Author Topic: [IC] Papilio| WKL TKL  (Read 31231 times)
Offline Screen.jing
« on: Fri, 11 February 2022, 11:00:43 »
Papilio
Gasket??? THOCC???
Hi keebord people! This is a TKL I have spent my time and all of my money on for the past year. I will never financially recover from this... I don't have the means to get more prototypes right now, here is what I have so far.
IC Form
Discord
Specification
  • 86 keys tkl - WKL only
  • Material: 6063 Aluminium and Brass weight and SS Weight
  • Color: TBD
  • Plate: Sandblasted Polycarbonate / 5052 Aluminium - plates files will be made public later
  • Mounting: Gasket mount with 4mm NBR cords
  • PCB: Solder only - Designed by Sleepdealer (H88c NORTH variant compatible)
  • Typing angle: 6°
  • Front Height: 19mm without bumpons
  • Weight: ~2.3 kg built
  • Layout:
Prototypes
Build Stream for those interested!
Sound Test for those interested!
Availibility & Vendors
I am aiming for the target price to be around 450-500 USD + shipping. The MOQ is 100 units with fnf units here and there.
Vendors:
  • Hex.Keyboard (SEA)
  • Ashkeebs (NA)
  • Keygem (EU)
  • other regions are currently TBD
Issues noticed:
  • Sparkles are there because I did not specify the grit blast with the manu. I talked to the manu and gave them specific grits for the finishing for the GB units.
  • Slightly tighter tolerance than expected - solved in Fusion.
  • Keys on r4 row are **ed up (see X and Y) - this was due to half-plate tolerance - now solved in Fusion.
  • The USB cutout of the case is slightly offset - this made the whole plate/PCB lean left. This is also now solved in Fusion.
Thanks
everyone for reading this IC
everyone in Blacksimon's community - i love you guys :catBlush:
$W4GK!NG - thank you for building this keyboard, lit up a PCB and pictures
mcmcmc - thank you for giving me feedbacks and help with this IC
bababaul - thank you for giving me advice in manufacturing
All 69g longs in my discord - thank you for supporting me ❤️
« Last Edit: Sun, 13 February 2022, 20:09:02 by Screen.jing »
Too many projects going on at once
Papilio
MF60
Disco
Vlad
65
Adamo
Offline $W4GK!NG
  • Cars/Racing/Keyboards/Watches Enthusiast
    • Linktree
Re: [IC] Papilio| WKL TKL
« Reply #1 on: Fri, 11 February 2022, 11:01:09 »
Reserved
Offline Sleepdealr
  • my name is calliah
    • https://sleepdealer.xyz
« Reply #2 on: Fri, 11 February 2022, 11:03:43 »
i love tkl
Offline kameron
« Reply #3 on: Fri, 11 February 2022, 11:03:54 »
love u jing
Offline Ella
  • Why is it called an oven
« Reply #4 on: Fri, 11 February 2022, 11:30:09 »
tee kay el
Offline mcmcmc
« Reply #5 on: Fri, 11 February 2022, 11:37:58 »
happy to see this project in IC. :thumb:
Offline Fraaaan
« Reply #6 on: Fri, 11 February 2022, 11:38:08 »
Very thoccy side profile. GLWIC!
Offline herbologist
  • beige enjoyer. send help.
« Reply #7 on: Fri, 11 February 2022, 11:40:54 »
Reserved
Sent from my Pixel 6 Pro using Tapatalk
Offline chat and team
« Reply #8 on: Fri, 11 February 2022, 11:52:10 »
I like it very nice
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline Zyrophr
  • https://zyrophr.com
    • zyrophr.com
« Reply #9 on: Fri, 11 February 2022, 12:18:18 »
I love this, gib.
Looks beautiful
French keyboard streamer
Offline gotgoodiez
« Reply #10 on: Fri, 11 February 2022, 12:34:18 »
That front chamfer is really nice and honestly really like the sparkling. Nice job!
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #11 on: Fri, 11 February 2022, 13:18:11 »
badass sides
Offline Nonnegaard
« Reply #12 on: Fri, 11 February 2022, 13:57:38 »
holy **** im gonna cum
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline SDKCAMPING
« Reply #13 on: Fri, 11 February 2022, 14:08:34 »
i do not know if i would trust the GB units to be refinished properly unless you are getting another prototype from theim to verify that they can finish it properly. factories will often say they can do anything for you just so you place a bulk order with them. if you are still using the factory as you did for your prototype, I think you should reconsider.
personally i think you should just use a better factory instead of choosing these, and increase your price slightly. if someone is spending $500 on a keyboard of mediocre quality, i am sure they would spend $70 or more for high tier quality. it's not even just the finishing that this manufacturer is bad at, their actual machining and stuff is pretty bad too. they have crooked lines and dents and filleting that isn't properly round. just not good overall, but "good" for prototyping since they are so cheap at low unit count.
« Last Edit: Fri, 11 February 2022, 14:10:41 by SDKCAMPING »
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline Screen.jing
« Reply #14 on: Fri, 11 February 2022, 14:34:26 »
Hi! I appreciated your time giving me feedback. Right now I am looking at other factories that have a history of better QC. The prototypes that were shown are from 2 different 'ok' manus and I agree with you that they are pretty bad. I will reconsider them when I get the quotes from other manus if they are not significantly higher than what I have so far, but I would not push my target price over 500usd.  :thumb:
Papilio
MF60
Disco
Vlad
65
Adamo
Offline TRIGOZEN x TAO
  • Kanna + Keybort = Big Weeb
« Reply #15 on: Fri, 11 February 2022, 17:21:33 »
hello mrr jing, i like this very much
Offline linell
« Reply #16 on: Fri, 11 February 2022, 17:31:07 »
thank you for using the superior gasket mount
bro this a **** set, just be thankful you even getting 1 base running fr
Offline Kinesiologist
« Reply #17 on: Fri, 11 February 2022, 19:32:36 »
papi
Offline treeleaf64
    • treeleaf64
« Reply #18 on: Fri, 11 February 2022, 21:36:56 »
love that anodization  honestly great texture. am a fan of that stufff!
Everyone must pay the cat tax
Offline LaserCrafter
  • reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
« Reply #19 on: Sat, 12 February 2022, 00:57:16 »
so lit
Keyboard Collection: Unikorn, Orion v1, Orion v3, Realforce 87u, Das II, 356mini, Wang 325-3770, Lightpad v2, Deko Fast Action
Keyset Collection: OG Doubleshots x2, CRP 2551 R4, Muted 2, Cyan R1, WoB, DCS Wyse, ISO OG POM, ePBT Blanks, BSP Blanks, BoW + Gigachild, Minimal R1, SAD Dyesubs,
Offline milka158
« Reply #20 on: Sat, 12 February 2022, 09:21:34 »
hot. would love to see centered usb port with daughterboard
« Last Edit: Sat, 12 February 2022, 09:31:35 by milka158 »
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #21 on: Sat, 12 February 2022, 12:44:08 »
« Last Edit: Sat, 12 February 2022, 12:49:58 by ylothar »
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline nikotypo
« Reply #22 on: Sat, 12 February 2022, 18:20:52 »
so lit. I kinda like the sparkle, makes it stand out. I wish you could preserve some of that with a finer grit.
Offline less_blank
« Reply #23 on: Sun, 13 February 2022, 01:12:34 »
I really like the sparkly finish on the proto as well as the three color tones, hoping something like that will still be available for the production run but I understand changing it if you're not happy with the quality of the manufacturer.
Offline spedywin
  • Formerly spedywin
« Reply #24 on: Sun, 13 February 2022, 20:47:45 »
nice tea cay el glwic man
Offline Belled
  • I like shoobs
« Reply #25 on: Mon, 14 February 2022, 19:13:10 »
I like the weight
Offline CRASHFIRE
« Reply #26 on: Tue, 22 February 2022, 12:03:16 »
Looks really nice. I like it. Looking forward to seeing more about it.
Offline pepperfez
« Reply #27 on: Wed, 23 February 2022, 12:53:27 »
Count me among the sparkle lovers. It's appropriate for the board's name, too -- butterfly wings have the same effect.
Offline Shaqo_Wyn
« Reply #28 on: Sat, 05 March 2022, 12:05:16 »
Please tell me you're selling the color of the prototype. I needz that!
Offline Screen.jing
« Reply #29 on: Wed, 08 June 2022, 06:06:50 »
Prototype group buy in progress
Expect a build stream from Alexotos soon this month
Papilio
MF60
Disco
Vlad
65
Adamo
Offline //gainsborough
  • MATRIXの日常
« Reply #30 on: Wed, 08 June 2022, 12:16:55 »
oh man, prototype GB?  Was this open to the public or a F&F sort of deal?
Offline ZAND4
« Reply #31 on: Wed, 08 June 2022, 13:49:48 »
WKL iz not for everyone
« Reply #32 on: Wed, 08 June 2022, 15:12:20 »
not super unusual these days for a small fnf run to take place when ordering protos to offset the cost a bit
Offline deska
« Reply #33 on: Wed, 08 June 2022, 16:55:55 »
weight design looks great!
Offline Jubileus
« Reply #34 on: Thu, 25 August 2022, 22:15:45 »
Based Jing. Give me lavander!
Offline chigi22
« Reply #35 on: Fri, 26 August 2022, 09:41:13 »
Add me to the list of sparkle appreciators, LOL
Offline LMarci
« Reply #36 on: Wed, 28 September 2022, 12:49:12 »
Can't wait for this
Offline infinitum
  • i buy expensive plastic
« Reply #37 on: Mon, 03 October 2022, 08:56:20 »
yes i love the sparkle finish
Offline Flybeck
« Reply #38 on: Mon, 03 October 2022, 09:20:35 »
We love jing,
no but fr this looks really good man. Always making some cool boards. Excited to see more.
