Author Topic: [IC] Daze65 | Gasket Mount, 65% layout, Japanese inspired design  (Read 104950 times)
Offline SakuraThocc Studio Works
Welcome to Daze65 Interested Check!!!
Hello  Geekhackers! This is SakuraThocc Studio Works® from Asia and Europe. We are a new company in the enthusiast keyboard industry bringing you high quality bespoke endgame keyboards. We consist of a team of creative individuals: Jing (lead designer), $W4GK!NG (lead designer), Fran (ergonomics expert), rookb (customer support), Ella (graphics designer), kptburger (former child), 7h3of7 (translator) and Of Sam (investor).
Did you know that in Japan there are 6 vending machines for every person? WOW!
IC FORM: https://forms.gle/xBTYw8ibP7J4TgdV9
Our philosophy
Today we bring you the Daze65 65% gasket mounted keyboard. Daze means “(noun) a state of stunned confusion or bewilderment.” It is inspired by Japan, Japanese culture and oriental culture in general. We feel there is lacking amount of true Japanese beauty represented in this space so we bring you this keyboard today.
The layout of the Daze combines the functionality of a full size keyboard with the ergonomics and compactness of a 65% form factor. It is built to perform. The numpad Enter, Plus and 0 bring the benefit of having a numpad to a compact form factor while many dedicated layer keys can be used to simulate numpad number input. This increases user performance and productivity by up to 300%.
Thank you Bachoo for this awesome render!
Specifications:
65%
10° typing angle
Gasket leaf spring mount (Poron®)
6061 Aluminum case
HOTSWAP PCB
USB Type-C
Stainless steel bottom piece
Carbon fibre bottom piece
Brass weight
2.8 kg unbuilt
Flex cut PC plate (Check IC form for more plate options)
Innovation
We are expanding on the popular gasket mount design to bring you the most pleasant bouncy and soft typing experience
along with carefully thought out flex cuts. We are using Poron® gasket foam material for isolation to bring the most comfortable keystrokes.
The kit will come with 2 different case foams, PCB PE foam and plate foam for maximum acoustical pleasure and deep sound (thock) tuning.
For ease of assembly and to achieve the best aesthetic design while hiding the screws on the back case we have decided
to connect the top and bottom case using MAGNETS. We don’t know how they work but we are confident that this is the best solution for this issue.
The back of the keyboard and sides are inspired by the great wave of Kanagawa. We can see beautiful curves which are formed on the back.
Our goals are to revolutionize the backsides of keyboards with intricate detail for most pleasant aesthetic experience.
The bottom is inspired by CW88 keyboard by Cruel World.
Colors
Colors available will be: Shinkanzen Blue, Bok Choy Green, 風邪 Black, Sakura Pink and Seieki White (E-white)
We wanted to gain input from popular keyboard influencers so we reached out to Shoobs and Black Simon.
Custom made wrist wrest
Beautiful Wrist wrest with Koi fish motif will be  made out of alu or PC. This will be an optional add-on for interested buyers. (+$140 for alu, +$170 for PC).
FAQ
When will the group buy happen?
We hope to start the group buy within 5 working days from posting this IC.
What will this cost?
TBD
Where will I be able to buy this?
TBD
Will there be deskmat available?
TBD
Special thanks to:
Bachoo for render
Shoobs for upcoming build stream
Blacksimon for his insight and advice
Offline rookb
Re: [IC] Daze65 | Gasket Mount, 65% layout, Japanese inspired design
« Reply #1 on: Fri, 01 April 2022, 06:06:21 »
reserved
Offline $W4GK!NG
  • Cars/Racing/Keyboards/Watches Enthusiast
    • Linktree
« Reply #2 on: Fri, 01 April 2022, 06:06:24 »
r e s e r v e d
Offline Fraaaan
« Reply #3 on: Fri, 01 April 2022, 06:06:58 »
Reserved.
Offline Kptburger
« Reply #4 on: Fri, 01 April 2022, 06:07:11 »
r e s e r v e d
i crave lasang
Offline Screen.jing
« Reply #5 on: Fri, 01 April 2022, 06:08:59 »
RESERVED
Too many projects going on at once
Papilio
MF60
Disco
Vlad
65
Adamo
Offline denibhoxha
  • cock and balls technology
« Reply #6 on: Fri, 01 April 2022, 06:09:27 »
Reserved.
Offline ZavaZ86
« Reply #7 on: Fri, 01 April 2022, 06:10:09 »
Are you making a copycat and where is the weight???
Offline Ella
  • Why is it called an oven
« Reply #8 on: Fri, 01 April 2022, 06:14:21 »
So ****ing thocky
Offline Pontus
« Reply #9 on: Fri, 01 April 2022, 06:14:58 »
I am a bit concerned over the lack of flex/thock cuts on the PCB  :eek:
Offline asswipe09
« Reply #10 on: Fri, 01 April 2022, 06:18:46 »
Good evening thoccsters
Offline rodok
« Reply #11 on: Fri, 01 April 2022, 06:20:38 »
reserved
This looks really good, the layout is truly innovative. Really pushing the boundaries of sanity design and usability.
Offline Kasterborous
    • HEX Keyboards
« Reply #12 on: Fri, 01 April 2022, 06:31:39 »
yare yare daze
Offline I_V_I
« Reply #13 on: Fri, 01 April 2022, 06:41:58 »
Reserved
Offline Baka Bot
« Reply #14 on: Fri, 01 April 2022, 07:21:32 »
I am a big weeb so i am obligated to like.
Offline Sleepdealr
  • my name is calliah
    • https://sleepdealer.xyz
« Reply #15 on: Fri, 01 April 2022, 07:24:43 »
incredible and innovative design
gb when
Offline Pyroo
« Reply #16 on: Fri, 01 April 2022, 07:55:58 »
i will thocc
Bunny enthusiast
Offline linell
« Reply #17 on: Fri, 01 April 2022, 09:46:48 »
I love you roo keyboard
bro this a **** set, just be thankful you even getting 1 base running fr
Offline whitewolf154
« Reply #18 on: Fri, 01 April 2022, 09:52:48 »
Even if this is an April fools joke, I still want it fr
Offline Juan.
« Reply #19 on: Fri, 01 April 2022, 10:45:30 »
I like it
rubber cup
Offline shima
  • keeb weeb
« Reply #20 on: Fri, 01 April 2022, 15:19:24 »
yes
boards: anura
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #21 on: Mon, 11 July 2022, 10:23:24 »
I want to buy this keyboard
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
« Reply #22 on: Mon, 11 July 2022, 10:59:15 »
" This increases user performance and productivity by up to 300%. "
SOLD!
Offline warmbidetaqua
« Reply #23 on: Mon, 11 July 2022, 11:09:34 »
oh my lord the bottom, reminds me of Ditto from pokemon
Offline Baka Bot
« Reply #24 on: Tue, 19 July 2022, 10:38:31 »
I really want to buy this!!!
Offline marcowhatever
« Reply #25 on: Tue, 19 July 2022, 10:55:56 »
I want to buy this as well! There really needs to be more Japanese inspired boards
« Reply #26 on: Tue, 19 July 2022, 11:40:15 »
pretty sure this was a april fools joke lol but if they moved forward with this, I'd cop
Offline deviant324
« Reply #27 on: Wed, 27 July 2022, 00:11:29 »
My Katakana is rusty to say the least, but if I'm not mistaken the weight literally reads "Deez Nuts" (as close as you can get in Japanese anyway). It's very safe to assume this was just an april fool's joke
Offline Gerevala
« Reply #28 on: Fri, 29 July 2022, 05:01:25 »
Is this wrist flat?
Offline Nonnegaard
this is so cool im gonna start doing this now
« Reply #29 on: Thu, 25 August 2022, 01:53:16 »
uhhh where usb port
« Last Edit: Thu, 25 August 2022, 01:56:30 by Nonnegaard »
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline Nonnegaard
why can you change this
« Reply #30 on: Thu, 25 August 2022, 01:55:12 »
am i literally the only one who noticed the missing port?
Offline Ella
« Reply #31 on: Thu, 25 August 2022, 05:39:31 »
This is an April fools post
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #32 on: Thu, 25 August 2022, 09:21:38 »
This may be true, but it's 2% away from being an award winning design! I think the designer should re-do this keyboard from scratch, make it usable, more symmetrical etc.
Offline Nonnegaard
« Reply #33 on: Tue, 06 September 2022, 01:44:34 »
oh
Offline Nonnegaard
« Reply #34 on: Tue, 06 September 2022, 01:46:18 »
very true, SakuraThocc Studio Works shows a lot of promise.
