Author Topic: [GB] Safa TKL | GB COMPLETE  (Read 105303 times)
Offline paulgali
    • SKME
« on: Sat, 12 February 2022, 06:02:32 »
Safa is intended to be a lightweight, simplistic take on the TKL form factor (i.e. it's just a rectangle), with my primary focus being feel and sound.
IC link
Expected ETA - 9 Months from March 1st
Pricing
(Extras pricing in EU is subject to updates, everything else is final)
VAT included everywhere excluding US
LIMITED TO 2 PER HOUSEHOLD
A note for UK orders: When you order ships it will be converted to a UK order.  We have our UK VAT number and are able to ship orders without export/import procedures.   Next month new orders will automatically be UK orders (charged in pound).
There are not going to be extra costs to be paid anymore.
Unit allocation & Sale format
Sale will be conducted in a FCFS, 400-unit limited GB format.
MKBEU - 225 units https://mykeyboard.eu/catalogue/category/group-buys/keyboards/safa-588-f13-keyboard-kit_678/
HEX - 100 units https://hexkeyboards.com/products/safa5-88-group-buy
Rectangles - 15 units; Region locked
Basekeys - 30 units; Region locked https://basekeys.jp/en/products/safa-5-88-f13
Specs
  • 5 degree, 88 key (F13) TKL.
  • 1550g - 1700g weight depending on build
  • Winkey and WKL
  • Adjusted front height of 18.8mm (excluding case feet - 3M 8mm bumpons)
  • Included hard carry case
  • Primarily top mount, secondary gummy worm
  • Fixed ANSI, ISO plates. Variable JIS Plate available
  • Additional polypropylene (PP) plates will be available. Specifically chosen for its more dampening effect over PC
  • Aluminum half plates, ALPS and JIS Plates will be included. Note - ALPS requires hiney's h88c
  • Internal brass weight only - not exposed externally. I live in sandland, its hot, humid, and I never look at the bottom of the board. If its on my desk how can I? I wanted this to change the sound of the board, no other reason.
Plates are also compatible with Jane v2, KFE and other similar mounted boards. You will be able to purchase all available plates, including ALPS Alu 1.2mm options, separate from the main GB
Color options
  • 432c Dark Grey
  • 533c Navy
  • 188c Dark Red
  • E-White (Dark Grey plate)
  • Silver (Red plate)
Alu plates will be matched to case color by default - Grey alu plates are also an option.
PP plates will be black. If you want colored PP plates, get some spray paint and mod it  :D
PCB Compatibility
Solder PCB will be offered in the kit only, but Safa will be compatible with Gondo's hotswap 88 when he releases it.
Featuring north AND south facing space stab support, ANSI, ISO, JIS (both 4.5u and 3u), I have updated the configs for VIA to include this (see here: https://imgur.com/a/jvQMewU)
Front Height
Measured from the inside of the top ledge, to case floor without feet.
Prototype Photos
432c Proto, Built in JIS 4.5u. The grey is very dark, so much that I have decided to not run a black variant of the board (at least for now).
Samples of the 533c Navy and 188c Dark Red. Please bear in mind, these are V1 protos. Read "The original Safa" for more info.
A look at the bottom, and engraving, which are not infilled stock. I recommend oil-based Acryllic paint to get a similar effect to how it looks on the JIS build
Color Options / Layouts
Every vendor will offer each variant as a base kit, excluding JIS - which will only be a base kit option for Japan (Basekeys).
ANSI WKL
ANSI WK
ISO WKL
ISO WK
JIS
A few QOL insights...
Brass weight coverage - made to cover as much of the alphas as possible. Being such a low profile board has its limitations, and this was as much coverage as I could reasonably achieve
Alignment pillars - a simple way to assemble the case and not worry about alignment. These cover both the X and Y axis'
USB tolerance - uh...yeah...kinda obvious. Also helpful for locating the port when not looking directly at it, as the entire ledge leads to this point.
Back and side profile - please ignore the ano color on this - it is not an option
Soundtests
https://www.youtube.com/watch?v=6pGhf0mRoGE
https://www.youtube.com/watch?v=eFWezluM5dM
https://youtu.be/9EkjwVae_2M
https://www.youtube.com/watch?v=8Y_Vnjhn_80
Credits
David & Evy - awesome PCB work, as well as general guidance
The entire MENA server - for having my back throughout the past year
Boyos - you know who you are, thank you for the constant encouragement
g1lbrt, Hueth, Lovi, Poesjuh, Simone - For your testing, building of protos, and honest feedback
Bachoo - for your early render work, as always, much love
Discord
Its my house, don't smash the doors in!
Support this project by adding this to your signature <3
Code: [Select]
[url=https://geekhack.org/index.php?topic=116273.0][img width=275 height=120]https://imgur.com/ntJaJ1c.png[/img][/url]
« Last Edit: Wed, 02 March 2022, 00:15:58 by paulgali »
Offline paulgali
    • SKME
Re: [GB] Safa TKL | GB Feb 14th - 28th
« Reply #1 on: Sat, 12 February 2022, 06:07:13 »
Reserved.
2022/02/15 - Added Side/Back profile
Brass inside TM
« Last Edit: Tue, 15 February 2022, 04:24:13 by paulgali »
Offline of_sam
Re: [GB] Safa TKL | GB LIVE! Feb 14th - 28th
« Reply #2 on: Sun, 13 February 2022, 12:02:00 »
Best of luck to you Baul. Awesome project.
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline kyuut
  • i just learned a new dance
« Reply #3 on: Sun, 13 February 2022, 12:02:23 »
i love this rectangle. lets go :cool:
TGR Jane v2 | TGR Jane v2 CE | TGR x SINGAKBD Unikorn 2.2 | SINGAKBD Kohaku R2 Prototype | HHKB Professional 2
Offline mmayhem17
    • Steam profile
« Reply #4 on: Sun, 13 February 2022, 12:03:16 »
thank you baul for making weight and abnt avail
Offline TRIGOZEN x TAO
  • Kanna + Keybort = Big Weeb
« Reply #5 on: Sun, 13 February 2022, 12:03:26 »
Very cool keyboard, hope I can get one. (thank you mr paul for designing this cool ciel clone but tkl)
Offline rookb
« Reply #6 on: Sun, 13 February 2022, 12:05:56 »
Nice  ;D
Offline Hetpet
« Reply #7 on: Sun, 13 February 2022, 12:06:49 »
Very nice keyboard
Offline Pyroo
« Reply #8 on: Sun, 13 February 2022, 12:07:08 »
Lets goo
Bunny enthusiast
Offline tunket
  • yes
« Reply #9 on: Sun, 13 February 2022, 12:08:03 »
Hello I would like this board I am very rich spoon magnate pleas contact me thamks in advance
Offline Kptburger
« Reply #10 on: Sun, 13 February 2022, 12:09:43 »
Lets ***ing go, baul.
Finally its here, best of luck with the GB, very cool rectangle, almost as cool as the person who made it  :p
i crave lasang
Offline herbologist
  • beige enjoyer. send help.
« Reply #11 on: Sun, 13 February 2022, 12:13:19 »
go baul! gib.
Sent from my Pixel 6 Pro using Tapatalk
Offline keai
  • jis>>>>>>
« Reply #12 on: Sun, 13 February 2022, 12:13:36 »
cool keybort
Offline hpetrovski
  • Osum
« Reply #13 on: Sun, 13 February 2022, 12:15:32 »
About damn time, good luck with the group buy Baul  :thumb:
Offline Udyrstruidor
  • uga uga
« Reply #14 on: Sun, 13 February 2022, 12:18:11 »
I will not be able to afford one right now but congratulations on this awesome project :thumb:
Poseidon60 | GrayStudio Space65 R1 | Ikki68 Aurora | CannonKeys Bakeneko60 | Gok 7V | NotFromSam Samice | CableCarDesigns Prophet | Geonworks Frog TKL | FancyAlice | Aeboards Praxis R2 | HHKB Pro BT | Geonworks F2-84 | UTD 360C | Elongate | Realforce 87u | GrayStudio Space65 R3 | TGR Jane v2 ME | TGR x Singa Unikorn R2.2 | Singa Kohaku65 R1 | Cherry G80-1824HBU | Matrix 8xv 3.0 | CableCarDesigns Prophet | Daji Seis Cero | Matrix 8xv 2.0add Xmas | TGR Jane v2 CE | Baionlenja Bias R2 | Merisi Ottantaquattro | TGR Jane v2
Offline carlfink
  • metal rectangle enjoyer, @carl.#1208 on discord
« Reply #15 on: Sun, 13 February 2022, 12:23:33 »
hand it over baul
Offline TibtibThePrincess
  • Look but don't buy
« Reply #16 on: Sun, 13 February 2022, 12:28:02 »
Safa so good
Good luck with group buy!!
Offline Phractals
« Reply #17 on: Sun, 13 February 2022, 12:36:27 »
Can't wait to get my hands on this. Best of luck with the GB baul!
Offline soundstage
« Reply #18 on: Sun, 13 February 2022, 13:21:05 »
Definitely buying this. And it's my first ever custom mechanical keeb!
Offline notquant
« Reply #19 on: Sun, 13 February 2022, 13:36:19 »
Great project - best of luck
Offline plag
  • Formerly pepperonichicken
  • i also go by plag
« Reply #20 on: Sun, 13 February 2022, 13:39:31 »
Good luck with gb! Very excited for this!
Offline mrvpixel
« Reply #21 on: Sun, 13 February 2022, 15:00:22 »
Good luck with the gb, awesome its finally happening
Verstuurd vanaf mijn AC2003 met Tapatalk
Offline linell
« Reply #22 on: Sun, 13 February 2022, 16:20:08 »
all hail Baul
bro this a **** set, just be thankful you even getting 1 base running fr
Offline goya_dechi
« Reply #23 on: Sun, 13 February 2022, 18:00:37 »
It's finally happening, wishing you Baul all the best and a successful GB!
Offline HalfScrim
  • no fun. not ever.
« Reply #24 on: Mon, 14 February 2022, 06:20:30 »
real stoked to get this, best of luck to you Baul
Offline soundstage
« Reply #25 on: Mon, 14 February 2022, 06:58:54 »
Grabbed my copy of Safa!
Offline whirlwind
« Reply #26 on: Mon, 14 February 2022, 11:21:33 »
BASED
Offline pallescence
« Reply #27 on: Mon, 14 February 2022, 14:49:15 »
Can't wait to get this in my hands! Best of luck with the group buy!
« Last Edit: Tue, 15 February 2022, 00:24:15 by pallescence »
Offline Ensaum
« Reply #28 on: Mon, 14 February 2022, 17:00:53 »
Do you have any shots of the side, back, and bottom of the board? Literally all the pictures I can find are top down shots.
Offline chits
« Reply #29 on: Mon, 14 February 2022, 18:46:16 »
you mention weight was a big design factor but I can't find a built weight anywhere. something I'd definitely like to know before purchasing.
Offline heresy
  • aka Ty
« Reply #30 on: Mon, 14 February 2022, 19:27:34 »
picked up a Red WKL with extra PCB and pp+half-alu plates, can't wait to have it in hand  ;D
Offline TjarleN
« Reply #31 on: Mon, 14 February 2022, 23:02:45 »
Pic with PP plate from Pauls Discord (Alu should be 150/200g more):
Offline mmayhem17
    • Steam profile
« Reply #32 on: Tue, 15 February 2022, 04:45:12 »
Brass inside
Enviado de meu SM-G780G usando o Tapatalk
Offline chits
« Reply #33 on: Tue, 15 February 2022, 18:16:27 »
thanks. super helpful.
Brass inside
Offline paulgali
    • SKME
« Reply #34 on: Wed, 16 February 2022, 01:53:48 »
Updated the post. Sorry, things kinda haywire and I missed this. But yeah, depending on the build anywhere from 1550g to 1700g
Offline 4milk
« Reply #35 on: Mon, 21 February 2022, 11:35:44 »
Beyond excited for this
Offline Jewpac Shakur
« Reply #36 on: Tue, 22 February 2022, 16:54:06 »
It's almost perfect. The red color is amazing, the sound is great and the price is very fair. It's a shame that I don't like the side profile. I will definitely be on the look for more stuff from you.
Offline soundstage
Re: [GB] Safa TKL | GB COMPLETE
« Reply #37 on: Wed, 16 March 2022, 21:59:37 »
Fell for this board and ordered one. Going to be my first custom keeb. Any update regarding the manu accepting your order?
