Author Topic: [IC] GMK Regal | Group Buy Live  (Read 48540 times)
Offline JonoColwell
Re: [IC] GMK Regal | Hibi Added | GB July
« Reply #100 on: Sat, 18 June 2022, 09:57:01 »
Am I missing something or is there no R2 Esc for 40s compatibility? There's a R3 Tab and short Enter...
3-key 40s support doesn't usually include r2 esc from what I understand but since this base kit is so big already I agree that it should have been added.
I asked all one 40% user in australia what was bare minimum 40s support and he gave me the keys I need, at this point it's priced up, just waiting on a couple of regional prices.
Offline 傻子
« Reply #101 on: Sat, 18 June 2022, 10:23:34 »
I would say the color is what we need after PHANTOM, but the kitting is suffering  for acromegaly
Offline Wolff._.
  • Machinist
« Reply #102 on: Sun, 19 June 2022, 13:17:56 »
This set is practically Gmk future funk without the colors. Same patone purple but diffrent white, that you'll most likely end up not even noticing any difference from a standard white. Would like to see more split kitting but will consider copping relegandable kit even though I don't enjoy supporting this abnoxios way of kitting.
[Edit] Lmao just noticed I already said this 💀
« Last Edit: Sun, 19 June 2022, 13:41:12 by Wolff._. »
Offline JonoColwell
« Reply #103 on: Mon, 27 June 2022, 00:23:24 »
UPDATE: Final Hibi Renders and updated Wombat Renders
There's a couple of problems with split kitting, but my main one is that if you're buying the set aftermarket it sucks when you've got to hunt down some obscure kit that nobody's selling separately and then it won't fit your layout.
Another issue is that it's more expensive overall to purchase two kits than if they were one kit.
Essentially for everything except for XT columns the base kit will support it, not exactly with correct keys but with correct rows.
See above, I like big kits and I cannot lie.
Offline hkhawk
Re: [IC] GMK Regal | Final Render Updates | GB July 1
« Reply #104 on: Mon, 27 June 2022, 09:37:36 »
I see pricing on Geon's Instagram for Korea, what is the US pricing?
Offline Sweihan
« Reply #105 on: Wed, 29 June 2022, 03:03:53 »
Take my monez
Offline mr_foggy
  • neue = nope
« Reply #106 on: Fri, 01 July 2022, 11:56:54 »
on track to being my 128983th purple set
Offline JonoColwell
Re: [IC] GMK Regal | Group Buy Live
« Reply #107 on: Fri, 01 July 2022, 18:59:05 »
It's up now on the GB Thread, will be updating those fully as vendors go live.
Happy to help
Take my monez
Gladly
Offline Shorle
« Reply #108 on: Sat, 02 July 2022, 05:32:10 »
Let's make a set with novelties based on medievil Europe.
Also, let's not include European language support.
smh
Kitting wise I'd have included 1.25u convex spacebar but that's probably just because I also use Ikki68 Aurora with their split style spacebar.
 :-X
GLWGB anyway, set looks good!
