Author Topic: [IC] Cisne - 40% | Tented | Sculpted | Magnets | Sold out  (Read 10604 times)
Offline suika
  • suika#0001
    • Sonatina
« on: Fri, 25 February 2022, 05:55:06 »
A 40% keyboard you've never experienced before.
https://imgur.com/a/kVNN0sl
Pre-order (live now)
- my website
- First Come, First Served (no raffle)
- 100 units total
- Estimated shipping date is Q3 2022
Features
- Tented Top Case (5°) with Magnets
- Sculpted Bottom Case with Magnets
- Gasket Mount
- HHKB Alice-like Layout
- 8° Typing Angle
- 2.0 kg (fully assembled)
- Optional Rotary Encoder
- Hotswap PCB
- Plate Foam + Thin PE Foam
Color
- Mirror black (hand-polished and anodized)
- Matte black (fine sand-blasted and anodized)
- E-white
Supported Layouts
Typing Sound
3mm EVA, 0.5mm PE, BSUN + burgundy stem
Package Contents (example)
- Top Case with Magnets x 1
- Bottom Case with Magnets x 1
- Plate x 2
- Hotswap PCB x 2
- Flat Cable x 1
- Stabilizer Foam x 8
- Poron Gasket x 12
- Plate Foam (between plate and PCB) x 2
- Thin PE Foam (between the plate foam and PCB) x 2
- Custom Mold Silicone Rubber Foot x 4
- Mini Daughterboard x 1
- JST SH Cable x 1
- M2 Screw x 1
- (Optional) Rotary Encoder + Knob
Price
269 USD+ and Shipping (40 USD+)
More Info
- My Website
- Cisne Discord Channel
- My Discord Channel
« Last Edit: Sun, 17 April 2022, 06:08:08 by suika »
Offline Mecxs
Interesting.
Do you have an exploded view / internal photos showing how you've done the magnets?
Also, what is 'stabiliser foam' and why is there 8 of it included?
What materials are the case / plate made from?
What firmware will the PCB use?
None of the videos clearly show the USB port. Could you please post a photo of it? And confirm what USB connector it uses?
What is the single screw used for?
Your link for the sound test is broken - http://sndup.net/pz7b
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
this alignment hurts my head. sounds cool tho
Offline AASH
Interesting.
Hey, not the designer but I've been following this in pre-ic.
-Case is alu
-Plates are TBD, proto used alu and copper, this is a question in the IC
-The PCB uses QMK
-It's USB-C, I don't have a picture of the port tho
-I believe the screw is for the daughterboard.
I hope that helps. Also, glwic suika, love your work :)
40s, with love
Offline patcoll
  • !40s
This looks so good, I thought I was taking March off but I guess not. Great job suika
Offline fortaye
  • 40's 40's 40's
What a beauty! I’ll be following!
Offline MelonBred
Been following this one for a little while, and I'm glad to see this come to IC! Really love the unique case design and the gloss finish. Looking forward to group buy.
Offline PeppyToad
Let's go suika!
Offline ShandonCodes
I love how you really put everything you love/are interested in in one keyboard. Excited to see wear this goes.
Sent from my LE2115 using Tapatalk
Offline adobau
  • https://adobaulabs.com
    • adobaulabs
finally the suikalice 💖 super can't wait for this!!!
Offline stidal
  • milo#3939
pretty interesting!
transition tkl // aksara ce // bully // valhalla // voyager // rs60 // adiuvare // ciel60 // jules // prime e // ut47.2 // sequence // bumper // q1 // gaff60
Offline Rpmorrison10
I didn’t realize this was base kit compatible. I’m liking it even more now!
Offline suika
  • suika#0001
    • Sonatina
Okay I still get the responses from the IC form but the pre-order has already been live: https://sonatina.jp/store
Offline neoknob
    • Neo knob
This looks amazing but pricing is bit higher for a 40% keyboard.
Offline suika
  • suika#0001
    • Sonatina
Very good point. Here's the reasons why this keyboard is expensive:
- The sculpted design needs more milling time.
Which means the production costs getting higher than the usual cases.
And these are nearly 1,800g total, which is super heavy for 40%.
- This keyboard needs 2x plate and pcb (2 each, 4 total).
This also raises the production cost.
- There are 3 surface finishes (polished, anodized, and coating) on this round.
- Only 100 units available
I could not take advantage of the volume discount because of these factors.
« Last Edit: Fri, 08 April 2022, 17:25:04 by suika »
Offline VellFlamm
Re: [IC] Cisne - 40% | Tented | Sculpted | Magnets | GB is live now
« Reply #15 on: Sat, 09 April 2022, 03:56:55 »
Me daily-ing Adélie ($550), Cornelius ($430), and planning to buy Menhir ($500) "Damn this **** is dirt cheap for a 40% keyboard"
Offline suika
  • suika#0001
    • Sonatina
« Reply #16 on: Sat, 09 April 2022, 04:07:28 »
Thank you for saying that 😂😂😂 Actually, the profit margin of this keyboard is relatively low. Plus, the production costs kept getting higher and higher in this situation
Offline hottrout
  • I'd Hit Dat Key
« Reply #17 on: Mon, 11 April 2022, 09:09:01 »
I love how this looks and the effort in the design but without dedicated numbers I find it not a daily driver.  I do wish you luck though and admire creating something original in a sea of 60% and TKL boards.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
