Author Topic: [IC] PBTFANS DOUBLESHOT RESONANCE  (Read 15383 times)
Offline kbdfans
« on: Thu, 31 March 2022, 00:20:25 »
PBTFANS DOUBLE-SHOT RESONANCE
Updates 04/01/2022
Introduction
Designed by ok-c who's from OpenKey which designed Phase One 65 Keyboard. Resonance is inspired by the Braun calculator ET series. With KBDfans' Doubleshot PBT/metal process, it will be a classic and durable.
Inspiration Source
PBTfans RESONANCE on Phase One 75/65
Specification
Material: PBT material
Profile: Cherry profile
Production Method: Doubleshot
Manufacturer: KBDfans
Compatibility: Cherry MX switches and MX-style clones
Designer: ok-c
Kit Options
Artisan Keycaps
« Last Edit: Tue, 05 April 2022, 20:18:21 by kbdfans »
Offline chat and team
Re: [IC] PBTFANS DOUBLESHOT RESONANCE
« Reply #1 on: Thu, 31 March 2022, 00:33:25 »
why is there japanese? German company inspired set made by a Chinese company.
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline Slayer77
« Reply #2 on: Thu, 31 March 2022, 02:27:45 »
Is this not epbt? New manufacturer?
Sent from my GM1911 using Tapatalk
Offline abucazu
« Reply #3 on: Thu, 31 March 2022, 02:31:56 »
There is a wrong IC linked in the interest check form
Offline juniper37559
« Reply #4 on: Thu, 31 March 2022, 03:09:53 »
Latin with text mods please. Don't think this color theme is weeb enough to have hiragana sublegends.
Offline Nonnegaard
« Reply #5 on: Thu, 31 March 2022, 03:35:08 »
Neither are Beta JS or Sashin, but it fits the theme.
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline kiwoli
« Reply #6 on: Thu, 31 March 2022, 06:42:28 »
Would like the option of icon+text mod for latin alphas, strange to tie in different mods with different alphas and not offer the option to choose.
I don't think I've seen separate mod and alpha only kits for epbt, but I may be unaware of the reasons, seems applicable in this instance to try that out. Please also name the kits, easier for everybody reading this thread.
Offline NihonCK
« Reply #7 on: Thu, 31 March 2022, 06:45:33 »
Correct, they have their own facility now that is not a part of ePBT
Offline konstantin
  • Formerly constexpr
« Reply #8 on: Thu, 31 March 2022, 08:55:32 »
The numpad kit is missing R1 PgDn, End keys, which are required for 1800/CP/96-key support. Both text and icon variants of these keys should be added.
The spacebars in this render look brown instead of black. Those keys should be alpha-colored, not mod-colored.
6.25c and 7c sizes should be removed (unless you change them to be accent-colored), and in their place, 1c and 1.25c spaces should be added.
The chōonpu () on the right should sit higher than the underscore (_) on the left, not the other way around.
« Last Edit: Thu, 31 March 2022, 09:07:15 by konstantin »
Offline Adelscott
« Reply #9 on: Thu, 31 March 2022, 12:14:35 »
Wrong IC link, it points to "PBT Purpolch" google form.
Please add a french kit. And make it in stock. Thanks
Please think about ISO users, add a split left shift to your "alice style" keyboards
Offline speedycake
« Reply #10 on: Thu, 31 March 2022, 13:06:44 »
Consider splitting mods and alphas, latin alphas with texticon shouldn't have to require buying two base kits.
Offline Rafa_n
« Reply #11 on: Thu, 31 March 2022, 13:13:10 »
are there any proto pictures of any "PBTFANS" keycaps?
Offline TyPo.mk
« Reply #12 on: Thu, 31 March 2022, 14:26:14 »
Isnt there already TWO sets based on this calculator?
 edit
SA Calculator
GMK Taschenrechner
« Last Edit: Thu, 31 March 2022, 14:31:50 by TyPo.mk »
Offline abucazu
« Reply #13 on: Thu, 31 March 2022, 16:18:23 »
Please consider an extended international kit with ISO Spanish
Offline treeleaf64
    • treeleaf64
« Reply #14 on: Thu, 31 March 2022, 18:07:06 »
Can do whatever you want : )
Everyone must pay the cat tax
Offline NihonCK
« Reply #15 on: Thu, 31 March 2022, 19:51:23 »
These are early batch samples, font created by Biip
Offline salgiza
« Reply #16 on: Fri, 01 April 2022, 03:43:57 »
That would be amazing. There are not that many dark kits with ISO ES support (or even a South kit).
P.S. Why is there a recessed macOS command key? Is there any keyboard layout that uses that? (I guess for people that don't use caps lock much?)
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #17 on: Sat, 02 April 2022, 14:35:31 »
 edit
SA Calculator
GMK Taschenrechner
GMK Taschenrechner's OP says it was put on hold, presumably because of SP SA Calculator.
Then SP SA Calculator was canceled when it failed to reach MOQ.  (Odd that its legends were yellow, since Braun ET66's are white.)
Arguably this PBTfans IC is cutting in line, although there's been no activity in Taschenrechner's IC since 13 October 2021.
Offline kajahtaa
« Reply #18 on: Sun, 03 April 2022, 18:02:46 »
Hahahah... ePBT is a dumpster fire so find a new way to keep the money coming in.... Yeah No.
Offline nvh2092
« Reply #19 on: Sun, 29 May 2022, 12:01:17 »
Please add R1 1u PgDn and End to base kit since there are icon and text types.
Offline NihonCK
« Reply #20 on: Tue, 05 July 2022, 14:29:43 »
Offline dvorcol
« Reply #21 on: Tue, 05 July 2022, 16:32:06 »
Offline EdgeOfInfinity
« Reply #22 on: Wed, 06 July 2022, 16:37:03 »
this is very good imo
Offline kiwoli
« Reply #23 on: Tue, 06 September 2022, 20:48:09 »
I see these as in stock now, but what happened to icon+text mods?
Offline websitelover
« Reply #24 on: Tue, 07 February 2023, 17:06:34 »
Anyone know what keyboard this is?
Offline M2Pac
« Reply #25 on: Thu, 09 February 2023, 14:59:29 »
BAGUETTE 66%
