Author Topic: I made a brass artisan - thoughts?  (Read 25462 times)
Offline nitwimp
« on: Mon, 13 June 2022, 00:36:08 »
Hello everybody, this post is going to be about the process i worked through to mill out some metal keycaps. Writing and organized documentation are not my strong suit - sorry if some of this is overly summarized
I am a machinist with a small shop, attended school for maching/drafting and then worked as a manual machinist afterwards. Self taught mostly about CNC/CAD/CAM - at first it was overwhelming but i've learned alot since i started :) - with that brief background about myself out of the way, lets get into it
First I downloaded pre modeled caps (I used hineybush's work, would recommend 10/10 design)
I had to modify them a little bit to make them work for me and my approach to milling them
Started with this
Turned it into this
I made the stem like that for tool clearance reasons
Heres a picture of op1 on the mill - cutting the bottoms of the caps/stems
I had to do the bottom side first ( honestly thats how i've done 90% of parts on my mill ) because i thread the center of the stem with m3 thread to aid in holding down the cap for the second operation
Here is the fixture i came up with, it took a couple attempts but i now have a design that i can easily scale up or down if i want to make more fixtures
Now that operation 1 is complete and we have made our fixture, we can attach our half completed workpiece to it and begin operation 2
heres a small snippet of tool pathing from op2
Now that we have finished milling its time to pull the caps out and give them a quick rinse - heres where we are
Heres what the underside looks like fresh off the mill
Fit check
The caps feel good and not too heavy for stock mx brown switches. Alum would be more ideal for switches with a similar spring weight to mx browns - but for an escape key, its great
So far so good, now im starting to get excited about my progress
Now its time to laser engrave the caps and then lightly sandblast them for powdercoat prep (I used cerakote)
Now its time to finish the caps - I bought a cheap airbrush off of amazon, some cerakote online and a cheap oven from walmart to powder coat them at home
I attached long threaded rod to the tapped stem i used for fixturing (so i have something to hold onto while painting it)
If you can visualize with me - After i spray the lollypop cap i place it into a fixture so the wet cerakote is safe for placing/cooking in the oven
After many attempts I finally got results I was happy with
Heres a example of how the cap sits compared to plastic cherry caps
And thats really about it, please feel free to ask any questions you might have - I hope my post is easy to follow, thanks!!!
imgur dump: https://imgur.com/a/APvk55s
« Last Edit: Mon, 13 June 2022, 13:30:51 by nitwimp »
Offline phinix
Re: I made a brass artisan - thoughts?
« Reply #1 on: Mon, 13 June 2022, 04:56:40 »
Niiice:)
12100 | 9070XT | 2TB SSD | ROG STRIX B760-I ITX | 32GB RAM | SFX 850W | NR200p | Ruark Audio MR1 Mark II | LG OLED 42C4
Realforce 87u55 | CM QuickFire Rapid MX Blacks | Filco TKL 85g Gateron Oil Kings | Tiger Lite 85g Oil Kings | Logitech Pro Superlight
GSA: Retro High-light  HSA: Hyperfuse  XDA: Canvas  PBS: MV Classic
« Reply #2 on: Mon, 13 June 2022, 05:14:31 »
Impressive!  The threaded stem for clamping is a great idea.  Is there a polishing step or is there a "shiny bronze" Cerakote?
Out of interest why brass not aluminium as it's lighter and cheaper?
Offline nitwimp
« Reply #3 on: Mon, 13 June 2022, 11:23:59 »
The ones with exposed metal are polished - I dont think there is a Cerakote thaaattt shiny.
Yeah aluminum is cheaper and lighter but i had some brass left over from some keeb case weights
Offline Tha_Pig
    • Futurepig
« Reply #4 on: Sat, 30 July 2022, 16:34:54 »
That's some impressive work there!   :thumb:
I have two questions, could this be done with aluminum? (I see it's already been asked)
And, could the letters and numbers be engraved on the surface of the key?
« Last Edit: Sat, 30 July 2022, 16:42:26 by Tha_Pig »
Offline NamesReed
  • 40 enjoyer, Cheapskate.
« Reply #5 on: Fri, 05 August 2022, 14:05:59 »
Maybe I missed it in the post, but any idea what they weigh?
Looks great!
IDK man, be positive, kind and caring.
Offline daviddgm
« Reply #6 on: Tue, 09 August 2022, 17:32:03 »
Wow... great!
Offline JP911
« Reply #7 on: Wed, 10 August 2022, 13:27:37 »
Dude thats awesome.
Would be cool to play around with the weight of the switches. I kind of want one for my full brass case lol.
Offline th3_outs1d3r
« Reply #8 on: Tue, 23 August 2022, 22:43:36 »
looks really sweet dude. What is the weight like?
Offline 1pctipaday
  • The show must go on
« Reply #9 on: Wed, 24 August 2022, 07:10:49 »
I would buy them all 😍
Offline upscalevalley
« Reply #10 on: Mon, 29 August 2022, 03:18:42 »
Impressive. Seems you have done lots of hard work getting there. Keep it up.
Offline crookey
« Reply #11 on: Sun, 04 September 2022, 07:31:25 »
It's a really, really cool artisan keycap. The way make a metal artisan keycap using a machine always feels interesting and cool.
« Reply #12 on: Sat, 24 September 2022, 16:51:22 »
Looks great, nice work!
Offline jammiiew
« Reply #13 on: Wed, 19 October 2022, 09:39:45 »
woww. thats shiny look GREAT!
Offline ThreadyKeycaps
    • ThreadyKeycaps
« Reply #14 on: Sat, 22 October 2022, 09:29:14 »
Kudos to you! Definitely sounded like a challenging task. Your keycaps turned out amazeballs!
Offline caughtquick
« Reply #15 on: Wed, 26 October 2022, 00:03:19 »
That looks great, especially for a one off piece :).
Offline ZenKeycaps
« Reply #16 on: Sun, 06 November 2022, 02:34:41 »
Great job, but it seems to me that it is not worth spoiling the noble and special look of the metal by painting, but this is just my opinion :)
Offline alvrnicu
  • Collecting Bongo Cat Keycaps
« Reply #17 on: Tue, 06 December 2022, 10:02:38 »
Love the design on it!
Offline desgeek
    • Desgeek
« Reply #18 on: Tue, 06 December 2022, 20:03:15 »
amazing
Offline Slywanin
  • Abdul Lutfi is my name.
« Reply #19 on: Fri, 30 December 2022, 11:57:54 »
I'll buy them for the entire keyboard of mine! ^-^
Offline Marboard
    • Marboard.net
« Reply #20 on: Thu, 04 May 2023, 15:01:23 »
I know this is very late in the thread, but will you sell these?
Offline mathisart
« Reply #21 on: Tue, 13 June 2023, 07:26:06 »
What type of CNC machine does this require
