Author Topic: [IC] Troublemaker - FRL Compact 1800 keyboard  (Read 32797 times)
Offline kbye
« on: Sun, 29 May 2022, 10:36:10 »
Troublemaker
Troublemaker is a compact-1800 minus the F-row. It is top mounted via the PCB, which will allow for plateless builds.
When I designed Nue, it was meant to be a board I used at home. Now that I'm back in office for work, I wanted a more work-centric layout.
Thus, troublemaker was born. It's called troublemaker due to the massive headaches I incurred while designing it.
Interest check form: https://forms.gle/gQoJybE6pqUGhf2M6
Discussion and feedback on my discord: https://discord.gg/Sv9a37n
DETAILS
  • Case Angle: 7 degrees
  • Mounting: PCB Top Mount (o-ring experimental)
  • Case Material(s): 6063 aluminum, Frosted polycarbonate
  • Weight Material(s): Sandblasted Brass, Polished Stainless Steel
  • Accent Material: Polished Stainless Steel
  • Front Height: ~18mm
  • Plate:  Aluminum, PC, FR4
  • 1.2mm Atmel PCB + C3 daughterboard. QMK/VIA compatible
  • no PCB/case foam but will provide files to have them cut if you desire
I wanted a work board which meant having a numpad, but also wanted a compact layout with isolated arrow keys in order to avoid accidental keypresses.
A subtle cherry-style lip helps keep the case profile low and allows for a place to rest your palms, but a common problem is that it interferes with the arrow cluster in CP1800 layouts.
I am not a fan of how far the lip extends out in vintage boards (see G80-1800), so with troublemaker I kept the profile flat on the arrow keys. This creates some visual interest and provides uniform bezel widths around the board (0.5u on the top/middle/bottom, 0.25u on the sides and arrows)
LAYOUT
  • Stepped Caps
  • ISO
  • Split Backspace
  • Split Numpad
  • 6.25U/7U/10U/3U Split Bottom Row
Layout should accommodate a broad audience and I have no interest in changing it at this time.
The decision to use 3U split space instead of 2.25/2.75 is because I personally like 3U and want to push more designs to include them. 3U wires will be included.
10U for memes
COLORS
Colors not final. Would like to run 2/3 colors max.
Black
Blue-Grey / Silver
E-white
PRICING/AVAILABILITY
  • $450 USD (tentative)
  • 50-100 units depending on interest
  • Group Buy in Q4 2022
  • Ran by me @ store.studiokestra.ca (ships from Canada)
REVISIONS
Prototype R1 (August 2021)
Photo album: https://imgur.com/a/HXBT3rr (courtesy @jlai.keebs)
  • USB aligned to indicators
  • E-White top / Polycarbonate bottom
  • Interior Brass Weight
  • *Screwless* exterior
Feedback notes:
Used for a couple months for work. Typing feel was decent, wasn't a big fan of the sound which I initially attributed to the PC bottom.
This was my first "screwless" exterior design, where the screws were located on the interior beside the switches.
I had issues with the switches interfering with the screws which made it hard to assemble/disassemble.
Indicator LEDs rattled the top case.
Prototype R2 (April 2022)
Photo album: https://imgur.com/a/2S9J2Yq (courtesy @stillchromatic)
  • Centered USB Port
  • Black Alu top/bottom, Stainless Steel Weight, Raw Alu Accent
  • Blue-Grey Alu top/bottom, Sandblasted Brass Weight, Stainless Steel Accent
Feedback notes:
Screw / switch interference was fixed.
Switched indicators to SMD mounted RGB lights to prevent the rattling.
Sound was a bit better, but I figured out that the meh acoustics were due to the mounting style.
Some screwhole tolerances needed fixing but overall I liked the visual appeal.
Prototype R3 (Planned for Aug 2022)
  • USB Port location dictated by IC
  • New color TBD
  • Case/Weight Materials TBD
  • Refine engraving
  • Exterior screw design, Geon molded feet
  • Add tadpole mounting option
  • Add gummy-o ring mounting option
The interior screw design is not user-friendly so I'm ditching it. The final proto will be assembled via exterior screws covered by Geon molded feet.
I am also adding 2 more mounting methods. My hope is that the tadpoles will soften the bottom-out sound that I don't like.
Adding O-Ring as another mount option (a plate would be mandatory in this case).
TO-DO
  • finish gathering feedback
  • order 3rd prototype
  • send to streamers for review
  • prepare for GB
Thanks for looking!
« Last Edit: Sun, 29 May 2022, 10:59:54 by kbye »
Offline o3okevin
Re: [IC] Troublemaker - FRL Compact 1800 keyboard
« Reply #1 on: Sun, 29 May 2022, 10:44:35 »
Yoooo let's ****in go board of the year
Offline finalarcadia
« Reply #2 on: Sun, 29 May 2022, 10:49:06 »
Very nice design, good work
Sent from my SM-S908U1 using Tapatalk
Offline pixelpusher
« Reply #3 on: Sun, 29 May 2022, 10:53:33 »
I like the solution for the front bezel.  Hopefully your attention to detail in revisions will make this a phenomenal board.
Offline noodleman
« Reply #4 on: Sun, 29 May 2022, 11:03:06 »
take my money!
Offline mmayhem17
    • Steam profile
« Reply #5 on: Sun, 29 May 2022, 11:05:22 »
looking good  :thumb:
Online Rob27shred
  • Insane in the Membrane! 👻
« Reply #6 on: Sun, 29 May 2022, 11:10:08 »
I'm ready to make some trouble!
Offline ankit
  • Formerly ankit-sachdeva
« Reply #7 on: Sun, 29 May 2022, 11:53:53 »
This is so cool. I realllly like this idea/aesthetic.
Offline reticent
« Reply #8 on: Sun, 29 May 2022, 12:52:25 »
The duo tone aesthetic with the brass weight and the stainless steel accent piece is probably my favourite part of the board. That and the fact that the arrows are detached without having a huge ass lip.
Great work man, you know I'm in for sure.
Offline Cylent
  • Formerly cylentshadows
« Reply #9 on: Sun, 29 May 2022, 13:00:40 »
Goddammit, 1 day after I purchase the odin v2 you post this IC. I will be watching your IC carefully, GLWIC!  :thumb:
Offline asciisii
« Reply #10 on: Sun, 29 May 2022, 13:09:03 »
Insanely nice, too bad its a form factor I could never use  :)) Really love the lip
Offline spedywin
  • Formerly spedywin
« Reply #11 on: Sun, 29 May 2022, 13:33:55 »
looks so hot
Offline BRSxIgnition
« Reply #12 on: Sun, 29 May 2022, 13:37:43 »
Love the style of this case and the target price is dead on.
Excited to see how it sounds and feels, especially with tadpole and O-Ring gasket mounts.
I think Navy Blue may work well rather than Blue-Gray, but the black and white are both super sleek with the three tone base/weight combo.
Will be watching this with great interest.
Offline Draxion
« Reply #13 on: Sun, 29 May 2022, 13:48:21 »
I'm in
Offline clik_clak
« Reply #14 on: Sun, 29 May 2022, 14:03:40 »
Gorgeous board!
I'm definitely going to try and grab one of these when they run!
Offline misswaffle
« Reply #15 on: Sun, 29 May 2022, 16:07:46 »
Yet another amazing design!! Love the look of this and the layout
Offline BasedCoper
« Reply #16 on: Sun, 29 May 2022, 16:36:07 »
Great job with another fantastic project. GLWIC
Offline irithyll
« Reply #17 on: Sun, 29 May 2022, 17:38:15 »
Really interesting in seeing how the third round prototype will turn out!
Offline bshendy
« Reply #18 on: Sun, 29 May 2022, 18:09:21 »
Interesting bezel, Big long thic brass weight w/ an internal weight under alphas, subtle branding, an IC that's straight to the point and isn't ostentatious, new interesting option in a relatively uncompetitive 1800 layout market...
This is like getting delivered an A+ steak that's perfectly seasoned with salt and pepper.
On a side note, this reminds me a lot of the Venn65, which isn't a bad thing by any means.
Offline Arithmetics
« Reply #19 on: Sun, 29 May 2022, 18:42:46 »
+1 for 3u nice to see people finally implementing
Offline synthetics
  • very cool
« Reply #20 on: Sun, 29 May 2022, 19:59:23 »
Hot.
Offline Ashen_21
« Reply #21 on: Sun, 29 May 2022, 20:24:49 »
Damn this looks clean!
Offline TyPo.mk
« Reply #22 on: Sun, 29 May 2022, 21:48:58 »
Pretty cool board, looks nice
Offline Ghostinn
« Reply #23 on: Mon, 30 May 2022, 09:26:46 »
Arrow cluster blocking the lip is a really gorgeous visual part of this board, excited to see this move forward!
Offline infinitum
  • i buy expensive plastic
« Reply #24 on: Mon, 30 May 2022, 12:26:31 »
damn nice front lip, might cop.
glwic!
Offline L0fi
  • Fn row is only for Minecraft
« Reply #25 on: Mon, 30 May 2022, 21:58:25 »
Really like the mirror finish on the back. Definitely gonna consider because I/m looking for a good full-size kb. GLWIC :D
Offline fujitasenpai
« Reply #26 on: Wed, 01 June 2022, 01:10:56 »
Exactly my situation. And yeah I'm definitely getting this one as well. I love the simplicity of it.
Offline bitbot
« Reply #27 on: Wed, 01 June 2022, 01:27:46 »
nice looking board  :thumb:
Offline LegendsWorks
  • thocc
« Reply #28 on: Wed, 01 June 2022, 02:14:15 »
Joining this for sure :thumb:
Offline deska
« Reply #29 on: Wed, 01 June 2022, 09:18:22 »
this is so clean! I especially love the spacing around the arrows
Offline treeleaf64
    • treeleaf64
« Reply #30 on: Wed, 01 June 2022, 10:25:49 »
Need more mounting tab for stability
Everyone must pay the cat tax
« Reply #31 on: Wed, 01 June 2022, 12:31:20 »
Would be interesting to see how O-Ring gets implemented - would potentially make mounting points a non-issue if it was the primary mounting method.
Offline granola bar enthusiast
« Reply #32 on: Wed, 01 June 2022, 15:19:05 »
very cool, will consider getting
« Last Edit: Sat, 04 June 2022, 10:09:01 by granola bar enthusiast »
Offline kbye
« Reply #33 on: Thu, 02 June 2022, 18:06:38 »
Thanks for all the good feedback so far.
  • a lot of you want to see burgundy so I will prototype that for R3
  • someone asked for caps and numlock LEDs but doesn't make sense because I already have the indicators there
  • I prototyped a PCB with flex-cuts (not shown but pictures in my discord). Plateless, it gave an uneven typing feel and bottomed out the switches so unlikely I will implement
  • I forgot to put in the IC form whether people prefer sandblasted stainless steel or polished. but I received 2-3 comments that they prefer sandblasted SS
  • I would love to run it with some regional vendors but that would probably increase the price of the board. I also like to personally QC the boards. but we'll see, I'll leave that open
286913-0
idk who keeps putting this in my ICs lol but ty <3 you all
Typing is quite stable because it is top mounted, but will be revising mounts slightly for the tadpole mounts anyway.
« Last Edit: Thu, 02 June 2022, 18:12:37 by kbye »
Offline empa
« Reply #34 on: Thu, 02 June 2022, 19:26:46 »
def. keen on this one. subscribed
Offline hottrout
  • I'd Hit Dat Key
« Reply #35 on: Fri, 03 June 2022, 03:45:56 »
Nice layout.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline acme64
« Reply #36 on: Fri, 03 June 2022, 21:04:20 »
this is mislabeled
1800 - f row is a 65% with number pad
Offline SwitchKeys
    • SwitchKeys
« Reply #37 on: Fri, 03 June 2022, 21:44:24 »
Inject this into my veins
Offline clik_clak
« Reply #38 on: Sat, 04 June 2022, 09:22:41 »
this is mislabeled
It’s far closer to an 1800 than a 65.
Imagine thinking you can tell a designer what to label their keyboards as.
Offline WK
« Reply #39 on: Mon, 06 June 2022, 13:39:46 »
I don't like it. I LOVE IT!
Offline Bachoo
« Reply #40 on: Mon, 06 June 2022, 14:01:56 »
All your boards have been nothing but bangers bro, GLWIC <3
Offline JQ27
« Reply #41 on: Mon, 06 June 2022, 17:02:55 »
I love me some FRL 1800 boards.  :thumb:
Offline KurtKurtson
« Reply #42 on: Tue, 07 June 2022, 06:01:31 »
Very nice. I support the tadpole mount. Looking forward to use this board alongside my Cypher and the incoming W1-AT. By far the best layout for office use.
Offline GraffitiDecos
« Reply #43 on: Tue, 21 June 2022, 20:23:59 »
I like this a lot!
Silly question: how well do the indicators work? On my cypher they are pretty much useless ; the angle doesn't work, they aren't bright enough and they bleed to into the adjacent keys.
Also, Canadian designer/vendor? Saving on shipping is a definite plus!
Sent from my SM-S901W using Tapatalk
Offline LumiP
  • A lil Faedude on the net. Fave layout is FRLTKL!
    • Sometimes I do builds on Twitch! :3
« Reply #44 on: Wed, 22 June 2022, 13:30:14 »
I absolutely adore this design! GLWIC!
Honestly, I don't need another FRL 1800 but what I can tell you is that if this comes out at the correct time you absolutely will have my money. LOVE LOVE LOVE.
Current Boards: Aaru TKL Old Dark Sand, Drop + Planck Purple, Mr Suit WKL Black w/Gold Chamfers, Sangeo60 Black, KBD67Lite White, D45 E-Grey, Wind X Pink, NCR 80 Beige, QK65 Dark Green, Gentleman65 Black, Av4 Claymore, TGR x Monokei Tomo Suave Blue, Heracles80 Holy White, Snake60 Rust, Array E-White, Capsule E-White, QK75 E-White, Zoom75 Milky Green, QK80 Black, Envoy 65 PC, Mode Sonnet Ice Blue, Cycle 7 Lavender, E-White; Neo70 Retro White, Black; Reflection Chocolate, Neo80 Champagne, Matra Alice 90 Glossy Red;
Offline kbye
« Reply #45 on: Wed, 22 June 2022, 15:10:05 »
I like this a lot!
That's a great question. The indicators are 1mm in diameter, and in testing I find the visibility to be very good.
This is revision 1 which uses THT LEDs. The photo shows the indictors in super bright flooded studio lighting. Even under harsh lighting, it's pale but still visible.
Rev2 PCBs are SMD RGB LEDs which are a lot brighter (sorry no pictures at the moment, proto is in use at my office)
There is barely any light bleed because of how close the top is to the PCB, but just to account for it, I have simple gasket cutouts that you stick onto the PCB.
« Reply #46 on: Sat, 25 June 2022, 09:13:44 »
Nice to see that common issues like light bleed are being addressed. Excited to hear more ubdates regarding the project - lots of good 1800 options lately in IC.
Offline treeleaf64
    • treeleaf64
« Reply #47 on: Sun, 26 June 2022, 11:37:13 »
It is not trouble making if the design is simple
Offline lowercaselena
« Reply #48 on: Mon, 11 July 2022, 05:36:00 »
this looks really great!! im happy to see more FRL 1800 options pop up :)
Offline turangaleela
  • らんだむぶれいん!わおっ 叫んじゃえ わおっ
« Reply #49 on: Mon, 11 July 2022, 20:38:00 »
I'm really into this...
