Author Topic: Chicony  (Read 6271 times)
Offline RamaBot
Offline Moeks
Chicony
« Reply #1 on: Wed, 06 October 2010, 09:25:23 »
Hi there,
Did you buy one of these RamaBot or anyone else for that matter, to see what they are like? I use an IBM Model M currently, I wonder how these feel in comparison.
Offline Zenarchy
Chicony
« Reply #2 on: Fri, 29 October 2010, 17:24:40 »
Quote from: Moeks;230430
Hi there,
I've just bought one of these keyboards. It arrived pretty quickly (faster than they said on the ebay listing).
Compared to the model M I've been using over the last few yeas (or any other mechanical keyboard I've used in the past), describing them as clicky is a bit of a stretch imho.
I haven't taken it to bits to check (and probably won't bother), but it definitely feels like a rubber dome keyboard to me and not quite as tactile as an old HP rubber dome one I have (though the keys do seem a bit noisier which slightly gives that impression when typing quickly oddly - they have a bit more of a ping to them when they're released I think).
There's a video on youtube of this keyboard, which along with the 'clicky' description in the ebay description, lead me to think it might be a mechanical keyboard. I'm guessing the youtube video is just someone hammering the keyboard heavily which makes it sound more clickly than it really is (unless I've got a look alike keyboard and theirs really was mechanical). Still for a £10er new and delivered it was worth a gamble, and I've seen much worse keyboards on sale in computer shops for more than that.
The one I received doesn't have chicony written on it anywhere I spotted, nor on the box it came in, or the slip of paper with the FCC stuff on it (though there was a sticker with the model number mentioned in the listing). Only FCC compliant, and made in china and some other serial numbers that I could see unless I'm missing it. I'm not sure if this is to be expected (if they're making them for other companies as the ebay listing suggests and these are surplus or something then maybe they wouldn't include the chicony branding).
On the plus side, it does look pretty sturdy and has a decent weight to it and it feels nicer (to me at least) than the other rubber dome keyboards I've got gathering dust in the cupboard, and doesn't feel quite so much of a leap moving from the Model M to it as some of the others (keys seem to be about the same size and spacing and with a reasonable amount of travel).
For £10 including delivery I can't complain really, even if it wasn't quite what I was hoping for, and it'll come in handy as a spare until I get around to getting another model M as a spare. Or I'm tempted to try to remove the lettering (it appears to be printed rather than lazered on or whatever they do on the model M's) to make it completely black.
You should bear in mind I'm new to this forum and this is my first post. So this is just my somewhat inexpert (compared to many of the people here) impression.
Offline Zenarchy
Chicony
« Reply #3 on: Fri, 29 October 2010, 19:53:25 »
Thanks for the warm welcome :)
I had a look at your FCC reference, but I can't spot those codes anywhere on this keyboard. There's an FCC compliance statement on the back of the keyboard, and :
CANADA ICES-003 CLASS B / CANADA NMB-003 CLASS B
on there, just above the made in china text, but I suspect these are just the standards that it's complying with.
Also a couple of serial numbers but these don't match the codes either.
Since making that post above I thought I'd better actually plug it in and use it for a bit to make sure it was working properly before anyone else got one (previously I'd only given it a quick check before putting it back in the box).
It seems to be working fine (though I forgot to check the mouse port on it), and to be fair to the ebay seller, I can perhaps understand why he's describing it as clicky as it does make a bit more noise and have a nicer feel to it than the other rubber dome keyboards I've got (assuming it is a rubber dome and not some soft switch I'm not aware of - as I say I'm not an expert).
After using it for a couple of hours, and considering it was only £10 I'm pretty happy with it. Infact it felt a bit nicer and less of a leap from the full size model M than the smaller IBM M2 clicky keyboard I had to use for a couple of days recently (this is only my personal impression and I'm sure many would disagree with me - I find the M2 a bit too noisy and I can't type as quickly on it - whether this is because I'm adjusting my typing style to try to make less noise or the keys are spaced differently, I'm not quite sure).
I think I might sell the M2 now and keep this as a spare while I go hunting for another full size model M.
Offline jeyoung
Chicony
« Reply #4 on: Sat, 30 October 2010, 07:58:31 »
I bought one from the seller for use at the office. I'm hoping that it will feel like the IBM Chicony-made keyboard that I use at home.
[I've pretty much given up on acquiring keyboards with mechanical switches (besides the G84-4100 that I use with my netbook), as I realised that I prefer rubber domes. This leaves me with the Topre, which is a costly option for me, or higher-end rubber domes.]
Offline Zenarchy
Chicony
« Reply #5 on: Sun, 31 October 2010, 13:05:41 »
Quote from: jeyoung;240444
You might be in luck. Curiosity got the better of me and I popped a few keys off. It's definitely a rubber dome keyboard.
Would be interesting to hear how you get on with it when it arrives compared to your other keyboard (and if it really is half decent or it's just that my other rubber keyboards are even more rubbish :D).
Offline jeyoung
Chicony
« Reply #6 on: Mon, 01 November 2010, 07:30:55 »
Quote from: ripster;240790
Meh.  Reminded me of the IBM Model M rubber domes.
How come? I thought the IBM Model M was regarded highly :)
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
Chicony
« Reply #7 on: Mon, 01 November 2010, 15:30:38 »
Yeah, the buckling spring ones. The rubber dome variants (less common, but they exist) aren't even particularly great for 'domes, and apparently relatively noisy in spite of being called "quiet touch".
Offline jeyoung
Chicony
« Reply #8 on: Thu, 04 November 2010, 16:18:44 »
Finally got the Chicony KU-8933 after a week of waiting -- although shipped First Class the very next day, the keyboard got lost in processing.
The keyboard is as tactile as the IBM KB-7953 but feels cheaply built in comparison. Overall, it is not a bad purchase at £10 (slightly more than the £1.50 that I paid for the IBM) and is a good fit for the office.
