Author Topic: KAILH CHOSFOX V2 ARCTIC FOX SWITCH RGB SMD CLICKY  (Read 12524 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Mon, 20 June 2022, 03:32:15 »
Kailh Chosfox V2 Clicky Switch
SPEC
  • PC housing upper and bottom
  • POM stem
  • Clicky switch
  • Spring length about 20mm
  • Actuation force 30+/-10gf
  • Bottom force 52+/-10gf
  • Pre-travel 1.7+/-0.3mm
  • Total Travel 3.6+/-0.3mm
  • 80 million clicks
CHECK IT NOW
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: KAILH CHOSFOX V2 ARCTIC FOX SWITCH RGB SMD CLICKY
« Reply #1 on: Mon, 20 June 2022, 03:32:49 »
Offline KPrepublic
  • * Moderator
    • KPrepublic
