Author Topic: [IC] GMK Regal | Group Buy Live  (Read 48993 times)
Offline JonoColwell
« on: Tue, 29 March 2022, 00:12:52 »
Group Buy Thread Here
GMK Regal
Interest Check Form
Concept:
I really liked Phantom, however I wasn't absolutely sold on the yellow, I felt like it just prevented me from matching it with whatever I wanted and it wasn't as clean as I liked, in addition the set is kind of old and the kitting's not quite there in my opinion, thus goes my epic journey to get a set that's a more refined Phantom and also slap in some relegendables
GROUP BUY JULY 1
Colours:
Pantone 2695 Purple
RAL9016 Traffic White
Note, I have seen RAL sample for 9016 and I have the swatch for Pantone 2695 on hand, however my camera/photography skills are bad, I've ordered a RAL sample as well as the plastic pantone chips for 2695 and I'll get some photographs of those when they arrive and do colour matching against those.
Kits:
Base Kit:
Novelties Kit:
Extension Kit:
Relegendables Kit:
HIBI cap
Filigree Deskmat
For some reason imgur won't upload this as a .png so it has to be atttached here, I don't know why but it is what it is.
286604-0
Lion Deskmat
Update 05-04-2022: I've removed the novelties from the base and split them out into their own kit, taking a look at the GMK quotes it's going to add some cost for getting novelties as well as the base kit but most people don't seem to want the novelties so it is what it is.
Update 07-04-2022: Added 1.25 u R3 tab and 1.5u R3 enter for the 40s people.
Vendors:
OCE/Australia: Daily Clack
Europe: MyKeyboard EU
SEA: iLumkb
NA: Mechs & Co
CA: DeskHero
CN: Zfrontier
KR: GEONWORKS
Collaborations:
LP Cables
Sinpra Caps
Kook Caps
Arunika Keycaps
Primecaps
Additional Renders:
More may be to come
Bean by Kingk22
Constellation by AEBoards
Endash by FinderWorks
Praxis by Ivery Boards
Wombat by Impulse Boards
Note, for wombat, I've got the physical boards being finished at a plater, so expect an interest check on that one soon.
UPDATE: 25-05-2022
  • Updated novelty renders to use accepted art from GMK
  • Added collaborations
  • Added Deskmats
  • Updated all kits to latest version
  • There is a hibi cap just waiting on renders, that has also been confirmed for manufacturability
Update 31-05-2022
  • Added hibi cap renders
  • GB date announced
Update 27-06-2022
Addes Geon as Korean vendor
Updated some older renders
« Last Edit: Fri, 01 July 2022, 18:55:28 by JonoColwell »
Offline L-Ron
Re: [IC] GMK Regal
« Reply #1 on: Tue, 29 March 2022, 00:18:18 »
Love the colourway and the chunky base kit. GLWIC!
Offline clickpig
  • naisu naisu naisu
Re: [IC] GMK Regal
« Reply #2 on: Tue, 29 March 2022, 00:19:06 »
Consider my interest checked.
Thoughts on moving the novs to a child kit to cut down potential base price?
Offline LittleAad
  • Hello
Re: [IC] GMK Regal
« Reply #3 on: Tue, 29 March 2022, 00:29:16 »
Incoming 200 dollar base kit.
Not a fan of your kitting, but I can see why some may appreciate it.
Why aren’t you using a stock color for the white??
Offline JonoColwell
Re: [IC] GMK Regal
« Reply #4 on: Tue, 29 March 2022, 00:34:21 »
I thought about it, then I thought, I don't really want to do that.
I looked at the stock whites and they weren't quite what I wanted.
Offline Dingo..
Re: [IC] GMK Regal
« Reply #5 on: Tue, 29 March 2022, 00:56:32 »
Interested. Very nice colour choice
Offline rainkeebs
  • rainkeebs.mx
    • Rainkeebs
Re: [IC] GMK Regal
« Reply #6 on: Tue, 29 March 2022, 01:28:03 »
your kitting is really bad this is not going to make moq
Offline Silk
Re: [IC] GMK Regal
« Reply #7 on: Tue, 29 March 2022, 01:33:59 »
have you met this man
Offline JonoColwell
Re: [IC] GMK Regal
« Reply #8 on: Tue, 29 March 2022, 01:54:25 »
If it's not for you it's not for you. It should have compat for 40% keyboards in there anyway so not sure what you mean when you say kitting is bad
Offline Ensaum
Re: [IC] GMK Regal
« Reply #9 on: Tue, 29 March 2022, 02:02:54 »
Some thoughts on kitting so no one is really giving suggestions:
  • Move novelties to a child kit!
  • You don't need both icon and 'super' 1u and 1.25u win keys. Pick one.
  • Move 1.5u super and and 1.75u backspace to an extension kit.
  • Split macro and space bar kits into separate child kits instead of 1 giant extension kit.
  • Remove mini bars from base kit and create a mini bar child kit in either white or purple. 1u mini bars need to go here to.
  • Make standalone white accent bar kit sans 1u bars.
  • (Personal preference) Just put centered 6u space bar in the base kit.
  • Splitting numpad may help with pricing.
« Last Edit: Tue, 29 March 2022, 02:06:16 by Ensaum »
Offline JonoColwell
Re: [IC] GMK Regal
« Reply #10 on: Tue, 29 March 2022, 02:10:01 »
So essentially you're proposing
Base Kit
Purple spacebar kit
White spacebar kit
Small spacebar kit
Novelties Kit
Macro Kit
Numpad Kit
Relegendables kit?
Offline Ensaum
Re: [IC] GMK Regal
« Reply #11 on: Tue, 29 March 2022, 02:22:39 »
Base Kit
Purple spacebar kit
White spacebar kit
Small spacebar kit
Novelties Kit
Macro Kit
Numpad Kit
Relegendables kit?
On second thought, it'd prob be better to do something along the lines of 6.25u and 7u accent bars, purple 6us, and purple mini bars in one space bar kit. So:
Base
Novelties
Space Bars
Macro
Extension
Relegendables
Numpad could go either way tbh. I think people usually remove it to get base kit cost down for moq reasons
Offline JonoColwell
Re: [IC] GMK Regal
« Reply #12 on: Tue, 29 March 2022, 02:27:07 »
Base Kit
Purple spacebar kit
White spacebar kit
Small spacebar kit
Novelties Kit
Macro Kit
Numpad Kit
Relegendables kit?
Base
Novelties
Space Bars
Macro
Extension
Relegendables
Okay so I've considered this carefully, and I think I'm going to go with what I have at the moment for the following reasons
1. I like the idea that the base kit you buy it and it's compatible with pretty much everything right off the bat
2. I always use a numpad so I wouldn't want to split the numpad off, and it never actually saves any money
3. I've committed to buying out MOQ myself anyway so I really don't mind
Offline Ensaum
Re: [IC] GMK Regal
« Reply #13 on: Tue, 29 March 2022, 02:36:48 »
Really? You're prepared to tie up potentially 10s of thousands for over a year to buy out moq? I don't really believe this, but good luck.
If you change your mind, there's plenty of other successful sets out there with great kitting you can take a look at.
« Last Edit: Tue, 29 March 2022, 02:38:32 by Ensaum »
Offline VXQN
Re: [IC] GMK Regal
« Reply #14 on: Tue, 29 March 2022, 03:41:47 »
I kinda love the enormous base kit, but I do think that the novelties should be separate, or massively cut down.
Also, if you're putting 2x3U bars in base, I'd say it's probably worth putting a single 1U bar in there too.
Initially I thought going for a custom white was probably not the best idea, but having looked at it I see that there isn't really a similar white in GMKs stock colours. To me it looks like a slightly dimmer WS1, but not edging into cream like CP?
Offline OJtheTiny
Re: [IC] GMK Regal
« Reply #15 on: Tue, 29 March 2022, 05:34:21 »
that basekit is gonna need a lot of help to make anywhere near MOQ holy ****, even if you price that at 1k it's gonna be closer to $200 per base kit which is insanity for current gmk wait times
Offline P103
Re: [IC] GMK Regal
« Reply #16 on: Tue, 29 March 2022, 06:34:48 »
Sticking with full size, Alice, uk ISO and some 40s support is good enough for most people's need for compatibility. Any potential saving for having a base kit this large is lost when you're forced to set a very low moq.
« Last Edit: Tue, 29 March 2022, 06:36:31 by P103 »
Offline neon_tom
Re: [IC] GMK Regal
« Reply #17 on: Tue, 29 March 2022, 06:56:03 »
I’m interested but I’ll echo the opinion that your base kit needs to be split. At the very least split out the novelties.
Offline Bub
    • big bub's beepers
Re: [IC] GMK Regal
« Reply #18 on: Tue, 29 March 2022, 07:05:43 »
you say you'll commit to buyout, but how do people (customers and vendors) know that will actually happen? do you really wanna drop 50k into this project to buyout at 250 moq if this set sells like 10?
lots of yellow flags in this IC... it doesn't seem like you are keen on listening to the feedback being offered.  GL tho
« Last Edit: Tue, 29 March 2022, 07:14:45 by Bub »
Offline TyPo.mk
Re: [IC] GMK Regal
« Reply #19 on: Tue, 29 March 2022, 07:15:13 »
I love forcing 30 novelties into base and you can’t even use them in a 65column/macro column
Offline nqbshas
Re: [IC] GMK Regal
« Reply #20 on: Tue, 29 March 2022, 07:21:59 »
Looking forward to see how much the price for that base kit.
Sent from my SM-G998B using Tapatalk
Offline Bub
    • big bub's beepers
Re: [IC] GMK Regal
« Reply #21 on: Tue, 29 March 2022, 07:29:47 »
OK bro i just keeping finding more warning signs here....
this is literally just a slightly modified version of your last IC: https://geekhack.org/index.php?topic=115066.msg3089694#msg3089694
is it april 1st in Australia already?
Offline stidal
  • milo#3939
Re: [IC] GMK Regal
« Reply #22 on: Tue, 29 March 2022, 09:06:16 »
babe wake up, deep navy r2 with absurd kitting just dropped
transition tkl // aksara ce // bully // valhalla // voyager // rs60 // adiuvare // ciel60 // jules // prime e // ut47.2 // sequence // bumper // q1 // gaff60
Offline udller
Re: [IC] GMK Regal
« Reply #23 on: Tue, 29 March 2022, 09:18:25 »
i like the colours, but i do agree the kitting isn't exactly the best.
i personally think the novelties should be moved to a separate kit. with probably some of them being removed. i don't think someone is likely to use all the r1 keys on their board at once. and all the r4 keys only like 4 can be used at once. id suggest keeping the crown and the lion tiger.
moving to the base kit. you have 2x r4 Fn keys. i don't think this is needed. also the amount of keys to use for windows or supers is kinda extreme you could cut it back a bit. i don't know what the extra r2 backspace key is for as it doesn't have a size on it.
but most importantly your missing the hang bag caps lock and stepped handbag capslock. which  is the best caps lock by far.
i edit your render with my awesome ms paint skills...284374-0
Offline Rumblethumps
Re: [IC] GMK Regal
« Reply #24 on: Tue, 29 March 2022, 09:28:06 »
The potential price of that base kit plus GMK's current lead times put me off from this entirely.  :confused: I'm willing to eat my words if it turns out to be reasonable though.
And you're dead set on buying out MOQ before getting any pricing info? There's too many risks here atm.
Offline Cylent
  • Formerly cylentshadows
Re: [IC] GMK Regal
« Reply #25 on: Tue, 29 March 2022, 09:36:29 »
everyone else: GMK is increasing their prices, let's try to cut costs to keep base kit at 130$
this guy: hold my beer.
(seriously though I echo everything that has already been said: fix the base kit's size and cost or this set is dead in the water).
Offline ggggggg
  • schmeiß die forties durch den club
Re: [IC] GMK Regal
« Reply #26 on: Tue, 29 March 2022, 10:11:08 »
You're a third of the way to basic 40s support. Ok technically you're only missing an r3 1.25u tab, but I strongly suggest adding at least a dozen or two 40s-specific keys.
« Last Edit: Tue, 29 March 2022, 10:14:31 by ggggggg »
Offline rainkeebs
  • rainkeebs.mx
    • Rainkeebs
Re: [IC] GMK Regal
« Reply #27 on: Tue, 29 March 2022, 10:17:55 »
Base kit is ginormous, will be prohibitively priced. The 40s support you mentioned is nonexistent. You have the backspace key for one specific size of 40% and *nothing* else. Basic 40s support (called 3 key) is r2 1.75u (Backspace), r3 1.25u (Tab), r3 1.5u (Enter). That’s bare minimum to make them shut up. I don’t have any opinions on the set itself, that’s why I didn’t say any. The kitting is just not going to work and this will be another failed GMK GB. It needs a lot more work put into optimizing the kits to be realistic for current pricing:wait times.
Offline norb
Re: [IC] GMK Regal
« Reply #28 on: Tue, 29 March 2022, 10:23:35 »
"yo dawg i heard you like keyboards so i designed a deskmat-sized keyboard so you can put your keyboard on your keyboard while you keyboard."
xzibit, probably.
Offline Ensaum
Re: [IC] GMK Regal
« Reply #29 on: Tue, 29 March 2022, 11:25:51 »
i edit your render with my awesome ms paint skills... (Attachment Link)
Oh, I completely missed the duplicate fn. Yeah this can be removed too.
What's your reasoning behind removing stepped caps from base, but leaving stepped control? I would leave stepped caps and maybe move stepped control to extension along with more complete 40s support.
Offline JohnYYZ
  • KanataKeys.co
Re: [IC] GMK Regal
« Reply #30 on: Tue, 29 March 2022, 11:38:16 »
$200 USD Base Kit? Good luck  :(
Also, the base kit image is being displayed as 16:9 ratio when not zoomed in.
Offline XiXora
Re: [IC] GMK Regal
« Reply #31 on: Tue, 29 March 2022, 13:07:54 »
I would love a massive base kit like this as I end up always buying base+extension kit anyway but I feel you would like to sell some of these as you'll see people worry about kits at high prices.
Love seeing 1.5 Supers (need 2 1u alts though) and stepped control etc.
May need to organise space bars a little as may need 1.25u and 1u with the Alice bars for split space boards.
You may want to check Zambumon's kitting with his latest kits with base + macro-extension.
Offline Neely_12
Re: [IC] GMK Regal
« Reply #32 on: Tue, 29 March 2022, 13:34:40 »
Uh, you make want to get your eyes checked out. Red/green colorblindness is very common.
Offline JonoColwell
Re: [IC] GMK Regal
« Reply #33 on: Tue, 29 March 2022, 16:18:22 »
Oh I already have the quote and it's within budget.
Offline less_blank
Re: [IC] GMK Regal
« Reply #34 on: Tue, 29 March 2022, 16:51:11 »
This IC seems pretty pointless if you don't care if people are actually interested in purchasing and are dead set on running it exactly as is without listening to community feedback. A lot of misplaced hubris here, I'm sure this will end well. GLWIC.
Offline TyPo.mk
Re: [IC] GMK Regal
« Reply #35 on: Tue, 29 March 2022, 17:10:07 »
If you already have quotes what do you plan on pricing this base kit at?
Offline JonoColwell
Re: [IC] GMK Regal
« Reply #36 on: Tue, 29 March 2022, 17:29:10 »
Brother I am not going to come up with a unique layout etc for every interest check, I'm happy with the layout of the post and almost 100% with the kitting, currently chatting to a couple of people about some potential updates.
I like two R4 fn keys
Handbag caps I dislike
Windows/supers I was only going to have windows keys but then the linux people I know complained so it has both now.
The second backspace is there for minivan support and good catch I didn't notice I forgot to label it 1.75u
Thanks for the info on 40%, I genuinely didn't know because I've never used one haha.
Currently waiting on lead vendor to provide an update on that, I can buy it out at wholesale though but I'm not allowed to share that information, not cheap though.
« Last Edit: Tue, 29 March 2022, 17:31:50 by JonoColwell »
Offline IOVERCALLHISTIOCYTES
Re: [IC] GMK Regal
« Reply #37 on: Tue, 29 March 2022, 18:17:02 »
One less base kit to buy out if you use pantone 2695, I’d be in for one.
Offline Cylent
Re: [IC] GMK Regal
« Reply #38 on: Tue, 29 March 2022, 19:03:48 »
You have the quote, you know it's "within budget," but you need to wait on your lead vendor to provide an update on the pricing? You can't even ballpark it? If you can buy it out wholesale, then why are you making an IC? Is your plan to buy out this set yourself, or to run a successful GB and make MOQ naturally? My vision has turned red due to the blinding light of so many red flags, and for that reason I'm out.
Offline datfroyodoe
Re: [IC] GMK Regal
« Reply #39 on: Tue, 29 March 2022, 19:36:45 »
if you're gonna force novelties in the base kit, i think i would rather have the option for 1u R4 novelties than the windows icon keys. the window keys just look too off-theme(?), it is just not very "regal"
Offline GMK83
Re: [IC] GMK Regal
« Reply #40 on: Tue, 29 March 2022, 20:14:13 »
I’m in!  If only this had R5 tho…
Offline Baka Bot
Re: [IC] GMK Regal
« Reply #41 on: Tue, 29 March 2022, 20:15:14 »
I really dig the colors. I also agree with the criticisms about the base kit mentioned above. glwic
Re: [IC] GMK Regal
« Reply #42 on: Tue, 29 March 2022, 20:30:05 »
Very nice! Love the colors. I do agree though, consolidate some of the child kits at the least. MOQ will be 100 kits minimum on each of those!
Offline autocast
Re: [IC] GMK Regal
« Reply #43 on: Tue, 29 March 2022, 20:33:49 »
Need some regal stained glass windows keys
Offline Cujo96
Re: [IC] GMK Regal
« Reply #44 on: Tue, 29 March 2022, 20:55:00 »
I'm actually going to laugh when this madlad buys out moq and everyone who doubted him is left in shock and awe.
Offline MIGHTY CHICKEN
Re: [IC] GMK Regal
« Reply #45 on: Tue, 29 March 2022, 22:04:41 »
American sized base
Offline FatefulStranger
Re: [IC] GMK Regal
« Reply #46 on: Tue, 29 March 2022, 22:11:49 »
What do you mean "within budget"? I'm assuming your budget? If you really wanted to make a set that's only for you, sure go ahead. But to call this an IC and disregard a lot of people's main concerns is not an IC at all but just a flex that you have a lot of money.
Just to echo everyone else, the least you can do is separate out the novelties. Not everyone likes novelties or will even use them, and personally this set's novelties are meh to me. I mean if you're going to be hitting MOQ by yourself, do you personally need that many novelties to yourself?
Offline kiwoli
Re: [IC] GMK Regal
« Reply #47 on: Tue, 29 March 2022, 22:21:22 »
Yea... so this isn't an IC, just buy out MOQ and then sell in stock when GMK delivers to you, kthxbye.
Offline Neely_12
Re: [IC] GMK Regal
« Reply #48 on: Tue, 29 March 2022, 22:28:57 »
This^ The only reason people do groupbuys is to be able to fund the project, which you can apparently. It would also sell a lot more if it was in stock, especially if it rivals the “extras” pricing of other vendors. This all just rubs me the wrong way.  You added supers bc Linux people you know complained, yet dozens of people are asking to have a separate novelties kit and crickets.
Offline s__pete
Re: [IC] GMK Regal
« Reply #49 on: Wed, 30 March 2022, 04:47:01 »
Personally I'd move the novs to a separate kit because I hate novelty AND fun, other than that this set looks very good. Maybe remove what 40 support there is because I also hate 40% users with a burning passion.
