Author Topic: Can plate-mount stabilizers be quieted?  (Read 3219 times)
Offline HungerMechanic
« on: Sun, 26 June 2022, 17:25:31 »
I am assembling a silenced keyboard for someone else, and it will probably use plate-mount stabilizers.
In my experience, they can bottom-out pretty loud and hard.
The silent switches are fine, but I don't want loud stabilizers ruining the board. Is it possible to keep stabilizers quiet / from bottoming-out by using O-rings or something?
Offline MIGHTY CHICKEN
Re: Can plate-mount stabilizers be quieted?
« Reply #1 on: Sun, 26 June 2022, 19:43:11 »
What comes to mind is lube, bandaid underneath, maybe some of them foam stab pads, I've heard of people cutting up orings and sliding a small piece under stabs.
« Reply #2 on: Sun, 26 June 2022, 20:36:53 »
Hmm. Yes. I figured it might come down to modifying the stabilizers.
Offline granola bar enthusiast
« Reply #3 on: Sun, 26 June 2022, 21:19:16 »
stab pads are great.
also ThockPop (very cool vendor btw they are super kind) has the dry hump mod and you can do a modified holee mod which dampens bottom out
