] Liberi
« Reply #23 on: Sat, 05 February 2022, 15:16:58 »
also buddy...
Offline reticent
Re: [IC] Liberi
« Reply #24 on: Sat, 05 February 2022, 16:17:17 »
As an Arknights ****ter as well, I support this keyboard.
Offline Bachoo
Re: [IC] Liberi
« Reply #25 on: Sat, 05 February 2022, 17:28:13 »
Naise  :thumb:
Offline linell
Re: [IC] Liberi
« Reply #26 on: Sat, 05 February 2022, 18:02:27 »
this is beri swag
bro this a **** set, just be thankful you even getting 1 base running fr
Offline herfalerf
Re: [IC] Liberi
« Reply #27 on: Sat, 05 February 2022, 18:32:20 »
I like it.
Offline mcmcmc
[IC] Liberi
« Reply #28 on: Sat, 05 February 2022, 18:38:34 »
this is neat. very cool.
P.S. I also agree with the comment above, I think 450 is a tad bit high. And if you’re getting vendors for this, I think you can get a higher MOQ like 250. I don’t know much about these stuffs, so don’t take my words seriously. seeing that weight with that price, i changed my mind. price is nice. but still if you have vendors i think you can get a higher moq, thus lower price.
« Last Edit: Sun, 06 February 2022, 21:31:47 by mcmcmc »
Offline Kinesiologist
Re: [IC] Liberi
« Reply #29 on: Sat, 05 February 2022, 19:20:09 »
gotta love the classics
Offline zhol
  • zhol
Re: [IC] Liberi
« Reply #30 on: Sat, 05 February 2022, 19:43:10 »
daughterboard? 65xt? option to go without engraving? i'm interested
is the font for the katakana engraving on theme with the underlying weeb theme, or were other fonts considered?
i'm zhol
Offline herbologist
  • beige enjoyer. send help.
Re: [IC] Liberi
« Reply #31 on: Sat, 05 February 2022, 20:59:40 »
swag this is very swag of you  :D
Offline $W4GK!NG
    • Linktree
Re: [IC] Liberi
« Reply #32 on: Sat, 05 February 2022, 22:16:02 »
the font picked for the front engraving was picked for the curves and cuteness(?), I went through a couple of fonts and ended up using this one, the other candidate was either too serious looking or too extravaganza
Offline less_blank
Re: [IC] Liberi
« Reply #33 on: Sat, 05 February 2022, 22:53:33 »
You sure?
Anyway pricing seems fine to me. Frog (Kmac) Mini looks nice.
Offline Bunn3y
  • 绊
Re: [IC] Liberi
« Reply #34 on: Sun, 06 February 2022, 00:17:29 »
Are you making a weeb copycat?
Jokes aside this is cool. GLWIC!
Collection: Ivery Praxis | HHKB Pro 2 | JTD.Works Ovinnik | Realforce R1 87u | Switchplate iiA Sanction
Offline spedywin
  • Formerly spedywin
Re: [IC] Liberi
« Reply #35 on: Sun, 06 February 2022, 00:23:01 »
good stuff mr $W4GK!NG
Offline gloomycloud
  • me enjoy 60s
Re: [IC] Liberi
« Reply #36 on: Sun, 06 February 2022, 00:28:46 »
Looking good! Can you show more pictures of the internals? How big is the brass weight internally, the mounting points?
HHKB Pro Hybrid || Polaris || Kei || Meridian || Leviatán
Offline $W4GK!NG
    • Linktree
Re: [IC] Liberi
« Reply #37 on: Sun, 06 February 2022, 01:03:31 »
my bad, I've added an exploded view, that should be enough to cover both internal and mounting point, anyway thank you for pointing that out
Offline sirieous
  • help
Re: [IC] Liberi
« Reply #38 on: Sun, 06 February 2022, 01:11:02 »
pretty neat, glwic :D
Offline darthcapn
Re: [IC] Liberi
« Reply #39 on: Sun, 06 February 2022, 04:30:22 »
Niceone Glwic!
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline whirlwind
Re: [IC] Liberi
« Reply #40 on: Sun, 06 February 2022, 05:43:50 »
The keyboard got swag, GLWIC!  :thumb:
Offline 7h3of7
Re: [IC] Liberi
« Reply #41 on: Sun, 06 February 2022, 06:28:01 »
GJ sir.
glad to see you've mentally recovered from GMK Sus
Current Board: OTD 356 Mini v1 Black
Offline Keeblet_257
Re: [IC] Liberi
« Reply #42 on: Sun, 06 February 2022, 06:39:47 »
yes
« Last Edit: Wed, 02 March 2022, 15:39:41 by Keeblet_257 »
Offline h40
    • h40.io
Re: [IC] Liberi
« Reply #43 on: Sun, 06 February 2022, 09:14:01 »
I would highly suggest running another prototype with the changes made.
Offline shima
  • keeb weeb
Re: [IC] Liberi
« Reply #44 on: Mon, 07 February 2022, 01:52:38 »
liberi so lit
boards: anura
Offline xef
Re: [IC] Liberi
« Reply #45 on: Mon, 07 February 2022, 12:27:52 »
looks so good. ne silver or wkl avail
probably gonna consider either way
Offline unusuaL_
Re: [IC] Liberi
« Reply #46 on: Mon, 07 February 2022, 15:59:29 »
i want to hear the weeb ****, it wont bore me  ;D
collection: hibike 1/1, garderie tkl, casper60, hhkb pro2, matrix 2.0additional, f1-8x og
Offline $W4GK!NG
    • Linktree
Re: [IC] Liberi
« Reply #47 on: Mon, 07 February 2022, 19:36:50 »
Sorry but the color is locked to this because of the theme and I want to stick to it
Offline paopao
Re: [IC] Liberi
« Reply #48 on: Tue, 08 February 2022, 05:13:45 »
i nut
282265-0
Offline Nonnegaard
Re: [IC] Liberi
« Reply #49 on: Tue, 08 February 2022, 05:35:01 »
weeb 65xt with koala-esque sides. needn't say more.
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
