Author Topic: [IC]KAM Lucid NOW AVAILABLE FROM YUZUKEYCAPS!!  (Read 23746 times)
Offline Exembe
« on: Fri, 13 May 2022, 16:57:10 »
-NOW AVAILABLE HERE-
BUY HERE!!
-Welcome to the interest check for KAM Lucid-
Carrd Website
Interest Form
Inspired by the fashion style of Gothic Lolita, this set features dark and bright colors with a hint of red to complement it.
I decided to go with a lowercase font for added cuteness.
Show off your dark/cute gothic side with this keycap set!
Keyreative is the manufacturer for the set.
-The Kits-
-Base (Creme)-
-Base (Black)-
-Accessories-
-Accents-
Pricing
-Base (Creme)-
-Base (Black)-
-Accessories-
-Accents-
Deskmats
TBA open for collaborations
Cables
Artisan Keys
*Not actual products but a render of what it could look like
Renders
All renders were created by me.
*Renders may not depict final product.
-ikki68 by Wuque Studios-
-Maja by Vulcan-
—Cypher by Cable Car Designs-
-Isometria by ebastler-
-THOK by BLOQ-
-U80 by RAMA WORKS-
-Moonlight by Misonoworks-
-Fuji65 by CMM-
Vendors
TBA
US/CA:
UK/EU:
PH/SEA:
AUS/OCE:
CHINA:
Contact Me
Discord: Exembe
Signature
Code: [Select]
[url=https://geekhack.org/index.php?topic=117208.0][img width=146 height=120]https://i.imgur.com/Z4QXDId.png[/img][/url]
Last Edit: Fri, 20 May 2022, 16:43:34
« Last Edit: Wed, 28 May 2025, 23:31:56 by Exembe »
Offline Exembe
Re: [IC] DSA Lucid
« Reply #1 on: Fri, 13 May 2022, 17:00:14 »
Reserved for updates
06/09/22 Added artisan renders
06/08/22 Added AUS vendor and higher res renders
06/07/22 Created new novelties and redid renders
06/02/22 Added 7u space to base
05/31/22 Revamped icons and fixed the kitting images
05/26/22 Added cherry profile renders of kitting
05/23/22 New Kits and Renders
05/19/22 Changed the kitting
05/17/22 Changed the font
05/15/22 Added two new vendors
« Last Edit: Thu, 09 June 2022, 18:50:09 by Exembe »
Offline misononyan
Re: [IC] DSA Lucid
« Reply #2 on: Fri, 13 May 2022, 17:10:32 »
awesome concept! what colors are you using?
Offline Exembe
Re: [IC] DSA Lucid
« Reply #3 on: Fri, 13 May 2022, 17:12:04 »
I can message them to you on your discord server
Offline newcharmer
Re: [IC] DSA Lucid
« Reply #4 on: Fri, 13 May 2022, 17:33:46 »
colors are just like akko's ASA dracula.
Offline andromache
Re: [IC] DSA Lucid
« Reply #5 on: Fri, 13 May 2022, 18:16:40 »
I assume for the alphas you're using the open-source lowercase alphas from DSA Berry Yogurt? So will the f-row and TKL nav cluster all be new molds? (unless there are existing molds for lowercase f-row and lowercase TKL nav cluster your renders are based on).
If they'll be new molds, I would super recommend making the font on the nav cluster all the same size.
Offline Exembe
Re: [IC] DSA Lucid
« Reply #6 on: Sat, 14 May 2022, 00:46:38 »
not really, mine isnt completely white like that one
Offline Exembe
Re: [IC] DSA Lucid
« Reply #7 on: Sun, 15 May 2022, 15:41:04 »
Good point i completely looked over the nav cluster, I forgot to make it uniform. As for the font it should be the same as DSA Berry Yogurt
Offline Exembe
Re: [IC] DSA Lucid (Updated Renders and New Kits!)
« Reply #8 on: Mon, 23 May 2022, 18:46:55 »
bumping
Offline DarkS7R
« Reply #9 on: Mon, 23 May 2022, 19:22:59 »
Filled out IC, would probably cop if you could add 1.75u enter
Offline Exembe
« Reply #10 on: Tue, 24 May 2022, 12:28:22 »
yeah i can prob fit that in the base kit
Offline AuthenticDanger
« Reply #11 on: Tue, 24 May 2022, 12:35:54 »
I hate the way the fkeys look. The lowercase 'f' next to a number just looks weird to me.
I'd also love to see a "10" key for XT layouts (you already have an extra "B" for wacky Alice layouts).
F Keys belong on the left.
Offline yangsiyin
  • Hello World~ Keebs
« Reply #12 on: Wed, 25 May 2022, 07:37:23 »
I believe if the 7u space comes in the base kit would be better.
Offline Exembe
« Reply #13 on: Wed, 25 May 2022, 13:43:26 »
not sure what you mean by a "10" key sorry
ill see what I can do about the spacebar
Offline William_S_Jones
  • Best Prime Ever!!!
Re: [IC] DSA Lucid (Poll: DSA or Cherry)
« Reply #14 on: Fri, 27 May 2022, 06:57:56 »
I didn't see a poll to vote, so I say "DSA."
Sent from my SM-G998U using Tapatalk
Offline Mr Chrome
« Reply #15 on: Fri, 27 May 2022, 08:18:08 »
Voted DSA for the lowercase legends, but really it depends on manu.
“This plastic rectangle is alright. The plastic rectangles on top of it, though...”
Offline WbzShenyu
« Reply #16 on: Sun, 29 May 2022, 08:59:27 »
I didn’t see any poll (maybe I’m just blind xD) but I’d say Cherry. I’m not a huge fan of lowercase legends "^^
« Reply #17 on: Sun, 29 May 2022, 13:19:24 »
https://i.imgur.com/C24QskC.jpg
Instead of using the numpad "0", it would be nice to have a "10" since there are so many boards now with 2 columns on the left.
Offline Exembe
« Reply #18 on: Tue, 31 May 2022, 14:46:09 »
Oh, okay I think I could add that to the base kit or to the numpad.
Offline Exembe
Re: [IC] DSA Lucid (Revamped Novelties)
« Reply #19 on: Tue, 07 June 2022, 19:04:25 »
bump
Offline caroeggu
« Reply #20 on: Fri, 17 June 2022, 18:13:02 »
Nice work! I'm not a big fan of DSA since I don't like lowercase letters- but I might consider this set as my first (and maybe only) DSA set :)
Offline Exembe
Re: [IC]DSA Lucid (Looking for Manufacturer)
« Reply #21 on: Tue, 17 September 2024, 21:41:14 »
bumping after years
Offline keebibi
    • My Discord Server
« Reply #22 on: Wed, 18 September 2024, 03:05:40 »
Would you consider changing the profile to KAM or PBS?
Offline Exembe
« Reply #23 on: Wed, 18 September 2024, 09:41:43 »
Yes im up for anything honestly at this point
Offline keebibi
    • My Discord Server
« Reply #24 on: Wed, 18 September 2024, 12:18:03 »
In that case, I'd recommend reaching out to Keyreative! I really like them as a manufacturer.
Offline Exembe
« Reply #25 on: Wed, 18 September 2024, 13:16:09 »
Thanks i will definitely reach out.
Offline CaptainSterling
« Reply #26 on: Fri, 20 September 2024, 15:59:47 »
Keyreative could be good. I like their quality and pricing is usually fair. Love the novelties here!
Offline Exembe
« Reply #27 on: Sat, 21 September 2024, 04:02:32 »
Yes already talking to someone at Keyreative
Offline kajahtaa
Re: [IC]KAM Lucid (Reworked, New Manu, and Kits)
« Reply #28 on: Sun, 22 September 2024, 11:39:42 »
Would love to have this run as KAM
GL
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #29 on: Sun, 22 September 2024, 20:14:28 »
Please consider adding some other home keys to support alternative layouts.
A minimum of six keycaps are needed: non-homing F and J plus homing U, H, T, and N to cover Dvorak and Colemak. This covers seven other layouts
     Colemak DH
     ColemaQ
     Asset
     Workman
     Niro
     Norman
     QWPR
as well.
Here is a summary of how 33 previous uniform profile sets
     DSA 2077, Berry Yogurt, Coffee House, Encore, Granite, Hana, Legacy, Miami Dolch, PetriKeys, Royal, Scientific;
     KAM 80s After Dark, Bouquet, Command, Ghost, KAMistry, Lil Dragon, Little Pilot, Outline, Sewing Tin, Superuser, Wraith;
     MKB Legend;
     SA-R3 1976, Mizu, Nuclear Data;
     SLK Dessau;
     XDA Canvas, Canvas R2, Canvas R3, Godspeed, Oblique, Scrabble.
provided alternative homing support:
For 29 of 33, non-homing F and J were in the base or alphas kit.
Four of those 29 also had homing U, H, T, and N in the base or alphas kit.
Some sets added other home keys for various reasons:
   E to support BÉPO and Neo layouts (11/33)
   E + I and S for middle finger homing on all layouts mentioned above except Neo (5/33)
   A to support the QGMLWY layout (8/33)
   D and K for QWERTY middle finger homing (3/33)
Perhaps to minimize kit count, SLK Dessau's homing U, H, T, and N were part of its International kit.
« Last Edit: Sun, 22 September 2024, 21:32:02 by dvorcol »
Offline SacredMundane
« Reply #30 on: Mon, 23 September 2024, 15:51:46 »
a dark alphas kit would be sick
Offline dvorcol
« Reply #31 on: Mon, 23 September 2024, 20:39:40 »
I forgot to mention that Colemak and some other layouts use 1.75u Backspace in place of CapsLock. This Backspace is usually in the Mods kit or a stand-alone Homing kit.
Some QWERTY users also replace CapsLock, but usually with Control or Function rather than Backspace. This replacement is often in the Mods kit.
Offline Exembe
« Reply #32 on: Thu, 26 September 2024, 21:33:34 »
Great suggestion! i love the look of the dark alphas
Offline Ciantha
« Reply #33 on: Thu, 10 October 2024, 11:51:55 »
Some feedback on the updated 40s kit:
  • I've never seen accent backspace, if that's not something you personally want then I wouldn't bother with it
  • the "Z" for QAZ should be 1.75u
  • Speaking of QAZ if there's room for it in the kit a ".>" in 1.5u would be nice (very optional though)
  • Since there's no separate ortho kit a second 1u shift would be nice
  • On the subject of ortho it frequently uses 2x2u bars and most people want them to match
Offline Ciantha
« Reply #34 on: Thu, 10 October 2024, 11:54:49 »
Just saw the norde kit:
you need to have a look at the åäö. As you can see the circle/dot/dots are quite close to the letter. Right now it looks kinda like the key does a and if you hold shift you get a circle.
« Reply #35 on: Thu, 10 October 2024, 18:30:36 »
I love this set's update, I love KAM profile. I will be in for this come GB time!
Sent from my Pixel 8 Pro using Tapatalk
Offline Exembe
« Reply #36 on: Thu, 17 October 2024, 20:29:37 »
Hoping to get to GB soon actually.
Fingers crossed!  :D
Offline ryduann
Re: [IC]KAM Lucid (Reworked, New Manu, New Novelties, and Kits)
« Reply #37 on: Wed, 15 January 2025, 21:42:55 »
any updates to this? I'm really excited for this theme on KAM, and hope the GB is coming soon!
Offline Exembe
Re: [IC]KAM Lucid NOW AVAILABLE FROM YUZUKEYCAPS!!
« Reply #38 on: Wed, 28 May 2025, 23:32:20 »
bump bump buy now please and thank you!
Offline dvorcol
« Reply #39 on: Thu, 29 May 2025, 22:01:02 »
This is the first IC I've seen that went to YUZU. Their system looks really nice.
Can you change the CAPS LOCK legend to BACKSPACE for Colemak and Colemak-DH options?
Offline Exembe
« Reply #40 on: Fri, 30 May 2025, 10:20:41 »
Yeah! Super excited to have them make the set, i love their website configuration program thing. I can see if i can make that change you requested
