Author Topic: [IC] GMK HASRO/SAV Add-on kit - Vendors Announced  (Read 49911 times)
Offline Peter6109
  • Working on my own set.
« on: Fri, 27 May 2022, 20:26:21 »
Tastierarossa by Skok
This set is intended to pay homage to OG dye sub HASRO/SAV sets, but in ABS rather than PBT. I originally wanted to run a full base kit but decided to run alphas only to not conflict with sets running soon or that have run recently. The original version was run a long time ago in 2017, so I want to bring it back slightly modernized with Qarmaa's updated sublegends. Thank you for taking the time to read through this post and please fill out the IC form with any feedback.
Inspiration
Photo from Litster on Deskthority
Kitting
Kitting is still yet to be finalized. If you have any comments or suggestions about the kitting please leave a note in the IC form.
Colors
L9 U9 CR P3
Board Renders
Renders by Skok. Boards in order: Jane V2 by TGR, Tastierarossa by Skok
Pricing(TBA) and Vendors
US Vendor -
SEA Vendor - iLumkb
CA Vendor - DeskHero
AU Vendor - Switchkey
EU Vendor -
CN Vendor - zFrontier
KR Vendor - Swagkeys
Special Thanks
Simon's Discord Community
AndyV’s Discord Community
Keyboard Render Kit and its Discord
qarmaa for the sublegends
Skok for the renders
If you have any other questions, comments, or are a vendor interested in running this set, please reach out to me on discord: Peter#1369
« Last Edit: Thu, 02 November 2023, 17:44:44 by Peter6109 »
Offline Peter6109
Re: [IC] GMK HASRO/SAV Add-on kit
« Reply #1 on: Fri, 27 May 2022, 20:27:21 »
Updates
Changing sublegends to qarmaa's thick sublegends.
Moving the sublegend on the pipe key and ~ key to better match the original keycaps.
Adding mod pipe and mod tilde to the kit
Adding icon+text tab as well to the kit
Added SEA and US Vendors
Changed overall kitting from suggestions from the IC form
Added Vendors
« Last Edit: Sun, 19 June 2022, 17:31:02 by Peter6109 »
Offline ankit
  • Formerly ankit-sachdeva
« Reply #2 on: Fri, 27 May 2022, 20:27:29 »
« Last Edit: Tue, 05 December 2023, 11:09:33 by ankit »
Offline herbologist
  • beige enjoyer. send help.
« Reply #3 on: Fri, 27 May 2022, 20:29:03 »
Add on kits are so based
Offline LaserCrafter
  • reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
« Reply #4 on: Fri, 27 May 2022, 20:30:11 »
goddamn
Keyboard Collection: Unikorn, Orion v2.5, Orion v3, Realforce 87u, Viper v3, NMB RT8756CGR, Unicorn x Legend, Das II, TC-V3, Jetfire, Wang 325-3770, Lightpad v2
Keyset Collection: OG Doubleshots, CRP 2551 R4, Muted 2, Cyan R1, WoB, DCS Wyse, ISO OG POM, ePBT Blanks, BSP Blanks, BoW + Gigachild
Offline evillguy
« Reply #5 on: Fri, 27 May 2022, 20:34:01 »
Uhm... I need this. Like right now.
Offline VersusXO
« Reply #6 on: Fri, 27 May 2022, 20:41:22 »
Looks amazing!
Offline Neely_12
« Reply #7 on: Fri, 27 May 2022, 20:43:29 »
Please make the extra tab text+icon or add an extra.
Offline plag
  • Formerly pepperonichicken
  • i also go by plag
« Reply #8 on: Fri, 27 May 2022, 21:02:19 »
i like the decision to go with just the alphas. really looking forward to some abs red Cyrillic goodness  :thumb:
Offline Baka Bot
« Reply #9 on: Fri, 27 May 2022, 21:26:41 »
I like this. I like it a lot
Offline dérobé
« Reply #10 on: Fri, 27 May 2022, 21:28:28 »
Yay, super excited for this.
Maybe I'm the only person who's perplexed by this, but I've noticed that the '/' mod-pipe sublegend is on the upper half of the key in newer GMK cyrillic kits, instead of on the bottom like in older GMK sets or OG hasro/sav. Anyone knowledgeable can explain why this is the case?
Would much prefer the '/' being on the bottom for the sake of accuracy if it's possible.
ETA: Similar thing with the 'Ë' sublegend as well
« Last Edit: Fri, 27 May 2022, 22:29:54 by dérobé »
Offline spedywin
  • Formerly spedywin
« Reply #11 on: Fri, 27 May 2022, 21:39:40 »
alphas only is very amazing, glwic
Offline LXVRGS
« Reply #12 on: Fri, 27 May 2022, 22:10:35 »
i want it i want it bad
Offline Hentoys
« Reply #13 on: Fri, 27 May 2022, 22:52:44 »
I like this! Please make a windowed key!
Offline ankit
« Reply #14 on: Sat, 28 May 2022, 00:30:23 »
Offline HalfScrim
  • no fun. not ever.
« Reply #15 on: Sat, 28 May 2022, 02:44:22 »
Like others said, smart move on running just the alphas. Count me in!
Offline pngu
  • send noots
« Reply #16 on: Sat, 28 May 2022, 05:14:08 »
you managed to get 2 out of 2 names in a 5 word sentence wrong, bravo
Offline actress
« Reply #17 on: Sat, 28 May 2022, 10:20:08 »
Exactly what's needed. I am 100 % in for multiple kits. If you also do green Griseann on beige as kit 2 it would be the cherry on top. Tyvm!!
edit: Also imo text+icon tab is a must for an og add-on kit
« Last Edit: Sat, 28 May 2022, 10:22:11 by actress »
Offline Ensaum
« Reply #18 on: Sat, 28 May 2022, 10:58:21 »
Yes please!
Offline Peter6109
« Reply #19 on: Sat, 28 May 2022, 15:27:58 »
Fixed, nice catch
Offline Peter6109
« Reply #20 on: Sat, 28 May 2022, 15:30:43 »
Switching sublegends to qarmaa's sublegends. Moving the sublegend on the pipe key to align on the bottom instead of the top to match the original set better. Adding mod pipe and mod tilde to the kit.
« Last Edit: Sat, 28 May 2022, 15:34:46 by Peter6109 »
Offline Peter6109
« Reply #21 on: Sat, 28 May 2022, 16:40:01 »
I like this as well. Will change.
« Reply #22 on: Sat, 28 May 2022, 16:44:32 »
bruh it's fine, just don't worry about it.
« Reply #23 on: Sat, 28 May 2022, 16:45:32 »
Both variants exist on the original keyboards when it comes to that legend. It's all a matter of manufacturing date; Cherry changed the position at some point.
For example, if you look here you'll see two G81-3100SAVs made on different dates, each using a different position for that legend.
Agreed on the mod pipe legend though!
« Last Edit: Sat, 28 May 2022, 16:48:08 by Photekq »
Offline Chippy
  • sus chef
« Reply #24 on: Sun, 29 May 2022, 01:59:48 »
What currently running sets would this conflict with if it included mods or was a base kit.
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline mr_foggy
  • neue = nope
« Reply #25 on: Mon, 30 May 2022, 17:19:17 »
seconding this question.
Offline Mikhail
« Reply #26 on: Mon, 30 May 2022, 20:25:37 »
HASRO/SAV in ABS and L9 U9 is HAV
Offline Qarmaa
« Reply #27 on: Tue, 31 May 2022, 18:48:13 »
Proper pipe sublegend placement is on top 'cause this follows the logic when you hold Shift to enter the secondary legend (Shift + , → < and etc). Ё follows the same logic as well (it's primary legend in Cyrillic layout, so should go on the bottom).
Offline Peter6109
« Reply #28 on: Wed, 01 June 2022, 20:01:23 »
I think mainly hineybeige is going to group buy soon. Once I get the new renders I'll update the IC form to ask if people would prefer just alphas or a whole kit. I think just an alphas kit should be enough.
« Last Edit: Fri, 03 June 2022, 13:17:59 by Peter6109 »
Offline Agilr
  • Never stop achieving
    • Discord Server
Re: [IC] GMK HASRO/SAV Add-on kit - Updated(Kitting, Vendors and Renders)
« Reply #29 on: Sat, 04 June 2022, 23:39:17 »
why isn't this a base kit?
Offline Fraaaan
« Reply #30 on: Sun, 05 June 2022, 03:19:37 »
Read the comment above yours...
Offline actress
« Reply #31 on: Sun, 05 June 2022, 05:30:06 »
Nice update! I agree alpha add-on is the move
Offline beelzking
« Reply #32 on: Sun, 05 June 2022, 06:34:25 »
Alpha add-on only so good :gaynut:
GLWIC
« Reply #33 on: Sun, 05 June 2022, 21:32:16 »
at least for me personally, it's hard to grok exactly why people would want a worse version of HASRO/SAV, since GMK's pad print quality has been mixed over the years, but reading through the thread there's clearly at least some demand for it, so i'll just hold my L on this one
i already have the CRP version so i'll be skipping, but respect a good add-on kit regardless, gl
Offline Hinkerbottom
« Reply #34 on: Mon, 06 June 2022, 20:35:08 »
Pretty cool Peter, just like you. GLWIC :prayge:
Offline Peter6109
Re: [IC] GMK HASRO/SAV Add-on kit - Vendors Announced
« Reply #35 on: Sun, 19 June 2022, 17:37:53 »
Vendors announced!
Offline packman86
  • Morning Coffee
« Reply #36 on: Sun, 19 June 2022, 18:10:26 »
Neat addon kit for those with an existing beige set. GLWGB!
TGR Jane V2 | TGR Jane V2 CE | TGR Alice | TGR Dolice | TGR 910 | TGR x Singa UNIKORN 60 | Matrix 8XV 2.0 Korea Version | Matrix 8XV 2.0add | LZ CLS s h x | Duck Jetfire | TX-CP | QXP | Noxary X65 | RAMA M60-A | Model F62 "Kishsaver" | Daji OC 2XL FnF Black
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #37 on: Sun, 19 June 2022, 19:13:04 »
Can you please get an EU vendor onboard?
Offline Arrinura
« Reply #38 on: Sun, 19 June 2022, 20:10:24 »
If there's one thing to fix, the pipe key should have a split vertical line.
Offline ideus
  • Björkö.
« Reply #39 on: Sun, 19 June 2022, 20:27:58 »
I also prefer the split bar to the pipe (full vertical line) aesthetics-wyse; yet, if the change would be made, all the pipes in the set should be split for consistency. However, in practice, the split bar character is not used anymore. Maybe you want to enlighten us on any actual use for it, in any language.
    • Twitchy Homepage
« Reply #40 on: Mon, 20 June 2022, 16:43:33 »
Around what date are you planning to launch this on? :)
Offline Arrinura
« Reply #41 on: Mon, 20 June 2022, 20:48:08 »
It is true that it's not used anymore but I prefer keeping the aesthetics similar to the original, that's all.
Offline ideus
  • Björkö.
« Reply #42 on: Tue, 21 June 2022, 07:21:49 »
That's a legit point. However, GMK may not have the molds to produce the split bar legend at all the rows where the set includes a pipe-back-slash. Let's see what the OP decides.
« Reply #43 on: Wed, 22 June 2022, 20:31:37 »
Offline blunt
« Reply #44 on: Wed, 26 October 2022, 14:30:08 »
With hineybeige announced, is there any ETA for when this is running?
Offline Edric
« Reply #45 on: Sat, 29 October 2022, 09:41:17 »
+1 here.
As a guy who's actually using a RU layout, several things piss me off with 99% of Cyrillic sets on the market (and are the reason why I still don't own a single Cyrillic set despite typing in RU daily):
1. FONTS. Every time I see that OG Д or that OG Й I want to vomit all over my keyboard. Why do we still have sets in that font is beyond me. I'm super hyped for this set because it's using a font that actually looks great.
2. Small errors here and there. Some sets miss some sublegends. In other sets the sublegend placement is off.
OP has a chance to make a set that's actually not plagued by all of these problems, but then we'll need Ё in the bottom, red "/" in the top. You can check how RU layout works here: https://learn.microsoft.com/en-us/globalization/keyboards/kbdru.html.
Offline Qarmaa
« Reply #46 on: Sat, 29 October 2022, 10:10:27 »
Check out my WoB Red Cyrillic set. Wink-wink.
Offline Peter6109
« Reply #47 on: Sat, 29 October 2022, 12:57:52 »
Must have set for sure!   :thumb:
Offline Peter6109
« Reply #48 on: Sat, 29 October 2022, 12:59:41 »
No news from me yet sadly, EU and UK vendors pulled out so need to find replacements.
Offline Peter6109
« Reply #49 on: Sat, 29 October 2022, 13:02:54 »
I'll change this for the next update.
