Author Topic: What would be the highest grossing group buy?  (Read 2639 times)
Offline IceCandle
« on: Fri, 20 May 2022, 09:57:16 »
« Last Edit: Sun, 05 June 2022, 00:51:56 by IceCandle »
Offline granola bar enthusiast
Re: What would be the highest grossing group buy?
« Reply #1 on: Fri, 20 May 2022, 10:03:27 »
it's hard to tell since some group buys have bloated prices and higher profits than others, based on popularity the Jelly Epoch would maybe be up there.
Offline MIGHTY CHICKEN
« Reply #2 on: Sun, 22 May 2022, 11:30:12 »
Most likely the polaris or vega, but I do recall fuji65 having some absurd amount of units
Offline Leslieann
« Reply #3 on: Sun, 22 May 2022, 21:54:12 »
Total profit or profit per capita?
The highest grossing total is likely not a keyboard but a switch group buy.
Back when it wasn't easy to find individual switches (or get alternatives), much less for cheap there was a running group buy for Cherry and Matias switches run by 7bit, it most likely destroys any keyboard group buy several times over.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline IceCandle
« Reply #4 on: Thu, 26 May 2022, 10:46:56 »
« Last Edit: Sun, 05 June 2022, 00:51:47 by IceCandle »
