Author Topic: [IC] Akuma TKL, Keyboard - PBTfans Akuma doubleshot Keycaps - Deskpads  (Read 77710 times)
Offline Mighty Setup
    • Mightysetups.com
Akuma
In other words, Devil.
Designed By Mighty Setup
285640-0
288315-1
UPDATES
There are stil some hope for you who missed your shot at KBDfans!
Akuma TKL ISO version is coming to Sweden!
You will be available to find Akuma TKL with ISO layout, in-stock at swedish vendors!
OBS: There will only be 1 version available to order.
Layout: 80% - TKL WKL F13 ISO.
Case colour: Black
Plate: Polycarbonate
Weight: PVD Brass Multicolour
Nordic Vendors:
Maxgaming.se
Webhallen.se
Inet.se
International Vendor:
Maxgaming.com
More information about Akuma TKL:
KBDfans Akuma 80%
Alexotos build stream
Key Features
• Leafspring mounting system with option for top mount.
• 3 Piece Construction
• Typing angle: 6.9°
• Front height: 17mm, front typing height: 20mm, Back height: 39mm
• Weights: Estimated 2.9kg
Sell Details
• Date: Sep 22nd at 7:00 PM PST (Pacific standard time)
• MOQ: 500 Units Limited Edition
• Vendor: KBDfans (worldwide shipping)
• Colour options: Black / E - White / Purple / Gray / Blue / Red
Package includes:
• Aluminum Top and Bottom case x1
• Weight bar x1
• PCB x1
• USB Daughter Board x1
• Plate x1
• PCB foam x1
• Case foam x1
• Switch pads x1
• Silicone socks set x1
• Designed tape mod x1
• Akuma Themed card x1
• Stabilizer shims x1
• Rubber feet x1
PCB:
Hotswapable, Flex Cut, 1.2 mm thickness, RGB underglow, QMK firmware, Daughterboard
Material:
6063 Aluminium Top
6063 Aluminium Bottom
Plate Options: PVD Brass, Aluminium, Polycarbonate
Weight options: PVD Brass, PVD Brass multi coloured, Pvd Brass black mirror
Real pictures of the prototype taken by Kbdfans:
289812-2289810-3289827-4
289821-5288309-6289823-7
289819-8288313-9289817-10
Plate:
291549-11291551-12291553-13
Layout: TKL WK F13 / TKL WKL F13
291567-14291569-15
Colour versions (These are renders and might not be 100% accurate in colours)
291555-16291557-17291559-18
291561-19291563-20291565-21
Weights:
291573-22291575-23291577-24
Assembly:
285921-25
Akuma Keycaps
293575-26293577-27
294110-28294112-29
Details:
Material: PBT material
Profile: Cherry profile
Production Method: Doubleshot
Manufacturer: PBTfans
Compatibility: Cherry MX switches and MX-style clones
Colors - Violet black / Heron Blue / Wild Brown / Celery White
Akuma Base Kit
294098-30
Akuma Novelties
294100-31
Akuma Spacebar
294104-32
Akuma Numpad
294106-33
Akuma Nordic
294108-34
Sell Details
Pricing: TBD
Date: TBD
MOQ: TBD
Vendors:
Global Vendor: KBDfans
US Vendor: VALA SUPPLY
EU Vendor: KEYGEM
AU Vendor: Daily Clack
JP Vendor: Yushakobo
CA Vendor: Deskhero
UK Vendor: Prototypist Keyboards
Akuma Deskpads
285672-35 285674-36
285676-37 285678-38
Details
Size: 900 x 400 x 4
Cloth top Surface
Rubber bottom
Black Stitches
Sell Details
Pricing: TBD
Date: TBD
MOQ: TBD
Vendors:
US Vendor: TBD
EU Vendor: TBD
AU Vendor: TBD
JP Vendor: TBD
CA Vendor: TBD
UK Vendor: TBD
Please consider this post a living document, i accept all feedback!
If you have any questions or need to reach me please contact me on: HQ@mightysetups.com or Discord you can also follow me on Instagram
Thank you for your time!
- Fredrik at Mighty Setup
All renders are made by: its.hymn
To-Do List:
Round 2 samples (In process)
Send prototype unit to content creator for build and review content
Announce sale date
Updates 2022-06-09
Round 1 of prototypes have been made and I have to say they look amazing!
We made changes while waiting for the prototypes to be made, here are the changes we made:
• We changed the mounting system and added a leafspring mounting system.
• We added a bridge at the space bar on the plate so that the hotswap PCB will work.
R2 Prototypes are ordered
We also confirmed the price and MOQ
The keyboard price will be: 450$ and the MOQ: 500.
(Photos of the first round of prototypes will soon be updated on the IC)
The front engraving will remain, but there will also be option to remove it when you create your order.
Updates 2022-08-02
R2 Prototypes are made and everythings works perfect! (We had to change the PC plate version cutouts, it had to much flex. This is already fixed.)
We are waiting for the package to be done, this should only take a few more days.
Kbdfans will send one prototype to me and one to Taeha Types for content.
Updates 2022-09-17
GB date announced: Sep 22nd at 7:00 PM PST (Pacific standard time)
Alexotos build stream on Akuma 80%
GB timer kbdfans website
IC-FORM
« Last Edit: Mon, 09 January 2023, 15:14:47 by Mighty Setup »
Offline dan7789
Re: [IC] Akuma, TKL Keyboard, Keycaps, Deskpads
« Reply #1 on: Fri, 29 April 2022, 11:37:29 »
Looks sick!
Offline switchlab.sg
« Reply #2 on: Fri, 29 April 2022, 12:19:34 »
Looking dope! GLWIC!
Offline tuesdaygloom
  • wait.
« Reply #3 on: Fri, 29 April 2022, 12:55:37 »
very lone ronin
Offline BasedCoper
« Reply #4 on: Fri, 29 April 2022, 14:02:21 »
https://web.archive.org/web/20220306014119/https://geekhack.org/index.php?topic=116466.0
Are you the same one who made this, stole from someone else's design? I remember from a Blacksimon stream.
    • Mightysetups.com
« Reply #5 on: Fri, 29 April 2022, 14:18:01 »
Hello! I never stole anything, this is resolved between me and Hali.
Hali and I used the same manufacturer, this manufacturer sent me Halis files without my knowledge, they told me to use it as a template to create my own keyboard.
Everything has changed and there is nothing copied from Hali.
Thanks for bringing it up  :thumb:
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #6 on: Fri, 29 April 2022, 14:23:21 »
everything's been cleared up in dms; i gave permission to post the ic after seeing things being changed in the design
Offline SDKCAMPING
« Reply #7 on: Fri, 29 April 2022, 15:44:03 »
happy to see it was resolved . Design looks solid overall, but what does the engraving above the arrow say?
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
    • Mightysetups.com
« Reply #8 on: Fri, 29 April 2022, 16:01:56 »
Thank you! It says 豪鬼 which is translated from japanese to english: Akuma
Offline DirtyGingy
« Reply #9 on: Fri, 29 April 2022, 19:03:14 »
skipping the IC form as I do not want to give out an email. Is there an option of winkey for the board?
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #10 on: Fri, 29 April 2022, 19:19:12 »
can you share more details on the internals and assembly.
any protos that you're working on?
    • Mightysetups.com
« Reply #11 on: Fri, 29 April 2022, 22:02:16 »
Hello, yes there will be one winkey option and one wkl option.
    • Mightysetups.com
« Reply #12 on: Fri, 29 April 2022, 22:03:40 »
Hello! Yes there will be renders of this and also building video with the prototype. We stil working on this.
Offline yangsiyin
  • Hello World~ Keebs
« Reply #13 on: Sat, 30 April 2022, 07:34:20 »
The novelties are super cool!
Offline Mandabanker007
« Reply #14 on: Sat, 30 April 2022, 11:18:01 »
Those deskmats ball especially the second and third one
Offline Kajoler
« Reply #15 on: Sun, 01 May 2022, 03:23:07 »
Interesting, I'd like to see the prototype. What colors will there be for the board?
>:0
    • Mightysetups.com
« Reply #16 on: Sun, 01 May 2022, 07:40:02 »
Hello we are excited for that aswell! Our idea at the moment is to offer 6 colours.
Black, white, purple, blue, red, gray.
    • Mightysetups.com
« Reply #17 on: Thu, 05 May 2022, 13:30:03 »
!!! UPDATES !!!
Whats done?
Vendors confirmed for the Keycaps:
EU Vendor: KEYGEM
CA Vendor: Deskhero
Keyboard Assembly Render
Plate file confirmed
PCB confirmed
I want to say thanks for all the good vibes!
Offline Keeblet_257
« Reply #18 on: Sat, 07 May 2022, 02:01:03 »
can we get some renders of the board in the different colours? I know that renders dont represent the product to 100% but it gives me at least a idea on what it may look like/turn out.
    • Mightysetups.com
« Reply #19 on: Sat, 07 May 2022, 05:44:48 »
Hello, thanks for the feedback! I updated the post with keyboard colour versions! keep in mind that these are renders and that the colours might not be 100% accurate.
Offline Key_Capt
« Reply #20 on: Sat, 07 May 2022, 16:16:44 »
Look beautiful, I'm in for a forest green one.
desk mats are really nice as well.
Offline DaaDaa
« Reply #21 on: Sat, 07 May 2022, 23:45:02 »
darn, this is excellent, i have t0 have one.
piggy60 red upgraded PVD w/ GMK umka zaku | tiramisuit w/ GMK noire JWK silk emerald | mr.suit black/chrome glossy chamfers w/ GMK minimal cow POM stem | jelly epoch w/ SA oblivion zaku | mode80 deco w/ gmk boneyard alpaca | mode 80 imperial with ePBT origami alpaca| MODE80 viridian /w CRP boba LT | RAMA thermal kuro w/ GMK muted 2 pewter | BBox60 C64 wih marshmellows and c64 keycaps | MODE Sonnet green /w MW voynich gateron ink box pink
Offline DaaDaa
« Reply #22 on: Sun, 08 May 2022, 11:21:51 »
would it be possible to offer the option to buy extra top cases? id like to buy one unit with two top cases.
Offline strikerfreeZ
« Reply #23 on: Sun, 08 May 2022, 12:10:54 »
Ah, kinda shame that there isnt a SG vendor or a SEA vendor :(
    • Mightysetups.com
« Reply #24 on: Sun, 08 May 2022, 12:50:44 »
The keyboard will be limited to KBDfans. They sell global and it should be available to purchase trough them from SEA.
    • Mightysetups.com
« Reply #25 on: Sun, 08 May 2022, 12:55:38 »
Interesting question! I don't think that would be possible but i will for sure check the possibilities for that.
Weights, plates and other things will be available to buy extra.
Offline Log_In_Again
« Reply #26 on: Sun, 08 May 2022, 18:32:20 »
Looking good! Would like to see VIA compatibility as well if possible.
Is there also an estimate for the price at the moment?
    • Mightysetups.com
« Reply #27 on: Mon, 09 May 2022, 04:10:04 »
Yes the pcb will be VIA compatible.
Offline keeberdan
« Reply #28 on: Thu, 12 May 2022, 18:59:49 »
Wow... they def aren't the same and most keebs are similar in style anyway. Keep your negativity elsewhere.
Offline minibaker67
« Reply #29 on: Thu, 12 May 2022, 20:02:37 »
If I'm not wrong it says 悪魔 but regardless it does mean Akuma!
Offline BasedCoper
« Reply #30 on: Thu, 12 May 2022, 20:40:53 »
I was asking them a question. In the old one, it appeared to be the designer committing theft of the files. Also ironic you say to keep my negativity out for asking, when you seem to be quite negative in your response. The irony!
    • Mightysetups.com
« Reply #31 on: Fri, 13 May 2022, 06:33:26 »
Your correct, thank you for the notice!
Offline DangerousMoth
« Reply #32 on: Thu, 02 June 2022, 07:55:41 »
I really like the keyboard however I'm unsure about the top engraving. It might not appeal to non-Japanese speakers. Have you considered using "Akuma" or just leaving it blank?
Offline DaaDaa
« Reply #33 on: Thu, 02 June 2022, 09:21:35 »
In my Case I am no on Japanese speaker and the top engraving very much appeals to me
    • Mightysetups.com
« Reply #34 on: Thu, 02 June 2022, 10:28:40 »
Hello! And thank you for taking time to comment.
We found japanese very appealing when we designed the keyboard. We trying to offer a japanese theme and the engraving in japanese fits very well with that idea.
Your request depends on taste and we cannot change everything to fit everyones taste im afraid.
Have a good day!
Offline Flybeck
« Reply #35 on: Thu, 02 June 2022, 17:28:18 »
Great looking board. Best of luck :)
Offline LeoneShamoth
« Reply #36 on: Tue, 07 June 2022, 23:51:04 »
Looks great! Glad the problems were resolved with good old communication. It's something we don't see enough sadly. I hope all goes well, the purple looks perfect for a build I have planned!
    • Mightysetups.com
« Reply #37 on: Thu, 09 June 2022, 12:50:20 »
Updates
Best regards
Offline icey_keebss
  • deskmat designer
« Reply #38 on: Sun, 12 June 2022, 09:03:41 »
magnificent like the rest of your work. <3
Offline DosonTheGreat
« Reply #39 on: Tue, 21 June 2022, 21:48:10 »
Will there be an option for soldered PCB?
Offline throwaway776
« Reply #40 on: Wed, 22 June 2022, 08:37:34 »
Please add an FR4 plate option!
Offline superjackie
« Reply #41 on: Wed, 22 June 2022, 10:31:51 »
one of the pictures shows ISO style enter key. does the hotswap pcb support stepped caps and iso enter key?
does the keyboard come with any foam? will there be any reviewers for proto? thanks!
    • Mightysetups.com
« Reply #42 on: Thu, 23 June 2022, 02:46:28 »
Hello! Sorry but no, there will not be any soldered pcb.
Hi there! These renders was made before we decided not to do a iso version, there will only be Ansi offered. Thank you for mention this.
Yes we are currently waiting for the prototype to be ready, this will be shipped to a content creator.
Yes, the keyboard kit will include foam.
    • Mightysetups.com
« Reply #43 on: Fri, 24 June 2022, 09:19:10 »
UPDATE
We decided to offer both options, there ware many of you that stil want to have the engraving, and some of you that dont want it.
So both options will be available!
The voting is now removed.
Poll have been added on the IC-FORM about the japanese text on the front, please visit and vote!
Thank you!
288320-0
« Last Edit: Sat, 25 June 2022, 05:43:05 by Mighty Setup »
Offline QWER|key
« Reply #44 on: Thu, 30 June 2022, 06:07:13 »
There is no poll on the interest check form.
    • Mightysetups.com
« Reply #45 on: Thu, 30 June 2022, 16:33:12 »
We decided to offer both options (Japanese text and no engraving) i belive you missed this on the new comment.
Thank you! :)
Offline shendoo
  • *RAUGHS*
« Reply #46 on: Thu, 30 June 2022, 17:51:20 »
This looks greattt ! Def in on this!
    • Mightysetups.com
« Reply #47 on: Tue, 02 August 2022, 06:09:57 »
Updates! 2022-08-02
•Real photos of the prototype is now uploaded.
•Prototype R2 is completed and everything looks/works good!
•Boxes are in production and soon completed.
•Prototypes will soon be shipped to Taeha Types and me.
•GB date will soon be announced.
Offline Ascensia
Re: [IC] Akuma TKL, Keyboard - PBTfans Akuma doubleshot Keycaps - Deskpads
« Reply #48 on: Sun, 07 August 2022, 22:56:22 »
Will there be options to buy extra plates/pcb?
Offline Ghost of Olympus
« Reply #49 on: Mon, 08 August 2022, 18:17:53 »
Once group buy ends, do you guys have an estimate on when shipping might start?
