Author Topic: [GB] Teleport Artisan Custom NumPad - finally after almost 1 year hard work live  (Read 3119 times)
Offline WaS
    • TELEPORT
Hey guys,
it took a while, but i am proud to present you today the start of our presale for the teleport artisan numpad.
282831-0
find more pictures below
As you might remember we started with the first experiments last summer. actually we wanted to start with the presale already in August 2021, but we were not 100% convinced of the quality of the pads, so we did countless more trials and experiments. Today we can offer you a very high quality product in a first limited edition.
Each NumPad is a handmade unique piece.
Due to the applied casting technique no pad is like another. After casting, each NumPad is deburred by hand, wet sanded and checked for defects. So you can be sure to call an absolute unique piece your own.
Features:
Weight Case: approx. 300g
Typing angle: 6°
Tray Mounted
VIA Compatible
Hot swap + Daughterboard
Included in delivery:
Case
Mounting Plate (FR4 or Brass)
Hot Swap PCB
Daughterboard
The preorder ends after Easter (18.04., 12 pm (CET)). The ETD is 30.04.2022.
The maximum quantity is 50 pieces for the founders edition (3 colors incl. brass plate, $155) and 150 pieces for the standard version (2 colors incl. FR4 plate, $126).
The Numpads can be purchased from the USA and the EU. Please set the correct country in the store so that the correct taxes and shipping fees are displayed.
TO THE PREORDER https://www.theteleport.de/en/collections/artisan-custom-boards
Follow us https://www.instagram.com/the.teleport/
to the [IC] https://geekhack.org/index.php?topic=113382.msg3066658#msg3066658
More Pictures
282833-1
Founders Edition
282835-2 282837-3 282839-4
Colorways with FR4 plate
282841-5 282843-6
Check it out guys https://www.theteleport.de/en/collections/artisan-custom-boards
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Approved
Offline zea
  • yeh
love the happy accident one, wish it was available with fr4 plate tho
Offline WaS
    • TELEPORT
If you want this i can organize that for you. Just send an pm.
