Author Topic: Razer Huntsman V2 - possible to eliminate rattle with grease?  (Read 1750 times)
Offline Fandom
« on: Thu, 24 March 2022, 20:30:22 »
Hi folks,
I’m considering buying a razer huntsman v2 TKL but I’m quite worried about the rattle from all these metallic wires on all key switches. Is it possible to grease those and reduce, if not eliminate, all that rattle?
Topre RealForce 88 UB. Previously: Filco Ninja Majestouch 2 (brown) + CM Storm Quickfire TK (brown)
Offline Sup
Re: Razer Huntsman V2 - possible to eliminate rattle with grease?
« Reply #1 on: Fri, 25 March 2022, 02:59:48 »
Some people tried it and it seems to work.
current
Coming soon
