Author Topic: [IC] NESON DESIGN | The 700E Series 70% keyboard · Group Buy closed ·  (Read 51220 times)
Offline Simen
What’s up GeekHackers, this is Simen from: NESON DESIGN. It has been a while since we last posted here.
Please follow our Instagram:https://www.instagram.com/neson.design/ or join our Discord:https://discord.gg/g6YQHD9e4b for the latest updates!
The 700E Series 170 units Raffle Sale will star from Wed June,8th,2022 0:00 EST to Sat June,11th,2022 12:00 EST!!
The 700E Series Group Buy link:https://geekhack.org/index.php?topic=117412.0
In 2019, we designed a 70% keyboard – cross, and it has been one of our favorite designs. Today we are going to introduce to you to a revamped design of the cross – The 700E Series.
5/8/2022 Updates
1. 700E WK Photos
Wine Red WK
286116-0
286118-1
286120-2
286122-3
Black WK
286124-4
286126-5
286128-6
286130-7
2. 700E Group Buy Pricings
The price for the keyboard will cost $460~$480 USD. Due to the crazy price hikes on the chips and raw ingredients, we have reserved some buffer for unforeseen fluctuations. There will be a limit of 150 keyboards for this group buy. We will provide more details in the future group buy posting.
3. Streamers to showcase 700E
We will ship the 700E to Alexoto and Taekeyboards for building on stream. We have also posted a typing demo on our Instagram. Please check out the link below and join our discord for any discussions!
https://www.instagram.com/tv/Ccpm9sYATLh/?utm_source=ig_web_copy_link
Catalog:
1. Keyboard Specs
2. Keyboard Design
3. Design Changes Log
4. Prototypes Ver.1-Ver.3
5. Q&A
1. Keyboard Specs:
    - Layout:70%   WK / HHKB
    - Mounting System:Gasket Leaf + Spring Mount
    - Typing Angel:9° (front height 19.3mm)
    - PCB:1.2mm solderable(does not support hot-swap), Type-C with daughter board. PCB supports QMK and VIA, designed and manufactured by Astro
    - Plate: Default Aluminum, PC as optional
    - Layout picture:
     Keyboard Exploded View:
Parts included with the kit
①    Keyboard itself(Top/Middle/Bottom Case, Plate, PVD Badge, Aluminum Weights)× 1
②    1.2MM PCB and daughter board × 1
③    0.5MM PE foam ×1
④    3.5MM poron case foam ×1
⑤    C shaped gasket ×10
⑥    1.5MM poron bottom case foam ×1
⑦    LED diffuser ×1  Reflector ×1
⑧    PCB stabilizer foam ×10
⑨    USB cable ×1
⑩    Bumpons ×2
⑪    Instruction pamphlet x1
2. Keyboard Design:
Prototype Photos:
2-1: Inspiration for Isolated Spacebar:
The inspiration for the 700E’s isolated spacebar design came from some older keyboards with customized large spacebars. They allow the thumb to have more contact surfaces with the keycap, which provides a more comfortable and satisfying typing experience. We wanted to replicate that design but knowing it’s difficult to obtain a one-off spacebar keycap, we decided to achieve a similar result by shifting the spacebar downward, isolated from the main cluster.
2-2: Keyboard External Designs:
We continued the design language of the N series to the 700E. In order to achieve a balanced typing experience, we separated the PCB into two parts, left one for alphabet, and the right one for function and arrow keys.
IC Form: https://forms.gle/rHTBJRoVFVN6suzV9
If you are interested in the keyboard or if you have any suggestions, please let us know by filling out the IC form or tell us on discord. We sincerely appreciate everyone's participation and suggestions. Discord:https://discord.gg/g6YQHD9e4b
VER.1 Prototype
· 70% layout as the fundamental design
· Tested multiple top cases with different positions of the spacebar
· 9° Typing Angel
VER.2 Prototype
· Finalized the shift distance of the spacebar
· Tested three different thicknesses of LED diffuser
· Tested three different thicknesses of side profile
· Modified the fillet radius of bottom case
· Adjusted LED layout and improved LED drive circuit design
VER.3 Prototype (in production)
· Modified gasket support to avoid interference with stabilizer
· Modified the badge design and upgraded it to PVD brass
· Modified the placement of the internal screws and simplified installation
4. More Prototype Pictures
VER.1 Prototype
(with different spacebar distances)
In August 2020, we got our first prototype. We made several top cases with different positions of the isolated spacebar. With repeated testing, we confirmed the idea of an isolated spacebar is possible. If you like to install your spacebar upside down to enhance your typing experience, then you should have an even better experience with this design.
VER.2 Prototype
(External Design, Internal Design, LED Diffusion Design)
In September 2020, we made our second prototype to confirm the distance we want to shift the spacebar from the main cluster. We also made three different bottom cases to verify the best thickness for the LED diffuser and revised the size of the Fillet radius.
LED Diffuser Design
For the diffuser, we followed the same design language of the N series. We spent a lot of effort to improve the diffusion on this keyboard. We have divided the diffuser to three parts, made of different materials. The top part is made of transparent acrylic, middle part made of a sheet of 0.85mm reflector, and the bottom part made of matte white acrylic. We have also increased the number of LEDs from 32 to 64.
VER.3 Prototype (Being made)
Fast forward to February 2022, we have started manufacturing the third prototype. Modified gasket support near spacebar,resolved issues with certain stabilizers interference. We have also changed the badge at the front to be made of PVD brass to enhance the look of the keyboard.
5. Q&A
1: What are the color options?
      Black, Silver, Wine Red.
2: What is the limit?
      Limited to 150 keyboards.
3: Where do I get the latest updates?
      Please join our discord channel or follow our Instagram.
4: I don’t like your designs; can I say something?
      Of course. We accept feedbacks from everyone.
5: How much will 700E cost?
      TBD
6: Will there be any sound tests or test builds?
      Pending. We will make some if enough people request.
7: Can the weights be made of different materials?
      TBD
Ending:
Based on our testing so far, we have confirmed that an isolated spacebar can bring a different typing experience. The shifted space at can be a new typing experience without changing most people’s typing habits and styles.
We hope that the product is perfect when it arrives the owner’s hands. We will provide further updates once the third prototype is finished and show you the beauty of the assembled product. If you are interested, please join our Discord to discuss further and get the latest updates!
« Last Edit: Sun, 12 June 2022, 23:32:51 by Simen »
Offline Simen
Re: [IC] NESON DESIGN 700E Series
« Reply #1 on: Sat, 26 February 2022, 04:15:24 »
-Reserved-
« Last Edit: Mon, 09 May 2022, 01:16:57 by Simen »
Offline nullinasou
« Reply #2 on: Sat, 26 February 2022, 04:21:56 »
Looks pretty unique and interesting.
Any particular reason for the lack of wkl option?
Offline linell
Re: [IC] NESON DESIGN | The 700E Series 70% keyboard
« Reply #3 on: Sat, 26 February 2022, 05:02:19 »
hhkb blockers on a tkl is beautiful
bro this a **** set, just be thankful you even getting 1 base running fr
Offline kingnestea
« Reply #4 on: Sat, 26 February 2022, 05:45:31 »
give it to me, babe
Offline Neely_12
« Reply #5 on: Sat, 26 February 2022, 07:09:59 »
How’s the sound without foam? Would definitely consider, but I’m not a thocker myself.
Offline Yehuo.
« Reply #6 on: Sat, 26 February 2022, 07:27:35 »
Looks really cool. Definitely interested.
Offline darthcapn
« Reply #7 on: Sat, 26 February 2022, 15:20:53 »
That is a funky looking spacebar! I like it
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline HappyB0T
  • I'm a Piggie
« Reply #8 on: Sat, 26 February 2022, 23:16:48 »
That exploded spacebar explodes my brain. Bottom row pcb options are a little funky. I'll try reading th ic again but i'm stuck thinking about bottom row.
Offline Xury46
« Reply #9 on: Sun, 27 February 2022, 02:16:09 »
Wow, this is such a cool layout. I love the bottom row options and the exploded spacebar, so unique!
Offline japancakes
« Reply #10 on: Sun, 27 February 2022, 02:35:57 »
Exploded space is hot
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #11 on: Sun, 27 February 2022, 05:19:24 »
Man, you can't show me such a beauty and tell me it doesn't support ISO...
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline hkhawk
« Reply #12 on: Sun, 27 February 2022, 09:44:25 »
I really want to try the exploded spacebar, my hands are too big
Offline kapowaz
    • kapowaz industries
« Reply #13 on: Sun, 27 February 2022, 11:22:33 »
One of the most unique and interesting designs I’ve seen in a while. But please, support ISO?
Offline finalarcadia
« Reply #14 on: Sun, 27 February 2022, 13:51:06 »
Very nice design and layout, I like it  :thumb:
Offline Chuuu
« Reply #15 on: Sun, 27 February 2022, 19:16:53 »
any 10u spacebar support avail
Offline Dunne
    • Dunne
« Reply #16 on: Mon, 28 February 2022, 08:48:11 »
I actually really really like this, good work!
Offline HappyB0T
  • I'm a Piggie
« Reply #17 on: Mon, 28 February 2022, 12:45:07 »
your use case checks out ;)
Offline Finite
  • peer pressured into mk hobby, pls send help
« Reply #18 on: Tue, 01 March 2022, 16:22:54 »
If you want to try out how the exploded spacebar feels, you should check out the Curio and Relic by Cain/MechVault since he already made quite a few 40% keyboards with this exploded/isolated spacebar design implemented in it. Glad to see that more keyboards will feature this design since it definitely feels good to type on, hopefully this TKL will help the idea get more mainstream than just on the 40% server.
Offline York Chan
« Reply #19 on: Tue, 01 March 2022, 20:54:49 »
The layout of the keyboard is very much like the emoji R8R8 from China
Offline York Chan
« Last Edit: Tue, 01 March 2022, 20:58:35 by York Chan »
Offline Simen
« Reply #21 on: Wed, 02 March 2022, 00:08:50 »
Thanks for the suggestion, but we want to do more than just exploded spacebar.
Offline Simen
« Reply #22 on: Wed, 02 March 2022, 00:10:43 »
iso is a good proposal, maybe we will make it compatible. :D
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #23 on: Wed, 02 March 2022, 15:00:24 »
Offline Zyrophr
  • https://zyrophr.com
    • zyrophr.com
« Reply #24 on: Wed, 02 March 2022, 15:28:53 »
I'm in, I need this in my life, this is absolutely genius.
Would love it to be WKL tho, sad but np </3
French keyboard streamer
Offline mr_foggy
  • neue = nope
« Reply #25 on: Fri, 04 March 2022, 06:12:03 »
finally something different. will follow this very closely.
Offline EdgeOfInfinity
« Reply #26 on: Mon, 14 March 2022, 15:04:21 »
very unique, love the look of the spacebar.
Offline Vanquish
« Reply #27 on: Mon, 14 March 2022, 15:57:04 »
This is a great design. Could you elaborate more on the spring mount design? I haven't heard of this before. I will keep an eye on this IC!
Offline JQ27
« Reply #28 on: Mon, 14 March 2022, 17:54:20 »
Offline Ghostinn
« Reply #29 on: Thu, 17 March 2022, 18:41:10 »
Drooling at this. Would love to hear a sound demo just to see how the isolated spacebar sounds. Really considering making this an insta-buy for me
Offline peach
« Reply #30 on: Thu, 28 April 2022, 01:09:02 »
GB when?
Offline Nonnegaard
« Reply #31 on: Tue, 03 May 2022, 02:40:56 »
holy **** this is beautiful. i actually think i would enjoy using the isolated spacebar more than i initially thought, so this might have to go in the collection.
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
« Reply #32 on: Tue, 03 May 2022, 11:01:29 »
I was shattered after not winning a n6-65. This is a must have in the collection. Beautiful board!
Offline lush_bunny
« Reply #33 on: Tue, 03 May 2022, 11:26:48 »
Isolated Spacebar is so much sexier than other exploded layouts. Maybe it's the maintained symmetry? Either way I really hope this IC and eventual GB succeeds, my dude.
Offline darthcapn
« Reply #34 on: Tue, 03 May 2022, 22:51:14 »
I like how neat it looks yet has an element of chaos! Glwic and gb! Very interested.
Offline Simen
« Reply #35 on: Mon, 09 May 2022, 01:03:29 »
Latest updates on the main post!
« Last Edit: Mon, 09 May 2022, 01:17:21 by Simen »
Offline Sandy
  • Formerly cogitoergofemme
  • Sandy - Peach Tray Maker
    • the peach · studio
« Reply #36 on: Sat, 21 May 2022, 17:57:09 »
I would be interested to hear from someone who has smaller hands how this feels. I can imagine for someone with bigger ones the spacebar position would be really nice but for some others I'm not sure.
Maybe have a friend test it out I think there are 4 people on your team right? I remember from seeing your graphics and reading the neson studio bio.
🍑C11🍑KWA.6🍑GPK60 47-GR1RE🍑Vast60🍑Rose60🍑EHKB🍑Viktus Sinne🍑Boop65🍑Jelly60 Pro🍑Fuji65🍑Ginkgo 65🍑S7.7🍑Treasure Type-9 II🍑Thermal R2🍑Jelly 60🍑
Offline Cylent
  • Formerly cylentshadows
« Reply #37 on: Sat, 21 May 2022, 18:16:47 »
I like everything about the layout and design except for the exploded spacebar.  :(
Offline Adelscott
« Reply #38 on: Sat, 21 May 2022, 18:52:16 »
This exploded spacebar is what makes it unique.
Please think about ISO users, add a split left shift to your "alice style" keyboards
Offline Nonnegaard
« Reply #39 on: Tue, 24 May 2022, 07:59:28 »
you know, that and all the other cool design elements.
Offline SDKCAMPING
« Reply #40 on: Tue, 24 May 2022, 16:32:07 »
the spacebar is an interesting choice but what i really love is the piece under the 6 key cluster above the arrows :D
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline Simen
« Reply #41 on: Sat, 28 May 2022, 23:20:45 »
Don't worry, we've done a lot of testing, and it's accurate to say that this design is more helpful for users with smaller fingers! :thumb:
« Last Edit: Sun, 29 May 2022, 00:56:28 by Simen »
Offline jollyeskimo
« Reply #42 on: Mon, 06 June 2022, 23:04:37 »
Are the badge LED and the LED strip able to change colors, and can they be turned off independently of each other (in VIA?)
Any animations on either of them?
Offline ClickClack.io
  • Find us on clickclack.io
    • clickclack.io
« Reply #43 on: Tue, 07 June 2022, 23:25:33 »
Raffle Live
► Quantities: 150 regular units + 20 special collaboration units
► Price: $470 / $535 (collaboration units)
▼ Shipping: 3KG for Alu Weight and 4KG for Copper Weight, Shipping Estimate (finalizing may slightly adjust)
► Estimate Fulfillment Timeframe: Q4 2022
► Sale Format: Raffle
► Raffle Signup Time: Wed June, 8th, 2022 00:00 EST - June, 10th, 2022 23:59 EST Sat June, 11th, 2022 12:00 EST
► Raffle Form:
► How Raffle will be executed:
    1. Absolutely no duplicated raffle entries (we will review every entry).
    2. After remove duplicate entries, we will run random selection programmatically. We standby the fairness and integrity of random selection. You will get an email about raffle result. If you are selected, you will receive your unique discount code.
    3. With your discount code, you will be able to make purchase within 48 hours.
► If I am selected, where to make purchase:
     1. 700E will be available on our website with $999.
     2. Add-ons will be listed at normal price. If you intend to purchase them, make sure to add Add-ons to your cart along with your keyboard kit.
     3. When you checkout, make sure to apply your unique discount code to purchase 700E at correct prices ($470 / $535).
Offline Adelscott
« Reply #44 on: Wed, 08 June 2022, 12:48:12 »
In the end there's no ISO ?
Offline Simen
« Reply #45 on: Thu, 09 June 2022, 02:53:58 »
iso has been added :thumb:
Offline LegendsWorks
  • thocc
Ba da ba ba ba im loving it
Offline Adelscott
« Reply #47 on: Thu, 09 June 2022, 12:06:51 »
Maybe I'm blind but I don't see it written anywhere in first post ? The supported layout render still shows ANSI only, no close render of the pcb/plate. BTW is it an universal plate ?
Offline Simen
« Reply #48 on: Thu, 09 June 2022, 23:31:08 »
We've updated to the GB link!he is not a universal plate.
Offline MrEsosmao
Re: [IC] NESON DESIGN | The 700E Series 70% keyboard · Group Buy closed ·
« Reply #49 on: Wed, 15 June 2022, 17:43:02 »
I need this in my life. Reminds me of a centurion bot.
