Author Topic: TECSEE Switches  (Read 6436 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
TECSEE Switches
« on: Fri, 04 March 2022, 03:42:10 »
TECSEE Coral Tactile Switch
SPEC
  • Nylon Top and PME Bottom
  • 5 pin (PCB mounted)
  • Nylon Stem
  • Tactile
  • Spring length about 1.4mm
  • Actuation Force - 55+/-10 gf
  • Bottom Force - 68+/-10gf
  • Pre-travel - 1.8+/-0.4 mm
  • Total Travel - 3.0+/-0.4 mm
  • 60 Million clicks
TECSEE Jadeite Linear Switch
SPEC
  • UPE Top and PC Bottom
  • Stem Material: UPE
  • Linear Switch
  • Spring around 22mm in length, 2-stage
  • Actuation force: 55+/-10gf
  • Bottom force: 63.5+/-10gf
  • Pre-travel: 2.1+/-0.4mm
  • Total travel: 3.8+/-0.4mm
  • 60 Million clicks
TECSEE Ice Grape Linear Switch
SPEC
  • PC housing
  • Stem material: UHMWPE
  • Linear Switch
  • Spring around 22mm in length, 2-stage spring
  • Actuation Force: 55+/- 10gf
  • Bottom Force: 63.5+/- 10gf
  • Pre-travel: 1.9+/-0.4mm
  • Total Travel: 3.8+/-0.4 mm
  • 60 Million clicks
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: TECSEE Switches
« Reply #1 on: Wed, 09 March 2022, 01:56:15 »
TECSEE Ice Candy Linear Switch
SPEC
Housing Material - PC
Stem Material - Nylon
Linear Switch
Spring length around 22mm
Actuation Force 55+/-10gf
Bottom Force 63.5+/-10gf
Pretravel 2.1+/-0.4mm
Total Travel 3.5+/-0,4mm
60 Million Clicks
