Author Topic: [GB] Argyle 60 (GB over, Order submitted to manu)  (Read 73360 times)
Offline Seoulcialite
    • MechSeoul
« on: Sat, 12 February 2022, 10:11:27 »
Design
TLDR: Pretty 60% keyboard with through-hole components on the sides.
Long Version:
I love the through-hole keyboards out there but I wanted one with a metal housing. So, I employed Jae of Prototypist (logistics and fulfillment), James of Alchemist Keyboards (housing design), and Yiancar (PCB design) to make my idea into a reality. To give it’s own flavor and to give a better view of the components, the components were split to the sides of the keyboard. The relatively high typing angle was also chosen to increase the visibility of the components. Even though 65% is my favorite layout by far, I couldn’t pass up the opportunity to match the symmetry of the housing with the symmetry of the 60% layout. Because the focus of the keyboard is the side partitions, the rest of the design was kept relatively simple.
Keyboard Details
  • Case: 8.0°
  • Layout: Standard 60% (no HHKB, no WKL)
  • Material: Aluminum (6063)
  • Colors: Black with black PCB, White with white PCB, Silver with white PCB, Navy with white PCB (same as Navy Allison
  • Mounting: Top mount
  • Plate: 1.5mm aluminum
  • Weight: 1.78kg (built)
  • PCB: Argyle60 by Yiancar (USB-C,QMK/VIA compatible, LEDs and USB port pre-soldered)
  • Layout options for both the PCB and Plate:
GB Details
  • Price: $395
  • GB Dates: February 19, 9:00AM EST to March 5th, 9:00AM EST
  • Format: FCFS
  • Units: 200
  • Site: ProtoTypist
  • Timeline: Q1 2023
Package
  • Top and bottom case
  • Aluminum plate
  • PCB
  • Through-hole components
  • Hardware for the case
  • Bumpons (injection molded silicone)
  • Hard shell carrying case
  • Acrylic covers
  • Diffusers
Options
  • Extra plates available in the following materials: brass ($55), aluminum ($30), carbon fiber ($25), POM ($25)
  • Extra PCBs in white or black ($30), components not included
  • Extra set of through-hole components ($30)
  • Extra acrylic cover ($5)
  • Extra diffuser ($5)
Updates
Prototype Build VODs
The first prototype was built by Jae which can be viewed here.
And the second prototype was built by Alexotos which can be viewed here.
Changes from the Prototype and IC
  • Tolerances in the window area to better fit the acrylic covers
  • Circular bumpons to rectangular AKB bumpons
  • PCB to have RGB LEDs and USB port pre-soldered
  • Removal of the argyle pattern on the PCB
Gallery
White Prototype:
Orange Prototype (color not available in GB):
Photos courtesy of Alexotos
Renders
IC Thread
Here
FAQ/Misc
  • Why are you only offering white and black PCBs?
    Due to the economies of scale, offering additional PCB colors would make them quite expensive.
  • Will you offer other PCB colors at a later time?
    We are currently considering and exploring this option.
  • Can I have the plate files?
    The plate files will be released after the fulfillment of the GB.
  • Why did you decide to remove the argyle pattern from the PCB?
    As other have suggested, the argyle pattern could clash with the colors, novelties, and theme of some keysets.
Special thanks to: Jae, James of AKB, Yiancar, and my homies at Bottom Klunk and Zap Cables.
« Last Edit: Wed, 04 May 2022, 02:50:11 by Seoulcialite »
    • MechSeoul
Re: [GB] Argyle 60
« Reply #1 on: Sat, 12 February 2022, 10:11:47 »
(Reserved)
Re: [GB] Argyle 60 (2/19 - 3/5)
« Reply #2 on: Sun, 13 February 2022, 19:22:51 »
Approved :thumb:
Offline Aiwanei
    • ThocKeys.com
« Reply #3 on: Sun, 13 February 2022, 21:26:21 »
So excited this is finally happening, GLWGB.
ThocKeys.com
Offline koolaidpapa
« Reply #4 on: Sun, 13 February 2022, 22:58:32 »
Love me some thru-hole kits. Can't wait!
Offline teddo
« Reply #5 on: Mon, 14 February 2022, 00:39:52 »
What a stunning beauty
Offline ktrezzi
« Reply #6 on: Mon, 14 February 2022, 02:40:34 »
Looks pretty sick...Would be nice to add an OLED in one of the spaces on the side imho? (I know am late, just a thought)
    • MechSeoul
« Reply #7 on: Mon, 14 February 2022, 08:02:15 »
The pinout on the right side is compatible with OLED. However, it wouldn't fit without taking off the right acrylic cover. Also, the OLED functionality has not been programmed into the firmware.
Offline Blackb1rd405
« Reply #8 on: Mon, 14 February 2022, 08:50:39 »
could you provide the sizing layout for the keycaps required as the some of the keycaps in the renders & images provided seem smaller than 1u.
Offline RoyalOak88
« Reply #9 on: Mon, 14 February 2022, 10:04:24 »
Do the extra PCBs come with extra through-hole components or do we need to by them separately?
Offline Nurseh
  • Sorry for always apologizing
« Reply #10 on: Mon, 14 February 2022, 11:18:55 »
Good to see this in GB  :thumb:
Offline pixelpusher
« Reply #11 on: Mon, 14 February 2022, 11:19:24 »
Glad it's coming to life soon.  Will do my best to pick up a silver or black.  Still need to decide :)
    • MechSeoul
« Reply #12 on: Mon, 14 February 2022, 11:27:15 »
There you go. The size has been labeled on the top right corner of the keycaps and any keys without a label is 1u. But for any layout, this GB or other, you can safely assume there will be no keycaps smaller than 1u. That would mean that the cap would be smaller than a switch which would make that cap impossible to mount.
    • MechSeoul
« Reply #13 on: Mon, 14 February 2022, 11:28:31 »
Extra PCBs only have the USB connector and the LEDs presoldered and does not include extra through-hole components. I have modified the original post to reflect this.
« Last Edit: Mon, 14 February 2022, 12:14:39 by Seoulcialite »
Offline lanyusea
« Reply #14 on: Tue, 15 February 2022, 02:36:53 »
will there be the HHKB top case in GB?
HHKB Type-s / 4x KMAC Happy / 3x Duck Viper v1 / 2x Duck Viper v2 / 4x Duck Viper Duck TCV3 / Red Scarf 77 / 2x Infinity 60 / 2x ALF HHKB / LZ-CE / FJELL / Canoe / Canoe PC / Canoe FE / ARES Prototype / 2x Ares / LC-CLSh / TX60 / YODA2 / E6-V2 / E6-V2 FE / CAMP LC60 / 2x EM 7 / 4x Leaf 60 / UHK / Project F / Polaris / 4x Duck Viper v3 / TX60 v2 / Thermal / Matrix Falcon / TX60 v3 / 2x TMO50 / 2x Dolice / Dolphin 65 / Dolphin 60 / Plenty of keycaps
Offline lanyusea
« Reply #15 on: Tue, 15 February 2022, 02:46:31 »
found in the IC page: no HHKB option in this round of GB
Offline hottrout
  • I'd Hit Dat Key
« Reply #16 on: Tue, 15 February 2022, 02:56:52 »
Em yes.  It has been a long time coming, but very please to see this at GB stage at long last.  Very good luck with it.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
    • MechSeoul
« Reply #17 on: Wed, 16 February 2022, 10:44:11 »
A giveaway is now live on Instagram here!
Offline Starius
Re: [GB] Argyle 60 (Live 2/19 - 3/5) (Giveaway 2/16 - 2/18)
« Reply #18 on: Fri, 18 February 2022, 20:41:09 »
I'm sad the argyle pattern was removed from the PCB.  I love that kind of detail on PCBs that set it apart and make it unique.
That being said, I'm gonna try to get one of these!
Offline pixelpusher
« Reply #19 on: Fri, 18 February 2022, 23:36:08 »
Does anyone know if it's possible to get diodes like in the original renders that have blue on them?  It would be cool to have something blue like that, but I'm pretty sure the only components like that are resistors, right?
« Last Edit: Sat, 19 February 2022, 00:11:53 by pixelpusher »
    • MechSeoul
« Reply #20 on: Sat, 19 February 2022, 00:13:12 »
I think I spotted black ones before but I'm not sure about blue. You could try a search for "1n4148" in Digikey or Mouser.
    • MechSeoul
« Reply #21 on: Sat, 19 February 2022, 00:17:45 »
It was a decision that could have gone either way really. My plan is to use clear sticker paper that you can print on with a regular inkjet or laser printer to print out designs that would match the keycap I am using and stick it on the bottom corners of the PCB. You can easily find these on Amazon.
Offline pixelpusher
« Reply #22 on: Sat, 19 February 2022, 00:18:51 »
Okay, I checked and it looks like the only thing available is the standard brown/black.  I suppose I could paint them!  You'd just have to be careful to mark polarity :)
Offline pixelpusher
« Reply #23 on: Sat, 19 February 2022, 00:26:18 »
That's a great idea.
Offline Starius
« Reply #24 on: Sat, 19 February 2022, 08:10:44 »
Looks like there are some blue ones here:
https://www.jaycar.us/1n4148-1n914-signal-diode-pk-5/p/ZR1100
Offline h40
    • h40.io
« Reply #25 on: Sat, 19 February 2022, 14:03:14 »
I was really hoping for orange in GB. Sadge.
« Reply #26 on: Thu, 24 February 2022, 18:08:08 »
My goodness it's happening, I'm in for one!!
« Reply #27 on: Tue, 15 March 2022, 04:33:54 »
Is there any compatible dust cover for the Argyle?
Offline Darthbaggins
  • PC Cannibal
« Reply #28 on: Mon, 11 April 2022, 12:11:31 »
Of course I missed the GB for this,  :-[
Offline Starius
« Reply #29 on: Wed, 05 October 2022, 22:10:44 »
Yep, me too.  I'm with ya, man.
Offline pixelpusher
Re: [GB] Argyle 60 (GB over, Order submitted to manu)
« Reply #30 on: Thu, 16 November 2023, 09:17:46 »
Adding a link to the update page for this keyboard.  This link should have all current information for the Argyle:
https://prototypist.notion.site/prototypist/57d8169dada041f6b52b1d091e3e2c97?v=449c85bd9a29455fa8d1330e23680c5a&p=a9a8b18f830d46e692c801cb5f73d6f6&pm=s
The board is currently in QC stage at Prototypist, but there is still a mountain of work to do (program each PCB and count out and package all PCB components).
« Last Edit: Thu, 16 November 2023, 09:19:40 by pixelpusher »
