Author Topic: [IC] ktechs S1- Deep Blue Linear Mechanical Switches  (Read 4306 times)
Offline ktechs
« on: Sun, 26 June 2022, 01:49:47 »
Hello friends!
It's our first time posting here in Geekhack so would appreciate any advice that is given. Please be gentle with us  :(
ktechs is a Singapore-based keyboard mods/accessory vendor looking to bring in an interesting proposition for all things mechanical keyboards.
We're taking our first foray into custom mechanical keyboard switches with the S1 switch.
S1-Ultramarine aims to lower the clackish sound profile while providing a loud, satisfying bottom-out experience with a long pole stem.
We are utilizing a HPE Top housing, a proprietary blend by Tecsee that seeks to better UHMWPE.
The bottom housing utilizes another custom blend from Tecsee and the material it's based on is unreleased at the moment (Not HPE definitely).
The colors chosen for the switches are based on our logo as well as freedom from SEED 🙆‍♂️
Disclaimer: 26/6/2022 - Post date: I would like to say that we're not really active in Geekhack but we've found that some of the the top housing and decisions made are really similar to that of the Honeydew IC that's currently ongoing. I've reached out to them and clarified that we're not looking to replicate their work/work based off their project ideas as we've started worktesting/discussions and sampling in the Apr/May window.
We've already jumped over to the samples release stage with the focus being placed on the handfeel as well as the sound and performance of the switches. Samples have already been sold out and units have been sent over to reviewers.
https://ktechs.store/products/ktechs-s1-switches
Our intended GB Pricing is estimated to be 0.8-0.9SGD per unit to be confirmed based on Tecsee's quotation. Est 0.6 to 0.65USD
Through the release, we are collating feedback from our discord server while requesting sound samples and thoughts/opinions on these switches to improve the switch's performance.
25/5/2022 - Increasing the amount of lubricant placed on the switch by the factory. This is basically due to the usage of POM as a material.  - Changed
                - We're considering changing the springs over to Gold Plated 2 stage springs from Stainless steel 2 stage springs to bring down the spring ping from feedback. - Changed
Switch specifications:
Tye: Linear 5 pin MX Stem
Housing: HPE Blend from Tecsee
Stem: POM 13.5mm
Spring: Stainless steel 2 staged spring from Tecsee (50g Actuation, 63.5g bottom out)
Manufacturer: Tecsee
Force curve graph:
S1 Groupbuy Colors
288848-1288850-2288852-3288541-4GB units will have ktechs lettering on them.
Soundtests:
Kohaku:
Satisfaction75
Board: Satisfaction75
Jelly Epoch(member's)
[/i]
QK65(members')
PE,Plate Foam, Tx Stabs, S1 lubed,Aifei ABS WOB:
Compilation of S1 in other boards (members'):
more sound tests can be found on our discord server as well as some switch to switch comparisons uploaded by our members
IC Form: https://forms.gle/G8TTAV6VCC5yGxzx8
Groupbuy/sale date: TBA
Vendor list:
SG/Worldwide: ktechs and mecha store
CA: Shockport
NA: Dangkeebs
Others: TBA, TBD
Things that we're looking at:
1: Arrangement for reviews with creators (In progress and in contact with some sent out)
2: Recording of better quality sound tests (Please note that sound tests are quite subjective and heavily dependent on the users' entire setup)
Updates:
NA/CA/SEA vendors confirmed. Pending updates from other vendors.
Discord links, switch discussions and sales page for samples:
Discord server/discussion:https://discord.gg/edV63Nszby
Sale page: https://ktechs.store/products/ktechs-s1-switches
Thank you and looking forward to your feedback!
« Last Edit: Sun, 10 July 2022, 03:13:29 by ktechs »
Offline ktechs
^_^
