Author Topic: [IC] GMK Regal | Group Buy Live  (Read 48541 times)
Offline aeryxz
    • aeboards
Re: [IC] GMK Regal
« Reply #50 on: Wed, 30 March 2022, 05:19:03 »
Finally a base set that truly is based as. Text and icons, chefs kiss. Don't need to buy various random kits to make a "base" kit, chefs kiss. Mega support so you don't have to find random child kit after market when you've forgotten, chefs kiss.
Offline Cujo96
Re: [IC] GMK Regal
« Reply #51 on: Wed, 30 March 2022, 07:32:53 »
Everyone ripping on this but forgetting GMK Wild and DCS Deadbeats lmao
Re: [IC] GMK Regal
« Reply #52 on: Wed, 30 March 2022, 08:27:17 »
base kit is unhinged but just split the novs out and i think it's fine
people sent me this thread and acted like you had committed a war crime or something
Offline sirieous
  • help
Re: [IC] GMK Regal
« Reply #53 on: Wed, 30 March 2022, 09:38:06 »
Will be interested to see price on this when it goes live eventually. Hopefully not too bad cause I am keen to get a set.
Offline succulentdan
Re: [IC] GMK Regal
« Reply #54 on: Wed, 30 March 2022, 10:47:51 »
Personally I'd move the novs to a separate kit because I hate novelty AND fun, other than that this set looks very good. Maybe remove what 40 support there is because I also hate 40% users with a burning passion.
You’re just an absolute ray of sunshine and daises, aren’t you?
Offline gotgoodiez
Re: [IC] GMK Regal
« Reply #55 on: Wed, 30 March 2022, 10:52:01 »
I think if you fixed your kitting a bit this would be a great set. IMO pair down the novelties (the buck doesn't really seem "regal" like the other ones) or just move it to its own kit; Move your windows keys and supers to the extension kit and last one is you might not need all the accent spacebars as it will probably make that extensions kit quite a bit. On a different note maybe use a stock white if you can find it but beyond that glwic!
Offline soundstage
Re: [IC] GMK Regal
« Reply #56 on: Wed, 30 March 2022, 12:29:05 »
So your plan is to buy out at wholesale from lead vendor. Will that translate into you selling it to end users directly at a slightly higher price from wholesale price?
Offline konstantin
  • Formerly constexpr
Re: [IC] GMK Regal
« Reply #57 on: Wed, 30 March 2022, 18:12:40 »
That's one huge base kit.
I suggest removing the Windows keys and moving the novelties to a separate kit (though I'd maybe keep one or two of them in the base kit just for flavor).
Offline JonoColwell
Re: [IC] GMK Regal
« Reply #58 on: Mon, 04 April 2022, 19:20:21 »
Update Time:
I've got the quotes back for the kit with the novelties split out, most people seem to not want the novelties in base and someone pointed out that I would have to store a ****load of base kits to have all the novelties that I want, on that basis I've split out the base and novs.
Offline 傻子
Re: [IC] GMK Regal
« Reply #59 on: Mon, 04 April 2022, 19:39:39 »
will it has a CN vendor?
hope itwill be Zfrontier or KBDfans
Offline rainkeebs
  • rainkeebs.mx
    • Rainkeebs
Re: [IC] GMK Regal
« Reply #60 on: Mon, 04 April 2022, 22:16:01 »
nice kitting update. you still forgot the rest of the 40s keys tho. the literal 2 that are needed to support *most* 40s. they dont even have an incorrect legend alternative. dunno what the thinking was there, unless there wasnt any...
Offline less_blank
Re: [IC] GMK Regal
« Reply #61 on: Mon, 04 April 2022, 22:24:52 »
Why no 1u R4 novelties?
Offline JonoColwell
Re: [IC] GMK Regal
« Reply #62 on: Mon, 04 April 2022, 23:40:58 »
Offline rainkeebs
  • rainkeebs.mx
    • Rainkeebs
Re: [IC] GMK Regal
« Reply #63 on: Mon, 04 April 2022, 23:42:37 »
ok. im not sure what you're saying by that
Offline iamtragic
Re: [IC] GMK Regal
« Reply #64 on: Mon, 04 April 2022, 23:43:29 »
love ya work jono, im in.
Offline JonoColwell
Re: [IC] GMK Regal
« Reply #65 on: Mon, 04 April 2022, 23:45:32 »
I mean, so far 100% of the (single) 40% people that I've actually spoken to about this have been adamant of two things
  • The set must support 40%
  • They are not buying it
Are you actually interested in buying it?
Offline rainkeebs
  • rainkeebs.mx
    • Rainkeebs
Re: [IC] GMK Regal
« Reply #66 on: Mon, 04 April 2022, 23:47:50 »
I am not. I don't care if you have 40s support, but if you're going to "have" it you should at least actually have it. Either have all 3 keys or none I don't care. But it's a waste of money for everyone if you have just the one 1.75u backspace key.
Offline JonoColwell
Re: [IC] GMK Regal
« Reply #67 on: Mon, 04 April 2022, 23:49:34 »
Minivan
Offline rainkeebs
  • rainkeebs.mx
    • Rainkeebs
Re: [IC] GMK Regal
« Reply #68 on: Mon, 04 April 2022, 23:53:15 »
Minivan
For the last time, minivan needs the 1.75u backspace key, yes. BUT it ALSO needs the SAME 1.25u r3 tab that every other staggered 40% uses, as well as a r3 1.5u enter key. You do not have minivan support, you have the funny backspace key. That is not 40s support, that is not minivan support, it is literally wasting every single buyers money. Read what I am saying and listen to it. I am trying to help you man. You said it yourself that you don't even know what the **** 40s are, I DO. And I am telling you the solution to a problem. Fix the problem, or remove the problem, don't keep defending it.
Offline JonoColwell
Re: [IC] GMK Regal
« Reply #69 on: Mon, 04 April 2022, 23:58:10 »
Oh right, now I get it, how does this look then?
Offline rainkeebs
  • rainkeebs.mx
    • Rainkeebs
Re: [IC] GMK Regal
« Reply #70 on: Tue, 05 April 2022, 00:00:04 »
that is proper 3 key support. good job!
Offline conternecticus
Re: [IC] GMK Regal
« Reply #71 on: Tue, 05 April 2022, 01:23:44 »
Novelties separate kit we are all happy now
Personally I like the idea of a huge base kit. GLWIC!
Offline Botty212
Re: [IC] GMK Regal
« Reply #72 on: Tue, 05 April 2022, 01:49:32 »
no R2 and R3 novelties but 100 novelties for R1 and R4.....
cant even use half the novelties even if you are using a tkl
Offline JonoColwell
Re: [IC] GMK Regal
« Reply #73 on: Tue, 05 April 2022, 03:19:42 »
What would you even use r2 and r3 novelties for?
Offline VXQN
Re: [IC] GMK Regal
« Reply #74 on: Tue, 05 April 2022, 03:43:09 »
Macro/65% nav column.
Offline x-starburst-x
Re: [IC] GMK Regal
« Reply #75 on: Tue, 05 April 2022, 06:23:51 »
love this set
Offline zzkhan1996
Re: [IC] GMK Regal
« Reply #76 on: Tue, 05 April 2022, 07:01:26 »
I think that you should separate the spaces and macro into 2 kits
Offline XiXora
Re: [IC] GMK Regal
« Reply #77 on: Tue, 05 April 2022, 19:04:02 »
Kit is almost fine but please please one more r4 1u alt for HHKB/Mac 7u, everything else is there for it.
Of my 5 40s, not one is minivan/"basic 40s" (I'm mostly 12u). Slightly amusing but I'm not asking for it.
Looking forward to seeing this on your wombat :)
Offline Getsome!!!
Re: [IC] GMK Regal
« Reply #78 on: Wed, 06 April 2022, 22:30:11 »
As much as i absolutely hate the color the yellow (seriously, worst color ever) and the Lakers, I think i still prefer phantom. The yellow came off as more of a gold, probably just my preconceived notions of what "regal" colors are.
Offline IOVERCALLHISTIOCYTES
Re: [IC] GMK Regal
« Reply #79 on: Wed, 06 April 2022, 22:40:19 »
Phantom the render or phantom the set? That’s closer to butter beige than it is to yellow or gold.
Offline Getsome!!!
Re: [IC] GMK Regal
« Reply #80 on: Wed, 06 April 2022, 23:25:30 »
 Phantom the keycap set. What's "phantom the render"?
Just happened to stumble upon this looking at desk mats, might work well for people interested in this set. https://www.redbubble.com/i/mouse-pad/Purple-Fleur-de-lis-by-muskitt/41192870.GAP22
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
Re: [IC] GMK Regal
« Reply #81 on: Thu, 07 April 2022, 02:22:53 »
please remove 40%'s
Offline genevatypes
Re: [IC] GMK Regal
« Reply #82 on: Thu, 07 April 2022, 03:04:32 »
idc what other ppl are saying but this base kit is sexy. i love you
Offline JonoColwell
Re: [IC] GMK Regal
« Reply #83 on: Thu, 07 April 2022, 05:39:49 »
please remove 40%'s
I'll take that under consideration.
Also no.
I'll think about it but personally when I was using a HHKB for the week that I had it I mapped one of the alts to function/layer 1 so I could actually use the bloody thing. I'd also say you could use the super keys for that, it's not perfect but it does solve the issue.
Macro column is sorted with the macro set in extension, I'd either have to make a call on a single artisan to cover all the rows with or add another 28 novelties to get all of the novelties on these rows for an extremely niche use case when a lot of people use function keys or novelties on the XT columns in off sculpt from what I've seen at meetups.
Or you know, resin if they're ballers.
In addition 65% is supported by actual keys that are mapped there as standard so it's supported in base anyway.
I have phantom on my desk right now, it doesn't look like the renders at all, the yellow of phantom is definitely more like a butter yellow than what's in the renders.
No thanks.
Offline hottrout
  • I'd Hit Dat Key
Re: [IC] GMK Regal
« Reply #84 on: Thu, 07 April 2022, 07:38:47 »
LOVE the colour.  In on this.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline XiXora
Re: [IC] GMK Regal
« Reply #85 on: Thu, 07 April 2022, 19:13:09 »
Do you not use the Fn next to the right shift or is this why you added two r4 1u Fn to the kit? I use Super keys for my OS keys, that's out.
Just an odd choice to leave out that second 1u alt for two 1.5u super kits.
Offline JonoColwell
Re: [IC] GMK Regal
« Reply #86 on: Sun, 10 April 2022, 23:58:01 »
To be honest most of what I did with my HHKB was dislike it and offload it as soon as possible. However let me have a think about it.
Offline Wolff._.
  • Machinist
Re: [IC] GMK Regal
« Reply #87 on: Wed, 27 April 2022, 12:14:26 »
I love that purple is the same color as Future funk.
Will pick up a relegenable kit, but really would like a normal spacebars kit as well.
Offline BasedCoper
Re: [IC] GMK Regal
« Reply #88 on: Wed, 27 April 2022, 12:34:42 »
now that's what a base kit should look like
Offline santela
Re: [IC] GMK Regal
« Reply #89 on: Thu, 28 April 2022, 04:05:27 »
Lol seems like a lot of back and forth for the base kit to get where it is now, although it is probably still the largest base kit I've seen.
I like the colors and the novelty, but tbh the deer kinda feels outta place. It looks more like a hunting/wildlife kinda deer and not really a royalty/majestic kind.
Offline JonoColwell
Re: [IC] GMK Regal | Collabs added
« Reply #90 on: Wed, 25 May 2022, 01:22:57 »
UPDATE: 25-05-2022
  • Updated novelty renders to use accepted art from GMK
  • Added collaborations
  • Added Deskmats
  • Updated all kits to latest version
  • There is a hibi cap just waiting on renders, that has also been confirmed for manufacturability
Offline ee
  • hi
« Reply #91 on: Wed, 25 May 2022, 05:17:51 »
as a 40s hater i confirm i will buy this set
Offline JonoColwell
Re: [IC] GMK Regal | Hibi Added | GB July
« Reply #92 on: Mon, 30 May 2022, 22:17:13 »
Update 31-05-2022
  • Added hibi cap renders
  • GB date announced
Offline udller
« Reply #93 on: Tue, 31 May 2022, 11:21:27 »
that hibi cap is boss. its the Rolly Royce of metal key-cap artisans.
Offline Jho
« Reply #94 on: Tue, 31 May 2022, 18:09:23 »
Nice and cool theme. Absolutely love that HIBI keycap.
Offline mr_foggy
  • neue = nope
« Reply #95 on: Tue, 31 May 2022, 18:13:09 »
finally an actual BASE kit.
or should I say BASED.
idgaf about 40% but just keep the basic support if it makes them shut up
Offline hottrout
  • I'd Hit Dat Key
« Reply #96 on: Wed, 01 June 2022, 03:19:55 »
+1 for the BIG base kit.  Like a lot.
Systems -
  Keyboards -
Offline guypigeotto
  • beige baby
« Reply #97 on: Wed, 15 June 2022, 20:12:34 »
based and purplepilled
i made gmk handarbeige+
Offline VXQN
« Reply #98 on: Thu, 16 June 2022, 04:02:29 »
Am I missing something or is there no R2 Esc for 40s compatibility? There's a R3 Tab and short Enter...
Offline ankit
  • Formerly ankit-sachdeva
« Reply #99 on: Thu, 16 June 2022, 13:20:55 »
3-key 40s support doesn't usually include r2 esc from what I understand but since this base kit is so big already I agree that it should have been added.
